Insert Spaces in Variable?
Tue Sep 11, 2012 9:56 pm
ckeyes888 offline
Hey,
I'm constructing some variables using AppleScript that I need to have six spaces
inserted into, e.g. "abcde______ abcde", where the underscores here would be actual spaces. I've tried a number of things like, & " " & " " to add them but it only works to add just one space.
Not having much luck finding an answer anywhere how best to add them.
Any ideas?
Carl
Tue Sep 11, 2012 10:10 pm
nsheldon offline
Re: Insert Spaces in Variable?
Hi Carl.
Are you trying to use spaces in variable names or variable values? Variable names cannot have spaces in them. To add 5 spaces to the end of a variable value, the following AppleScript should work.
set value of variable "MyVariable" to value of variable "MyVariable" & "     "
Tue Sep 11, 2012 10:33 pm
ckeyes888 offline
I'd tried that but I only get one space. The spaces, in the variable value, need to be in the
middle, not at the beginning or end if that makes a difference.
Carl
Edit: Tried it again and it did work...go figure. Thanks a bunch.
Tue Sep 11, 2012 10:44 pm
nsheldon offline
Cool! Glad it worked.
Wed Sep 12, 2012 9:34 am
ckeyes888 offline
Oops...spoke too soon. The extra spaces show correctly in Touch control pages but
not in any browsers. Any idea what character I could insert into the variable to
get the spaces to show on web pages?
Carl
Wed Sep 12, 2012 9:44 am
nsheldon offline
Ha! That's a very different question. :-) The short answer is "no". I've seen this as well in my own control pages. The spaces do exist in the variable value, but either the web browsers ignore the extra white space (which makes sense, as that's how HTML, XML, and many other languages are), or Indigo Web Server interprets the control page contents slightly differently for web browsers compared to Indigo Touch, or both.
Wed Sep 12, 2012 10:00 am
berkinet offline
You can try   that should work in a browser, but probably not the iTouch client
Wed Sep 12, 2012 10:21 am
ckeyes888 offline
Thanks a bunch. Well I ended up just using some characters to fill it up.
It shows the high and low temps for the week here at the house and the NOAA reporting
station at the airport here.
Carl
Past Temps.jpg (154.1 KiB) Viewed 2258 times
Wed Sep 12, 2012 11:38 am
berkinet offline
Looks good. Nice touch with the High/Low gradient from Red to Blue.
Users browsing this forum: No registered users and 27 guests
