I'm trying to make a script that I can use to reboot a hardware music server I have (NuVo MusicPort). It's relatively straightforward to do, load the page, click the button, and a box comes up asking if you're sure, and I want to click 'ok'.
I have an applescript (attached) that loads the page and clicks the button. The problem is the dialog box that pops up asking "Are you sure you want to restart the server?". I've found many methods online for how to click a button on a dialog box, and even tried things like telling system events to enter "Keystroke return" ('OK' is the default selection). However none of it works. Some more testing and troubleshooting eventually shows me that as soon as the dialog box pops up, the applescript stops running until *I* click on a button and dismiss it (however, I can't make Applescript click on it).
This is the code I'm currently using to load the page and click the link on the page:
- Code: Select all
--Define Web Page Loader
to goToWebPage(theWebPage)
tell application "Safari"
activate
set URL of document 1 to theWebPage
end tell
end goToWebPage
--Define method to click a button by it's ID
to clickID(theID)
do JavaScript "document.getElementById('" & theID & "').click();" in document 1
end tell
end clickID
--load the page, wait a second, and click the button.
try
goToWebPage("http://10.0.1.10/Config/Machine.aspx")
delay 5
clickID("btnReboot")
--delay 2
---supposed to deal with the stupid dialog box, but doesn't seem to work.
--problem is that it doesn't even get here. Nothing runs until box is dismissed.
tell application "System Events" to tell process "Safari"
click button "OK" of window 1
end tell
end try
I'm also attaching all of the html for the web page in question... I'm totally open to any other kind of solution here that bypasses the dialog box and just 'runs the process' using either AppleScript or Python (my current skill level has me just trying to replicate the button clicks).
Page html:
- Code: Select all
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head id="Head1"><title>
Server Settings
</title><link href="Content/style.css" rel="stylesheet" type="text/css" /><link href="Content/ui.datepicker.css" rel="stylesheet" type="text/css" /><link href="Content/jquery.timeentry.css" rel="stylesheet" type="text/css" /></head>
<body bgcolor="000000" >
<script src="Scripts/jquery-1.2.6.min.js" type="text/javascript"></script>
<script src="Scripts/jquery.validate.min.js" type="text/javascript"></script>
<script src="Scripts/autonomic.validate.js" type="text/javascript"></script>
<script src="Scripts/jquery.alphanumeric.pack.js" type="text/javascript"></script>
<!-- jquery.datePicker.js -->
<script src="scripts/date.js" type="text/javascript" ></script>
<script src="scripts/jquery.bgiframe.js" type="text/javascript" ></script>
<script src="scripts/jquery.datePicker.js" type="text/javascript" ></script>
<!-- jquery.timeentry.js -->
<script src="Scripts/jquery.timeentry.js" type="text/javascript"></script>
<form name="form1" method="post" action="Machine.aspx" id="form1">
<input type="hidden" name="__VIEWSTATE" id="__VIEWSTATE" value="/wEPDwULLTE2OTk3NDczMjFkZIJfcpCEINjIK6rfqR1i14y64u1w" />
<input type="hidden" name="__EVENTVALIDATION" id="__EVENTVALIDATION" value="/wEWDQLiqf/HCAKZ+sDFCAKo9oKOAgKVzu6tCQL9oMr4AgKag+SDDQKc0Nb1DgKjm47TDwKI5PiaBwKI5OyaBwLOnd+ODgKAgfvvBQLZ+umcDusqu9j2NpIhxj9HCqfrm5+r3Juk" />
<div id="wrapper">
<div id='header'>
<div id='logo'>
<h1><a href='/MusicPort/'><span class='text'><span>Music Port</span></span></a></h1>
<a href='http://www.nuvotechnologies.com/' target='_blank'><span class='logo'><span>NuVo Technologies Inc.</span></span></a>
</div>
</div>
<!-- end #header -->
