Spotify parcially intergrating
Fri May 11, 2012 12:10 pm
henkjanvries offline
Hi everyone,
ive had Indigo for a while but since I've got a rfxcom I've seriously got into indigo.
Right now I'm just trying to get a little bit of spotify integration, which is working a bit.
But I'm trying to fill a variable with the state of spotify: playing or paused.
I've think I've got it with a applescript, but I'm getting an error:
ell application "IndigoServer"
exists variable «constant ****kPSP»
--> error number -10001
Result:
error "IndigoServer got an error: Er heeft zich een descriptor type mismatch voorgedaan." number -10001 to item (sorry dutch language)
does anyone know what to do?
here is my code
property spotifystate : ""
if spotifystate = "" then
   tell application "Spotify"
      if player state is paused then play
      set spotifystate to playing
         if not (variable spotifystate exists) then ¬
            make new variable with properties {name:spotifystate, value:playing}
         if playing is not equal to (value of variable spotifystate) then
            set value of variable spotifystate to playing
         else
            tell application "Spotify" to pause
            set spotifystate to paused
                  make new variable with properties {name:spotifystate, value:paused}
               if paused is not equal to (value of variable spotifystate) then
                  set value of variable spotifystate to paused
               end if
            end tell
         end if
      end tell
   end tell
end if
i hope I'm in he right direction. At least the functions for spotify work, it just that i want the value into a variable n indigo
thanks for the help!
HenkJan
Fri May 11, 2012 12:50 pm
Re: Spotify partially intergrating
Actually, I think there are a few logical problems with the script. I think what you're trying to do is toggle the spotify player and make sure that an Indigo variable is updated when you change it. Try this (untested because I don't have the spotify app):
property spotifyStateVariableName : "INDIGOVARIABLENAMEHERE"
-- First, toggle the player state and save the new status
-- in a local AppleScript variable called playerState
        -- Player is paused so we tell it to play
        play
        set playerState to "playing"
    else
        -- Player is playing so we tell it to pause
        pause
        set playerState to "paused"
    end if
end tell
-- Next, tell Indigo to set the variable to the saved playerState
    -- If the variable doesn't exist then create it with the right values, otherwise just update
        make new variable with properties {name:spotifystate, value:playerState}
    else
        set value of variable spotifystate to playerState
    end if
end tell
Fri May 11, 2012 1:06 pm
Re: Spotify parcially intergrating
the script got a fault
    [b]else[/b]
    end if
end tell
else should be end or end tell not else
any clue?
Fri May 11, 2012 1:10 pm
Leftover cruft from your original version:
        play
    else
        pause
    end if
end tell
    else
    end if
end tell
Fri May 11, 2012 1:15 pm
im not sure what your getting at,
but do you mean that i should have a second script that keeps track of the state of spotify and that the indigo script reads that one to toggle the value of the variable?
Fri May 11, 2012 4:00 pm
I corrected the problem with my first post in my second post...
Sat May 12, 2012 2:25 am
i was think to hard.
here is a undressed version that works.
   if player state is playing then
      pause
      set spotifystate to "paused"
   else
      play
      set spotifystate to "playing"
   end if
end tell
   if not (variable "spotifystate" exists) then ¬
      make new variable with properties {name:"spotifystate", value:spotifystate}
   if "spotifystate" is not equal to (value of variable "spotifystate") then
      set value of variable "spotifystate" to spotifystate
   end if
end tell
thanks for help!
Users browsing this forum: No registered users and 25 guests
