Adding variable to url and then run/open url
Wed Apr 09, 2014 4:14 am
haavarda offline
I am starting to try to migrate from vera to indigo. But in order to do so I have to take it in steps.
The thing I want to try is to move some of my rf equipment to indigo.
So I want to try to update a variable that is on the vera.
Here is my case.
I store values from my sensors in a variable in indigo.
Then I want to add this variable at the end of a url (VALUE) and run that url. Is this possible to do?
http://IP:3480/data_request?id=variable ... alue=VALUE
regards
Håvard
Wed Apr 09, 2014 4:22 pm
Re: Adding variable to url and then run/open url
Check this Python example in our Python scripting tutorial.
Thu Apr 10, 2014 3:34 am
haavarda offline
Hi thank you for your reply.
I am new to this, so please bear with me...
When I try the following I get an error when I try to run the script.
"embedded script: not a valid non-strig sequence or mapping object"
myVar = indigo.variables[1338124154]
import urllib, urllib2
urllib2.urlopen("http://10.0.1.222:3480/data_request?id=variableset&DeviceNum=67&serviceId=urn:upnp-org:serviceId:VContainer1&Variable=Variable1&Value=%s" % urllib.urlencode(myVar.value))
Can you see what is wrong with the script?
regards
Håvard
Thu Apr 10, 2014 7:51 am
My bad - you want to use quote_plus() rather than urlencode:
urllib2.urlopen("http://10.0.1.222:3480/data_request?id=variableset&DeviceNum=67&serviceId=urn:upnp-org:serviceId:VContainer1&Variable=Variable1&Value=%s" % urllib.quote_plus(myVar.value))
The point is that because variable values can contain any kind of value (spaces, etc.), if you're going to pass them on a URL line they need to be encoded.
Fri Apr 11, 2014 3:43 am
haavarda offline
Thank you for your help.
That did the trick. I can now do exactly what I was hoping for.
Håvard
Tue Apr 29, 2014 5:30 am
haavarda offline
Has been using this, and it is working good.
But I wonder if it is possible to turn it the other way around?
Can I set a variable in indigo by a http request?
thanks for your help so far.
regards
Håvard
Tue Apr 29, 2014 7:58 am
Bollar offline
This is documented in the Indigo help, but you might also find these real world examples helpful. I created them as I was trying to figure out how it all works: viewtopic.php?f=107&t=11386
Tue Apr 29, 2014 9:51 am
haavarda offline
I found an example I could use. I can now do exactly what I wanted to do.
Thanks for your input.
Regards
Håvard
Users browsing this forum: No registered users and 19 guests