<div id='menu'><ul><li><a href='Machine.aspx' class='a'><span class='a2'>Machine Settings</span></a></li><li><a href='Sources.aspx' class='a'><span class='a2'>Source Settings</span></a></li><li><a href='Content.aspx' class='a'><span class='a2'>Content</span></a></li><li><a href='Software.aspx' class='a'><span class='a2'>Firmware</span></a></li></ul></div>
<!-- end #menu -->
<div id="page">
<div id="banner"> </div>
<div id="content">
<div class="post">
<h1 class="title"><a href="#">Server Settings</a></h1>
<div class="entry">
<fieldset id="gbsystemName">
<legend>Server Identification</legend>
<table width='100%'>
<tr>
<td class="label"><label id="lsystemName" for="tbSysName">Name</label></td>
<td class="field">
<input name="tbSysName" type="text" value="MUSIC-PORT" id="tbSysName" class="required setvalue" ci="1" cicat="SYSTEM" ciname="NAME" />
</td>
<td class="status"></td>
</tr>
<tr>
<td class="label"><label id="lsystemDescription" for="tbSysDescrip">Description</label></td>
<td class="field">
<input name="tbSysDescrip" type="text" value="NuVo Music Port Server NV-MPS4" id="tbSysDescrip" class="required setvalue" ci="1" cicat="SYSTEM" ciname="DESCRIPTION" style="width:300px;" />
</td>
</tr>
</table>
</fieldset>
</div>
<div class="entry">
<fieldset id="dateAndTime"><legend>Date and Time</legend>
<tr class="btnNtpSync">
<td class="label"><label id="ltbSysDate" for="tbSysDate">Date</label></td>
<td class="field"><div id='timeString' style="font-weight:bold;">12:34:11 PM Saturday, October 31, 2015</div></td>
</tr>
<td class="label"><label id="llbSysTimeZone" for="lbSysTimeZone">Time zone</label></td>
<td class="field">
<select id="lbSysTimeZone" name="lbSysTimeZone" style="width:300px;" cicat='SYSTEM' ciname='TIME_ZONE' class='setvalue' ><option value="0" >(GMT-12:00) International Date Line West</option><option value="1" >(GMT-11:00) Midway Island, Samoa</option><option value="2" >(GMT-10:00) Hawaii</option><option value="3" >(GMT-09:00) Alaska</option><option value="4" >(GMT-08:00) Pacific Time (US & Canada)</option><option value="5" >(GMT-08:00) Tijuana, Baja California</option><option value="6" >(GMT-07:00) Arizona</option><option value="7" >(GMT-07:00) Chihuahua, La Paz, Mazatlan - New</option><option value="8" >(GMT-07:00) Chihuahua, La Paz, Mazatlan - Old</option><option value="9" >(GMT-07:00) Mountain Time (US & Canada)</option><option value="10" >(GMT-06:00) Central America</option><option selected="selected" value="11" >(GMT-06:00) Central Time (US & Canada)</option><option value="12" >(GMT-06:00) Guadalajara, Mexico City, Monterrey - New</option><option value="13" >(GMT-06:00) Guadalajara, Mexico City, Monterrey - Old</option><option value="14" >(GMT-06:00) Saskatchewan</option><option value="15" >(GMT-05:00) Bogota, Lima, Quito, Rio Branco</option><option value="16" >(GMT-05:00) Eastern Time (US & Canada)</option><option value="17" >(GMT-05:00) Indiana (East)</option><option value="18" >(GMT-04:30) Caracas</option><option value="19" >(GMT-04:00) Atlantic Time (Canada)</option><option value="20" >(GMT-04:00) La Paz</option><option value="21" >(GMT-04:00) Manaus</option><option value="22" >(GMT-04:00) Santiago</option><option value="23" >(GMT-03:30) Newfoundland</option><option value="24" >(GMT-03:00) Brasilia</option><option value="25" >(GMT-03:00) Buenos Aires</option><option value="26" >(GMT-03:00) Georgetown</option><option value="27" >(GMT-03:00) Greenland</option><option value="28" >(GMT-03:00) Montevideo</option><option value="29" >(GMT-02:00) Mid-Atlantic</option><option value="30" >(GMT-01:00) Azores</option><option value="31" >(GMT-01:00) Cape Verde Is.