Small Script Probelm
Sun Jul 20, 2014 6:38 pm
jltnol offline
So I'm trying to consolidate multiple triggers with scripts when possible... and while I've had some success, this one has me stuck.
This one is triggered anytime there is a change in the status of the lock..
I want to keep track of the time of the last status change, and what the last status update was
The time part of this works fine, but the status part doesn't. Regardless of the state the lock (on or off), the script always puts "Un-Locked!" into the variable...
   set value of variable "LockTime" to (time string of (current date))
   if on state of device named "Front Door Lock" is "true" then
      set value of variable "FrontDoor" to "Locked!"
   else
      set value of variable "FrontDoor" to "Un-Locked!"
   end if
end tell
Do I need to do some kind of "get status", or does the "if on state..." line do the same thing?
Sun Jul 20, 2014 7:55 pm
Re: Small Script Probelm
on state returns an AppleScript boolean, so change the conditional to:
   if on state of device named "Front Door Lock" is true then
Sun Jul 20, 2014 9:27 pm
jltnol offline
Once again Thanks Matt..
All this tiny script lines help me use them in lots of different situations, and put bigger things together...
Cheers
Users browsing this forum: No registered users and 23 guests
