Fun with iChat
Thu May 13, 2004 9:56 am
G4Shallow offline
Fun with iChat
I have been messing around with iChat and using it to change the ichat status message with an indication of what is happening and of course to send me a message if it is major, obviously for when I am at work not sitting downstairs ;)
This is just something I did to test if it works and it does :D so I am going to explore the options.
It of course requires you to have 2 AIM accounts. Anyone else doing anything with this?
I found that if iChat is not logged in then the script throws up an error hence the delay.
Thoughts?
--[url=applescript://com.apple.scripteditor/?action=new&script=tell%20application%20%22Indigo%22%0A%09using%20terms%20from%20application%20%22Indigo%22%0A%09%09if%20(on%20state%20of%20device%20%22Living%20Room%20Lamp%22)%20is%20true%20then%0A%09%09%09tell%20application%20%22iChat%22%0A%09%09%09%09log%20in%0A%09%09%09%09delay%2010%0A%09%09%09%09set%20status%20message%20to%20%22Light%20ON!!!%22%0A%09%09%09%09set%20buddy%20to%20%22ABUDDYNAME%22%0A%09%09%09%09set%20info%20to%20%22You%20left%20a%20light%20on!%22%0A%09%09%09%09send%20info%20to%20account%20buddy%0A%09%09%09end%20tell%0A%09%09else%0A%09%09%09tell%20application%20%22iChat%22%0A%09%09%09%09log%20in%0A%09%09%09%09delay%2010%0A%09%09%09%09set%20status%20message%20to%20%22Nothing%20to%20report%22%0A%09%09%09end%20tell%0A%09%09end%20if%0A%09end%20using%20terms%20from%0Aend%20tell]Open this script in a new Script Editor window[/url].
tell application "Indigo"
     using terms from application "Indigo"
          if (on state of device "Living Room Lamp") is true then
               tell application "iChat"
                    log in
                    delay 10
                    set status message to "Light ON!!!"
                    set buddy to "ABUDDYNAME"
                    set info to "You left a light on!"
                    send info to account buddy
               end tell
          else
                    log in
                    delay 10
                    set status message to "Nothing to report"
               end tell
          end if
     end using terms from
end tell
[This script was automatically tagged for color coded syntax by Convert Script to Markup Code]
Thu May 13, 2004 10:42 am
gregjsmith offline
(No subject)
I was thinking of doing some similar. I was going to use my cell phone's AIM capability so that I could have a 2 way chat with the HA system.
