Time Set Script Not Working
Sat Apr 21, 2018 8:43 pm
ckeyes888 offline
After upgrading to 10.12 this script, which set my time variables no longer works.
set theDate to (current date) as string
set hourWord to word 5 of theDate as integer --hour
set minWord to word 6 of theDate as integer --minute
set apWord to word 8 of theDate --AM or PM
set theHour to hourWord * 100 + minWord
if (apWord = "PM" and hourWord ≠ 12) then set theHour to theHour + 1200
if (apWord = "AM" and hourWord = 12) then set theHour to theHour - 1200
-- add leading zero if necessary
set minWordString to minWord as string
set theLength to the length of minWordString
if theLength = 1 then
   set minWord to "0" & minWord as string
end if
set theClock to (hourWord as string) & ":" & minWord as string
set theDay to text 1 thru 3 of theDate
   set value of variable "TimeNow" to (current date) as string
   set value of variable "TimeNow2400" to theHour
   set value of variable "ClockTime" to theClock
   set value of variable "DayShort" to theDay
end tell
It returns this error:
Error script error: around characters 77 to 84
Error script error: Can’t make "at" into type integer. (-1700)
Appreciate any help with a fix.
carl
Sat Apr 21, 2018 9:32 pm
ckeyes888 offline
Re: Time Set Script Not Working
Curious, how are people setting time variables now?
Doubt it’s by using my above script.
Carl
Sun Apr 22, 2018 12:13 am
Interesting question, and I think all the conversations about it are using AppleScript and variables.
This is crying out to be a plugin - and it would only take minutes to write (no pun intended).
Let me have a look.
Sun Apr 22, 2018 2:09 am
Sun Apr 22, 2018 5:15 am
jalves offline
For current time I use a schedule that runs every minute. It puts the current time string into a variable called "Current_Time" with the format string "%l:%M %p"
Running Indigo 7.4.1 on a 27" iMac (mid-2017), 40G memory, 1T Fusion Drive, OS X 10.15.4
Jeff
Sun Apr 22, 2018 8:12 am
ckeyes888 offline
howartp wrote:
https://github.com/howartp84/ClockDisplay/releases/tag/1.0.0
Tadaa
Peter
Love the plugin! Maybe some way to remove the preceding 0? e.g. 07:27 AM to 7:27 AM
Thanks a bunch,
Carl
Sun Apr 22, 2018 8:14 am
Definitely.
Sun Apr 22, 2018 3:27 pm
ckeyes888 offline
howartp wrote:
Definitely.
Carl
Sun Apr 22, 2018 3:37 pm
Definitely will add ability to remove zero.
I intended it from the start, because PHP has both time values with and without, but Python only has time value natively.
Peter
Mon Apr 23, 2018 6:08 pm
ckeyes888 offline
Might also be nice to have the am pm in lowercase.
Maybe just me but I think it looks much better.
Carl
Mon Apr 23, 2018 8:31 pm
I agree; Python’s defaults are poor in my opinion.
Will sort.
Tue Apr 24, 2018 10:22 am
Tue Apr 24, 2018 10:25 am
Tadaa
Awesome README in Github! :wink:
Tue Apr 24, 2018 11:08 am
ckeyes888 offline
Great reference...thanks for posting.
Not seeing a way to not pad the time with a 0, or have a lowercase am pm.
Maybe I missed something?
Carl
Tue Apr 24, 2018 11:39 am
%l (lowercase L) is a platform-dependent specifier to get the time without the 0 padding (pads with a space instead). So it'll work as long as Apple doesn't change the POSIX implementation that's used by Python.