</option><option value="32" >(GMT) Casablanca</option><option value="33" >(GMT) Greenwich Mean Time : Dublin, Edinburgh, Lisbon, London</option><option value="34" >(GMT) Monrovia, Reykjavik</option><option value="35" >(GMT+01:00) Amsterdam, Berlin, Bern, Rome, Stockholm, Vienna</option><option value="36" >(GMT+01:00) Belgrade, Bratislava, Budapest, Ljubljana, Prague</option><option value="37" >(GMT+01:00) Brussels, Copenhagen, Madrid, Paris</option><option value="38" >(GMT+01:00) Sarajevo, Skopje, Warsaw, Zagreb</option><option value="39" >(GMT+01:00) West Central Africa</option><option value="40" >(GMT+02:00) Amman</option><option value="41" >(GMT+02:00) Athens, Bucharest, Istanbul</option><option value="42" >(GMT+02:00) Beirut</option><option value="43" >(GMT+02:00) Cairo</option><option value="44" >(GMT+02:00) Harare, Pretoria</option><option value="45" >(GMT+02:00) Helsinki, Kyiv, Riga, Sofia, Tallinn, Vilnius</option><option value="46" >(GMT+02:00) Jerusalem</option><option value="47" >(GMT+02:00) Minsk</option><option value="48" >(GMT+02:00) Windhoek</option><option value="49" >(GMT+03:00) Baghdad</option><option value="50" >(GMT+03:00) Kuwait, Riyadh</option><option value="51" >(GMT+03:00) Moscow, St. Petersburg, Volgograd</option><option value="52" >(GMT+03:00) Nairobi</option><option value="53" >(GMT+03:00) Tbilisi</option><option value="54" >(GMT+03:30) Tehran</option><option value="55" >(GMT+04:00) Abu Dhabi, Muscat</option><option value="56" >(GMT+04:00) Baku</option><option value="57" >(GMT+04:00) Caucasus Standard Time</option><option value="58" >(GMT+04:00) Yerevan</option><option value="59" >(GMT+04:30) Kabul</option><option value="60" >(GMT+05:00) Ekaterinburg</option><option value="61" >(GMT+05:00) Islamabad, Karachi</option><option value="62" >(GMT+05:00) Tashkent</option><option value="63" >(GMT+05:30) Chennai, Kolkata, Mumbai, New Delhi</option><option value="64" >(GMT+05:30) Sri Jayawardenepura</option><option value="65" >(GMT+05:45) Kathmandu</option><option value="66" >(GMT+06:00) Almaty, Novosibirsk</option><option value="67" >(GMT+06:00) Astana, Dhaka</option><option value="68" >(GMT+06:30) Yangon (Rangoon)</option><option value="69" >(GMT+07:00) Bangkok, Hanoi, Jakarta</option><option value="70" >(GMT+07:00) Krasnoyarsk</option><option value="71" >(GMT+08:00) Beijing, Chongqing, Hong Kong, Urumqi</option><option value="72" >(GMT+08:00) Irkutsk, Ulaan Bataar</option><option value="73" >(GMT+08:00) Kuala Lumpur, Singapore</option><option value="74" >(GMT+08:00) Perth</option><option value="75" >(GMT+08:00) Taipei</option><option value="76" >(GMT+09:00) Osaka, Sapporo, Tokyo</option><option value="77" >(GMT+09:00) Seoul</option><option value="78" >(GMT+09:00) Yakutsk</option><option value="79" >(GMT+09:30) Adelaide</option><option value="80" >(GMT+09:30) Darwin</option><option value="81" >(GMT+10:00) Brisbane</option><option value="82" >(GMT+10:00) Canberra, Melbourne, Sydney</option><option value="83" >(GMT+10:00) Guam, Port Moresby</option><option value="84" >(GMT+10:00) Hobart</option><option value="85" >(GMT+10:00) Vladivostok</option><option value="86" >(GMT+11:00) Magadan, Solomon Is., New Caledonia</option><option value="87" >(GMT+12:00) Auckland, Wellington</option><option value="88" >(GMT+12:00) Fiji, Kamchatka, Marshall Is.</option><option value="89" >(GMT+13:00) Nuku'alofa</option></select>
<div id="divDstSetting" style="display:none;height:30px;margin-top:5px;" >
<span class="setvalue" ci="1" cicat="SYSTEM" ciname="TIME_ZONE_ENABLE_DST"><input id="cbEnableDST" type="checkbox" name="cbEnableDST" checked="checked" /><label for="cbEnableDST">Adjust clock for Daylight Saving Time.</label></span>
</div>
<div id="divDstSettingDisabled" style="display:none;height:30px;" >
<br />
</div>
</td>
</tr>
