[ANSWERED]: My Applescript no longer working with Yosemite
Thu Oct 30, 2014 8:56 pm
ryanbuckner offline
I have some simple Applescript that checks iCal for a specific event ("Guest" ) in order to set a mode for guests staying over at the house. It has worked for about a year, but recently stopped working after the upgrade to Yosemite. I receive an error: timeout waiting for server response for request ExecuteScriptSource, and the code doesn't execute properly.
Here's the code:
set {year:y, month:m, day:d} to current date
set str to (m as string) & " " & (d as string) & " " & (y as string)
set today to date str
set tomorrow to today + (60 * 60 * 24)
tell application "Calendar"
   tell calendar "My Home Calendar"
      set curr to every event whose start date is greater than or equal to today and start date is less than or equal to tomorrow
      delay 10
      if (count of items of curr) is greater than 0 then
         repeat with b in curr
            set a to summary of b
            if a is equal to "Guest" then
                  if value of variable guestMode is not equal to "true" then
                     set value of variable "guestMode" to "true"
                  else
                     log "Not setting guestMode again, repeat"
                  end if
               end tell
            else
                  set value of variable "guestMode" to "false"
                  log "Looks like no sleepover tonight!"
               end tell
            end if
         end repeat
      else
         end tell
      end if
   end tell
end tell
Sun Nov 02, 2014 5:20 pm
Re: My Applescript no longer working with Yosemite
Hi Ryan,
I wonder if it is just taking too long to execute. Try saving it into a script file (via the Script Editor application), then have Indigo execute the script file instead of having the script embedded in the action dialog. Indigo will then execute it in its own process, which will not have a time limit.
If that doesn't work, then you'll need to add some debug logging to the script or start commenting out sections of the script to narrow down the problem.
Mon Nov 03, 2014 7:04 am
DomoPat offline
Re: [ANSWERED]: My Applescript no longer working with Yosemi
I was surprised by your code because I remember how difficult it was for me to get results from ical, so i tried it in Script editor.
At first I had an error on the date format (may be because I use a French OS) so I had to do this change:
set today to current date
It worked, but on first run I get a window asking me 'to authorize script editor to access iCal database'. After that it runs well but very slow (even with removing of the delay 10).
May be that authorization request is blocking the execution ?
This is where I realized I do sort of the same thing in one if my scripts, to check if we are in school vacation time. I use iCalBuddy to makes things easier and wanted to see if it will work under Yosemite, and it does. And look how much more simple (and fast) the script is:
set LaString to (do shell script "/usr/local/bin/icalbuddy -nc -ic Famille eventsToday")
if LaString contains "Libéré" or LaString contains "Vacances" then
   set value of variable "VacancesScolaire" to "Oui"
   else
   set value of variable "VacancesScolaire" to "Non"
end if
iCalBuddy is a command lin,e utility with a lot of options to give you exactly the events of the iCal database that you need. It works so well I completely forgot about it !
Users browsing this forum: No registered users and 26 guests
