How Do You Set "Condition" in a Trigger with Applescript
Mon Jun 20, 2011 8:25 am
bob offline
How Do You Set "Condition" in a Trigger with Applescript? I want to set "If variable" someVariable is false. I don't see "condition" in the dictionary?
thanks,
bob
Mon Jun 20, 2011 9:18 am
Re: How Do You Set "Condition" in a Trigger with Applescript
Conditions aren't supported in AppleScript or Python.
As a workaround, you can create a sort of "template" trigger which contains the condition you want to use. Then duplicate it rather than create one from scratch and change the trigger and/or actions in code. The Conditions will get duplicated from the template.
NOTE: I just found a bug in the current Indigo 5 beta - the duplicate command in AppleScript seems to be broken; we'll get that fixed in an upcoming release.
Thu Jun 30, 2011 10:51 am
Fixed in Beta 6 - the duplicate bug in AppleScript that is is fixed. So the workaround I proposed above will now work.