<td class="label"><label id="llbSysNtpServer" for="lbSysNtpServer">NTP Server</label></td>
<td class="field">
<select id="lbSysNtpServer" name="lbSysNtpServer" style="width:300px;" cicat='SYSTEM' ciname='NTP_SERVER' class='setvalue' ><option value="asia.pool.ntp.org" >asia.pool.ntp.org</option><option value="europe.pool.ntp.org" >europe.pool.ntp.org</option><option value="oceania.pool.ntp.org" >oceania.pool.ntp.org</option><option selected="selected" value="north-america.pool.ntp.org" >north-america.pool.ntp.org</option><option value="south-america.pool.ntp.org" >south-america.pool.ntp.org</option><option value="africa.pool.ntp.org" >africa.pool.ntp.org</option></select>
</td>
</tr>
<tr>
<td class="label"><label id="lblSysNtpSync" for="btnSysNtpSync"></label></td>
<td class="field">
<input id="btnNtpSync" style="display:none;" type='button' class='cancel btnNtpSync' onclick="return syncTime(this);" value=" Update time from NTP Server " />
<div id="divNtpSync" style="display:none;"><img src="content/images/indicator.gif" /> NTP Sync in progress</div>
</td>
</tr>
<td class="label"><label id="lblSysNuVoSync" for="cbNuVoSync"></label></td>
<td class="field"><span class="setvalue" ci="1" cicat="MRAD" ciname="SYNC_TIME"><input id="cbSyncBridge" type="checkbox" name="cbSyncBridge" checked="checked" /><label for="cbSyncBridge">Synchronize NuVo amplifier's clock.</label></span></td>
</tr>
</table>
</fieldset>
</div>
<div class="entry">
<fieldset id="ethernet"><legend>Wired Ethernet (00:27:0E:10:9E:CD)</legend>
<tr>
<td class="label"><label id="lethernetDhcp" for="ethernetDhcp">Connection</label></td>
<td class="field"><select id="ethernetDhcp" name="ethernetDhcp" style="width:300px;" cicat='ETHERNET' ciname='DHCP' class="setvalue">
<option value="true" selected="selected" >Automatic Configuration (DHCP) - 10.0.1.10</option>
<option value="false" >Manual Configuration (Static IP)</option>
</select></td>
</tr>
<tr class="wiredStaticIp">
<td class="label"><label id="ltbWiredEthIp" for="tbWiredEthIp">IP Address</label></td>
<td><input name="tbWiredEthIp" type="text" value="10.0.1.10" id="tbWiredEthIp" class="ipAddress setvalue" ci="1" cicat="ETHERNET" ciname="IP_ADDRESS" style="width:300px;" /></td>
</tr>
<td class="label"><label id="ltbWiredEthSubnet" for="tbWiredEthSubnet">Subnet Mask</label></td>
<td><input name="tbWiredEthSubnet" type="text" value="255.255.255.0" id="tbWiredEthSubnet" class="ipAddress setvalue" ci="1" cicat="ETHERNET" ciname="IP_SUBNET" style="width:300px;" /></td>
</tr>
<td class="label"><label id="ltbWiredEthGateway" for="tbWiredEthGateway">Gateway</label></td>
<td><input name="tbWiredEthGateway" type="text" value="10.0.1.1" id="tbWiredEthGateway" class="ipAddress setvalue" ci="1" cicat="ETHERNET" ciname="IP_GATEWAY" style="width:300px;" /></td>
</tr>
<td class="label"><label id="ltbWiredEthDns1" for="tbWiredEthDns1">DNS 1</label></td>
<td><input name="tbWiredEthDns1" type="text" value="75.75.75.75" id="tbWiredEthDns1" class="ipAddress setvalue" ci="1" cicat="ETHERNET" ciname="IP_DNS_1" style="width:300px;" /></td>
</tr>
<td class="label"><label id="ltbWiredEthDns2" for="tbWiredEthDns2">DNS 2</label></td>
<td><input name="tbWiredEthDns2" type="text" value="8.8.8.8" id="tbWiredEthDns2" class="ipAddress setvalue" ci="1" cicat="ETHERNET" ciname="IP_DNS_2" style="width:300px;" /></td>
</tr>
</table>
</fieldset>
</div>
<div class="entry">
<fieldset id="Fieldset1"><legend>Logging</legend>
<tr>
<td class="label"><label id="lbltbLogEmail" for="tbLogEmail">Your email</label></td>
<td><input name="tbLogEmail" type="text" id="tbLogEmail" class="setvalue" ci="1" cicat="LOGGING" ciname="FROM_EMAIL" style="width:300px;" /></td>
</tr>
<tr>
