How to Use AppleScript to Display Logs in Indigo Touch
Tue Aug 10, 2010 8:40 pm
nsheldon offline
Example: How to Use AppleScript and Time/Date Actions to Show Recent Logs in Indigo Touch
Though this isn't as good as a built-in option to view recent log activity within the Indigo Touch app (and web interface), it does allow you to view the last 5 lines of the log (this is adjustable), updated every minute. Note that this will only work with Indigo Pro.
Here's how to set it up. Create a new Time/Date Action within the Indigo 4 Pro client with the following parameters:
    Name: Update Recent Activity Variables
    Time/Date Trigger tab:
      Time: Every 0 hours 1.00 minutes
      Date: Every 1 days
      Randomize by +/-: 0 minutes
      Starts on: (make sure the date here is the current date).
      CHECKED Suppress logging
      NOT CHECKED Auto delete after trigger
    Condition tab:
      Upon trigger do actions Always
    Actions tab:
      Type: Execute AppleScript
      Embedded
      set the ActivityLog to do shell script "tail -5 \"/Library/Application Support/Perceptive Automation/Indigo 5/Logs/indigo_log.txt\""
      set the TotalNumberOfLines to the count of paragraphs in the ActivityLog
      set the CurrentLine to 1
      repeat while the CurrentLine is less than or equal to the TotalNumberOfLines
          set the TextOfTheCurrentLine to paragraph CurrentLine of the ActivityLog
          set the variableName to ("RecentActivity" & CurrentLine) as string
          if not (variable variableName exists) then
              make new variable with properties {name:variableName, value:TextOfTheCurrentLine}
          else
              set the value of the variable variableName to the TextOfTheCurrentLine
          end if
          set the CurrentLine to (the CurrentLine + 1)
      end repeat
      NOT CHECKED Delay by ... minutes.
If you want more than 5 lines, simply change the "-5" after the "tail" command on the first line of the AppleScript to the number of lines (and corresponding "RecentActivity#" variables) you want.
Allow the trigger to run at least once (which should happen within a minute after clicking the OK button in the new Time/Date Action dialog). This will create a "RecentActivity#" variable for each of the lines of log data. You can then go into the Control Pages section and edit an existing page (or create a new one) and place a new Variable Value object for each line of the log anywhere you like on the page. The variables will be named "RecentActivity1" through "RecentActivity5" (or up to whatever number of lines you set above).
NOTE that text does not wrap on control pages, so be sure your control page is wide enough to show all of each line.
Fri Sep 03, 2010 12:38 pm
hamw offline
Re: How to Use AppleScript to Display Logs in Indigo Touch
That is very cool. Great idea.
Sat Sep 04, 2010 10:00 am
hamw offline
This will get rid of the date stamp, which takes up a lot of room on the variable output. Change character start, currently at 12, to 20 or so if you want to get rid of the time too.
set the ActivityLog to do shell script "tail -9 \"/Library/Application Support/Perceptive Automation/Indigo 6/Logs/indigo_log.txt\""
    set stringTextOfTheCurrentLine to paragraph CurrentLine of the ActivityLog as string
    set TextOfTheCurrentLine to (characters 12 through -1 of stringTextOfTheCurrentLine as string)
    else
    end if
end repeat
edited for Indigo 6.
Mon Sep 06, 2010 7:22 pm
nsheldon offline
Nice modification, hamw. Very handy to not have the time stamps all the time.
Sat Sep 11, 2010 6:40 am
hamw offline
The other thing I did was add a button to the top of the control page to execute the time date action so that the log would update immediately instead of having to wait a minute.
execute time date action "Update Recent Activity Variables"
Oddly I am occasionally getting a bunch of colons in the spaces between numbers and words. A reboot of the server fixes it. Are you seeing the same thing?
Sat Dec 18, 2010 10:55 am
hamw offline
Here's an example:
1:1:::3:1:::4:0: :W:e:b:S:e:r:v:e:r: :I:n:d:i:g:o: :T:o:u:c:h: :c:l:i:e:n:t: :c:o:n:n:e:c:t:e:d: :f:r:o:m: :1:0:.:0:.:1:.:2:0:0
any thoughts as to why this would happen? Otherwise this is a great script.
Sat Dec 18, 2010 11:20 am
Add this line:
set AppleScript's text item delimiters to ""
at the top of the script and see if that helps. The line that cuts out the date is reassembling the string by using text item replacements and you probably have another embedded script that periodically runs that's setting the delimiter to ":". That would cause what you're seeing. No guarantee but I suspect that's it.
Sat Dec 18, 2010 2:18 pm
hamw offline
Right you are, Jay. In my script for setting a timer variable for a whole house alarm clock, the set text item delimiter is there.
using terms from application "IndigoServer"
    set theCurrentDateTime to absolute trigger time of time date action "Radio WakeUP Actual WakeUp Time"
    set AppleScript's text item delimiters to ":"
    set theTargetTime to value of variable "RadioWakeUpDisplay"
    set hours of theCurrentDateTime to (text item 1 of theTargetTime) as number
    set minutes of theCurrentDateTime to (text item 2 of theTargetTime) as number
    set absolute trigger time of time date action "Radio WakeUP Actual WakeUp Time" to theCurrentDateTime
    set the value of the variable "RadioWakeUpEnabled" to "Yes, Actual Time"
end using terms from
All fixed up!
Sun May 22, 2011 6:48 am
hamw offline
If you have upgraded to Indigo 5,change the Indigo 4 in the first line to Indigo 5. Will work fine.
Sun May 22, 2011 8:42 am
I've updated the script in the original post with your suggestion. Thanks.
Sun Apr 27, 2014 8:51 pm
TheTechnoPilot offline
Hi all,
I updated this for the current daily log scheme that I am seeing in my copy of Indigo 6 and thought I would share it back out.
set IndigoLogYear to (year of (current date))
set IndigoLogMonth to ((current date)'s month as integer) as number
if IndigoLogMonth < 10 then
   set IndigoLogMonth to "0" & IndigoLogMonth
end if
set IndigoLogDay to ((day of (current date)) & " Events.txt") as string
set IndigoLogName to (IndigoLogYear & "-" & IndigoLogMonth & "-" & IndigoLogDay) as string
log IndigoLogName
set the ActivityLog to do shell script "tail -10 \"/Library/Application Support/Perceptive Automation/Indigo 6/Logs/" & IndigoLogName & "\""
      else
      end if
   end tell
end repeat
Cheers,
Sean "TheTechnoPilot"
Thu Apr 21, 2016 10:38 am
Different Computers offline
I would love to modify this script to only pull trigger executions from the log. Would grep work for this? I'm not sure how the log formats the whole
Trigger        this is where the trigger name goes
Thing.
Since I name my triggers something conversational, like "Kitchen lights turned off because no one is in there." I would love to just have those showing up on a control page.
Fri Apr 29, 2016 11:08 am
I got this working, though it's not pulling just triggers. That's OK.
In the scheduled run of this, I have logging suppressed, but I still get a log entry for "Script 2016-04-29 Events.txt" that's generated every minute. Is there a way to suppress that too?
Sun May 01, 2016 6:53 pm
So it's the first of the month, which I mention because this started just after midnight.
Error script error: tail: /Library/Application Support/Perceptive Automation/Indigo 6/Logs/2016-05-1 Events.txt: No such file or directory
The script still seems to be working though. Ideas how to fix it?
Mon May 02, 2016 1:08 am
The log file is 2016-05-01 so you need to pad the '1' with a '0' in your script.
