Talk to Indigo via IChat on Leopard
Tue Feb 26, 2008 7:17 pm
jashaffner offline
Please feel free to throw in some ideas for this script for anyone who finds it convenient to talk to the house via IM.
You can just put script in /Library/Scripts/iChat/ and use it in iChat > Preferences > Alerts > Event: Message Received. I use separate IM account and leave it running 24/7 on machine running Indigo.
Ideas:
- get device's status
Enjoy!
using terms from application "iChat"
   -- handler to respond to all incoming messages.
   on runIndigoRemoteControl(theMessage)
      set theResponse to "Unknown command."
      try
         if theMessage is "flash" then
               flash(2)
            end tell
            set theResponse to "Executing flash"
         else if theMessage is "bedtime" then
               execute group "scene - bedtime"
            end tell
            set theResponse to "Executing bedtime scene"
         else if theMessage is "tail log" then
               set theResponse to build event log list line count 30
            end tell
         else if theMessage is "help" then
            -- display available commands on "help"
            set theResponse to "Available Commands: flash, bedtime, tail log, turn on/off [device], toggle [device], dim/brighten [device], all lights on/off, execute group [name], tail log, send email to [emailAddress] [with subject text] [with body text]"
         else
               set result to (run script theMessage) as string
            end tell
            if result is "" then
               set theResponse to "Executing " & theMessage
            else
               set theResponse to result
            end if
         end if
      on error errorMessage
         set theResponse to errorMessage
      end try
      return theResponse
   end runIndigoRemoteControl
   -- When first message is received, accept the invitation and send a greeting message from Indigo Remote Control.
   on received text invitation theMessage from theBuddy for theChat
      accept theChat
      send "Welcome to Indigo Remote Control." to theChat
      set theResponse to runIndigoRemoteControl(theMessage)
      send theResponse to theChat
   end received text invitation
   -- On subsequent messages, pass the message directly to Indigo Remote Control.
   on message received theMessage from theBuddy for theChat
   end message received
   -- Sample, so you can test run this through Script Editor.
   display dialog "Send a command to Indigo Remote Control:" default answer "help"
   set theMessage to the text returned of the result
   display dialog theResponse
end using terms from
ps: borrowed a piece of code from script that came with iChat on Leopard for remote controlling iTunes.
Wed Feb 27, 2008 10:41 pm
asw24b offline
Re: Talk to Indigo via IChat on Leopard
I made one small change, which prevents anyone but me from from controlling things...
-- only allow connections from me for control -- put your name here
if the name of theBuddy is "myname@mac.com" then
accept theChat
else
log "Someone bogus tried to connect to us"
send "Bye" to theChat
decline theChat
end if
Thu Feb 28, 2008 8:55 am
jashaffner offline
(No subject)
yea, I thought about restricting to certain users (ie: wife and myself) via applescript but figured that I could just use iChat's privacy level which is set to allow people only in buddylist.
Thu Feb 28, 2008 10:54 am
(No subject)
Great script idea -- thanks for sharing!
Matt
Thu Mar 20, 2008 10:20 pm
mreyn2005 offline
random thought
It would be neat if one could incorporate an AIML bot application... Then your indigo mac could talk back! I know there are some python AIML implementations...
Matthew
Sun Apr 27, 2008 4:55 pm
gregjsmith offline
(No subject)
I've been testing ichat scripting. I found one problem, when ichat looses it's connection a bunch of dialogs pop up. You can't get rid of them without human interaction. I'm going to try this as a replacement.
http://www.macupdate.com/info.php/id/21 ... -scripting
Sun Apr 27, 2008 6:18 pm
mreyn2005 offline
(No subject)
the website says there is a charge for each SMS message sent?
Sun Apr 27, 2008 7:42 pm
gregjsmith offline
(No subject)
It appears you have to sign up for their SMS service. :(
Sun Feb 22, 2009 3:27 pm
jnscolo offline
(No subject)
Help. I copied and used this script (after commenting out the test stub at the bottom.) It works great, except, it only responds on the second inbound message (and subsequent,) not the first. No matter what I've tried, I can't get it to respond to the initial message. Anybody have any suggestions?
Mon Jan 03, 2011 7:10 pm
jmesberg offline
I realize this is a pretty old & stale thread, but I just started playing around with controlling Indigo through iChat and found that these scripts didn't quite work for me. The biggest problem was that the threads assumed that you'd be using an AIM or iChat account that was dedicated to home control. I don't think that's practical so I reworked the script to first assess whether the user is attempting to have a normal chat, or trying to control devices in the home,
I also fixed the other problem that member jnscolo describes below. It requires two scripts, one that you attach to the Text Invitation event, and the other that you attach to the Message Received event (as described in this thread you attach these in the Alerts pane of the iChat preferences panel).
Here is the Text Invitation event script:
   global AttemptingControl
   local theResponse
   set AttemptingControl to false
   set theResponse to ""
      accept theChat
      -- run parser.
      set theResponse to runAction(theMessage)
      -- determine if theBuddy is attempting Home Control
      if AttemptingControl is true then
         -- send back the response.
         -- initiate Indigo action
            execute group theResponse
         end tell
      end if
   on runAction(theMessage)
      if theMessage is "Entrance Lights on" then
         set AttemptingControl to true
         set theResponse to "Entrance Lights On"
      else if theMessage is "Heater On" then
         set theResponse to "Downstairs Heater On"
         set theResponse to "Available commands: Entrance Lights On, Heater On"
      end if
      return theResponse
   end runAction
...and here is the Message Received event script:
   local theResponse
      -- run parser.
      end tell
      end if
      return theResponse
   end runAction
I am not an experienced programmer so I'm sure there is probably a more elegant way to solve these problems, but these work for me and perhaps can help someone else out there.
John
Mon Jan 03, 2011 7:12 pm
jmesberg offline
apologies for the formatting above. I tried to use the Code block html formatting offered by the forum, but clearly not using it correctly. I hope to be posting some more applescripts soon, can someone tell me the right way to post code?
Tue Jan 04, 2011 12:19 am
macpro offline
Just look at the last line of your code.
You have just /code] instead of [/code].
"I tawt I taw a puddy tat!" Tweety
Tue Jan 04, 2011 7:27 am
jmesberg offline
Thank you. Reposted here properly:
local theResponse
accept theChat
-- run parser.
end tell
end if
end if
return theResponse
end runAction
local theResponse
-- run parser.
end tell
end if
return theResponse
end runAction
John
Mon Mar 28, 2011 2:50 pm
chrisla23 offline
Does the script originally posted work? It seems to me the on/off does not as the name of the device needs to be quoted ie:
turn off "bedroom lights"
It does not seem to work either way. It seems fine if I hard code in the commands per device like the later versions do, but essentially passing applescript thru as the first one appears to try to do in its final else fails.
Am I missing something? Obviously the first way is nice as it's simpler and does not need to be modified each time new devices are added.
Wed Mar 30, 2011 6:49 am
I'm not seeing "turn off" anywhere in the scripts posted above. Can you specify which script you are trying to to use exactly?