<td class="label"><label id="lbltbComments" for="tbComments">Comments</label></td>
<td><textarea name="tbComments" rows="2" cols="20" id="tbComments" class="setvalue" ci="1" cicat="LOGGING" ciname="COMMENTS" style="width:300px;height:100px"></textarea></td>
</tr>
<tr>
<td class="label"><label id="Label2" for="cbAdditionalData">Include media database</label></td>
<td><span class="setvalue" ci="1" cicat="LOGGING" ciname="INCLUDE_DATA"><input id="cbAdditionalData" type="checkbox" name="cbAdditionalData" /></span></td>
</tr>
<tr>
<td class="label"><label id="Label1" for="btnUploadLogFiles"></label></td>
<td class="field"><input type='button' class='cancel' onclick="return uploadLogFiles(this);" value=" Upload Log Files " /></td>
</tr>
</table>
</fieldset>
</div>
<div class="entry">
<fieldset id="Fieldset2"><legend>Utilities</legend>
<tr>
<td class="label"></td>
<td class="field" style="vertical-align:middle;cursor:pointer"><a href="#" id="btnReboot" onclick="return rebootServer(this);"><span style="font-size:larger;vertical-align:top">Restart your server</span></a></td>
</tr>
</table>
</fieldset>
</div>
</div>
</div>
<!-- end #content -->
<div id="sidebar">
<ul>
<li id='save'>
<h2>Save</h2>
<input type='submit' id='saveButton' name='save' value='Save Changes' class='cancel' style='width:200px' onclick="return emsAction('save', this);" />
<input type='submit' id='revertButton' name='revert' value='Undo Changes' class='cancel' style='width:200px' />
<div> </div>
</li>
<li>
<h2>Server Identification</h2>
<p>Name – this setting identifies this server on your network. </p>
<p>Description – enter a description and/or location for this server.</p>
</li>
<li>
<h2>Date and Time</h2>
<p>Time Zone – Enter your local time zone.</p>
<p>NTP Server – Select the internet time server closest to your location.</p>
<p>The <i>Synchronize Now</i> button will force your server to synchronize its clock with the time server.</p>
</li>
<li>
<h2>Wired Ethernet</h2>
<p><strong>Connection</strong>: Select the connection method for attaching to your wired network. If you choose to configure this setting manually, you will have to provide an unused IP address, subnet mask, gateway and DNS server address. If you are unsure of these settings, use the automatic (DHCP) setting, or contact your network administrator.</p>
</li>
<li>
<h2>Logging</h2>
<p>Use this section to upload log files when directed to do so by technical support.</p>
</li>
</ul>
</div>
<!-- end #sidebar -->
<div style="clear: both;"> </div>
<!-- end #page -->
</div>
<!-- Footer -->
<div id='footer'><p>© Copyright 2006-2015 <a href='http://www.Autonomic-Controls.com/'>Autonomic Controls, Inc.</a> All rights reserved.</p><p>Version 5.0.15934.4 Release.</p></div>
<!-- end #footer -->
</div>
</form>
<script type="text/javascript">
var g_callCount = 0;
var g_tickTimeOut=0;
var g_lastNtpSyncState = -1;
function timeZoneChanged(e) {
var selObj = $('#lbSysTimeZone')[0];
if (selObj == null)
return;
var selIndex = selObj.selectedIndex;
var selValue = selObj.options[selIndex].value;
post = $.ajax({
url: "sv.aspx",
data: "x=1&action=qdst&value="+selValue,
async: false,
cache: false
}).responseText;
if (post=="1") {
$("#divDstSetting").show();
$("#divDstSettingDisabled").hide();
else {
$("#divDstSetting").hide();
$("#divDstSettingDisabled").show();
timeZoneChanged(null);
function syncTime(ctrl) {
emsAction('ntpsync',ctrl);
$(".btnNtpSync").hide();
$("#divNtpSync").show();
if (g_tickTimeOut!=0)
clearTimeout(g_tickTimeOut);
g_tickTimeOut = setTimeout("getTime()", 5000);
return false;
function getTime() {
var post;
try
g_callCount++;
post = $.ajax({
url: "getstatus",
data: "x="+g_callCount,
async: false,
cache: false
}).responseText;
