A little Indigo script ...
Tue Oct 27, 2015 7:51 pm
rlesperance offline
Hello,
I want to log by script to Indigo. In Indigo 5, I was able to do so. It doesn't work anymore. Can you help me to troubleshoot my little script ? Here it is:
property theTextToLog : ""
LogToIndigo("Test------------------------------------")
on LogToIndigo(theTextToLog)
      log theTextToLog
   end tell
end LogToIndigo
Wed Oct 28, 2015 5:03 am
Re: A little Indigo script ...
First off, I am not an Applescript expert :wink:
However, I have just run your script on an Indigo Client Mac and on my server.
When I execute your script on the Client - it runs and nothing happens e.g. no error but at the same time no message in the log.
If I run the script on the Server - I get the dreaded -600 error: Application isn't running.
What exactly are you seeing happen?
Wed Oct 28, 2015 7:00 am
rlesperance offline
Hi Jon ... Thanks for trying. I get an error -10810.
Wed Oct 28, 2015 9:22 am
If you're running it from the script editor, it should also give some textual description of the error.
[MODERATOR NOTE] moved to the AppleScript forum.
Wed Oct 28, 2015 9:26 am
A quick internet search revealed that this is likely that the Mac OS X process table is full. This can be alleviated by quitting some other applications.
Wed Oct 28, 2015 5:19 pm
rlesperance offline
Jay,
Your quick Google search revealed a process table problem ... but reading further, it concludes that it's not t a full process table problem. I have 32GB of RAM, so it's not a memory size problem neither.
I have to say that my "LogToIndigo" idler worked perfectly with Indigo 5. It stopped working with Indigo 6. I then stop using it. Now, I need it again. The Log function is included in IndigoServer's AppleScript library so I thought to give Indigo's forum a try. I understand that you are not an expert script designer, but since Indigo is scriptable, maybe someone out there can be of help.
Thanks for trying.
Robert
Wed Oct 28, 2015 5:23 pm
rlesperance offline
Hello autolog ... The Indigo client does not understand the Log command. Only IndigoServer can.
Thu Oct 29, 2015 7:44 am
Can you give a little more background - where are you trying to run this script from?
It might be possible to do what you want using Python - it might be less problematic and there will be more people who can help.
Also what version of OSX are you using?
Thu Oct 29, 2015 8:30 am
Regardless, the error you indicated above is from the process manager, which is not something Indigo can influence. The script as you wrote it should work fine - I can run it (when I'm not getting the well-known -600 error).
Thu Oct 29, 2015 10:30 am
What happens if you change this line:
to:
   tell application "YourHDName:Library:Application Support:Perceptive Automation:Indigo 6:IndigoServer.app"
where YourHDName is the name of your Mac's main hard drive?
Thu Oct 29, 2015 10:40 am
Hey, can someone who's experiencing the -600 error try Matt's suggestion above? I wonder if that might solve that problem as well...
Thu Oct 29, 2015 11:19 am
Still get the -600 error :(
Thu Oct 29, 2015 1:14 pm
Oh, well, was worth a try. I didn't actually expect it to work.
Fri Oct 30, 2015 4:41 am
rlesperance offline
Thanks all for trying ... I will try with MacScripter forum.
Users browsing this forum: No registered users and 20 guests