//$("#statusText").text( g_callCount+": " +post );
catch(e)
$("#divNtpSync").hide();
return;
try
eval(post);
catch(e)
return;
$("#timeString").text( status.timeStamp );
if (status.ntpsyncInProgress==0) {
$(".btnNtpSync").show();
else {
g_tickTimeOut = setTimeout("getTime()", 1000);
function uploadLogFiles(sender) {
if (echeck( $("#tbLogEmail").val() ) == false ) {
var dest = $("#tbLogEmail").parent("td").next("td");
dest.html("<label class='error'>Invalid email address</label>");
alert("Invalid email address");
$("#tbLogEmail").focus();
return false;
if ($("#tbComments").val() == '') {
var dest = $("#tbComments").parent("td").next("td");
dest.html("<label class='error'>Comments are required</label>");
alert("Comments are required");
$("#tbComments").focus();
return false;
//var x = prompt("Enter log file password provided by tech support:", "");
var rVal = emsAction('uploadLogFiles',sender);
$("#tbComments").val('');
return rVal;
function echeck(str) {
var at="@";
var dot=".";
var lat=str.indexOf(at);
var lstr=str.length;
var ldot=str.indexOf(dot);
if (str.indexOf(at)==-1){
return false;
if (str.indexOf(at)==-1 || str.indexOf(at)==0 || str.indexOf(at)==lstr){
return false;
if (str.indexOf(dot)==-1 || str.indexOf(dot)==0 || str.indexOf(dot)==lstr){
return false;
if (str.indexOf(at,(lat+1))!=-1){
return false;
if (str.substring(lat-1,lat)==dot || str.substring(lat+1,lat+2)==dot){
return false;
if (str.indexOf(dot,(lat+2))==-1){
return false;
if (str.indexOf(" ")!=-1){
return false;
return true;
function onDateSelected(e, selectedDate, $td, status) {
var value = (selectedDate.getMonth()+1)+'/'+selectedDate.getDate()+'/'+selectedDate.getYear();
var postData = "cat=SYSTEM&name=DATE&value="+value;
callAjax(postData);
function onTimeSelected(){
var value = $('#tbSysTime').val();
var postData = "cat=SYSTEM&name=TIME&value="+value;
callAjax(postData);
$('#tbSysName').alphanumeric({ allow: "-" });
$('#tbSysDescrip').alphanumeric({ allow: "- '" });
$('#cbEnableDST')
.bind('click', function(e) {
var value = $('#cbEnableDST')[0].checked ? 'True' : 'False';
setParamAjax(value, $('#cbEnableDST').parent()[0], null);
$('#cbSyncBridge')
var value = $('#cbSyncBridge')[0].checked ? 'True' : 'False';
setParamAjax(value, $('#cbSyncBridge').parent()[0], null);
$('.ipAddress')
.numeric({ allow: "." })
.css("text-align", "right");
$('.seconds')
.numeric()
$('#ethernetDhcp')
.bind('change', wiredConnectionTypeChanged);
function wiredConnectionTypeChanged(e) {
var selObj = $('#ethernetDhcp')[0];
if (selObj == null)
return;
if (selValue == "true")
$('.wiredStaticIp').hide();
else
$('.wiredStaticIp').show();
wiredConnectionTypeChanged(null);
$('#cbLogEnabled')
var value = $('#cbLogEnabled')[0].checked ? 'True' : 'False';
setParamAjax(value, $('#cbLogEnabled').parent()[0], null);
$('#cbAdditionalData')
var value = $('#cbAdditionalData')[0].checked ? 'True' : 'False';
setParamAjax(value, $('#cbAdditionalData').parent()[0], null);
function onScreenResolutionChange(rb)
var srcId = this.id.substr(10);
var postData = "spa=1"+"&cat=SYSTEM&name=SCREEN_RESOLUTION&value="+srcId;
var post = callAjax(postData);
checkPostResult(post);
function rebootServer(e) {
if(confirm('Are you sure you want to Restart your server ?')!=true)
return false;
var rVal = emsAction('reboot',e);
return rVal;
$(document).ready(function() {
initValidation(true);
initStatusRefreshMonitor();
if ($.browser.msie) {
$("#lbSysTimeZone").mousedown(function(){
$(this).css("width","auto");
$("#lbSysTimeZone").change(function(){
$(this).css("width","300px");
timeZoneChanged();
$("#lbSysTimeZone").blur(function(){
else {
timeZoneChanged();
$(".screenResolution").click( onScreenResolutionChange );
getTime();
</script>
</body>
</html>
