The attached applescript tests the ethernet with a ping to 3 different devices once per minute.
If all 3 devices do not answer the ethernet interfaces on the MAC (both en0 and en1) get reset.
After a reset everything seems to work fine.
This is just FYI if someone has a similar problem
in applescript editor export this script as app with option "stay open after run handler" then add to login item
- Code: Select all
-- Karl Wachs
-- Dec 31 2013
-- version 1.0
-- please use as you see fit
-- ========> reset both ethernet interfaces if no responses from routers ..
-- test 3 hubs once a minute, if ONE answers ethernet is ok, testagain in 1 minute
-- save as "app" with option "stay open after run handler"
-- set no icon option in package plist if you like
-- add to login auto launch
-- this app will listen to quit command
-- ping .. grep will return: "2 packets transmitted, 0 packets received, 100.0% packet loss" if no response ... look for "0 packets" to detect failure
-- ping .. grep will return: "1 packets transmitted, 1 packets received, 0.0% packet loss" if successful
--reseting is essentially done by (for en0):
-- ifconfig en0 down
-- ifconfig en0 up
-- plus sudo, piping password and suppressing output to make it work in a script
on run
global theIP1
global theIP2
global theIP3
global thePassword
global ethernetInterface1
global ethernetInterface2
set theIP1 to "192.168.1.6" -- this is the router IP .......... put the IP numbers of devices to be tested here
set theIP2 to "192.168.1.7" -- this is the wifi hub 1
set theIP3 to "192.168.1.8" -- this is the wifi hub 2
set ethernetInterface1 to "en1" -- this is the "short name" of ethernet interface adopt to your environment
set ethernetInterface2 to "en0" -- ...
set thePassword to "your password goes here"
idle 60 -- send to idle immediately
end run
on idle
global theIP1
global theIP2
global theIP3
global thePassword
try
set outputByPing to do shell script "ping -o -t 2 -c 2 " & theIP1 & " 2>/dev/null | grep received " -- test router connection, reduce output, 2 sec wait, 2 pings, dump error messages
end try
if outputByPing contains "0 packets" then -- 0 packets received, test next hub
try
set outputByPing to do shell script "ping -o -t 2 -c 2 " & theIP2 & " 2>/dev/null | grep received " -- test wifi hub 1 connection, reduce output, 2 sec wait, 2 pings, dump error messages
end try
try
set outputByPing to do shell script "ping -o -t 2 -c 2 " & theIP3 & " 2>/dev/null | grep received " -- test wifi hub 2 connection, reduce output, 2 sec wait, 2 pings, dump error messages
end try
if outputByPing contains "0 packets" then -- 0 packets received by all 3 devices, reset both ethernets
-- reset interface en1
do shell script " echo '" & thePassword & "' | sudo -S ifconfig " & ethernetInterface1 & " down 2>&1 &" -- stop interface: pip in password , options: dont wait, dump output messages
do shell script " echo '" & thePassword & "' | sudo -S ifconfig " & ethernetInterface1 & " up 2>&1 &" -- start interface: pip in password, options: dont wait, dump output messages
delay 1 -- let it settle
-- reset interface en0
do shell script " echo '" & thePassword & "' | sudo -S ifconfig " & ethernetInterface2 & " down 2>&1 &" -- stop interface: pip in password , options: dont wait, dump output messages
do shell script " echo '" & thePassword & "' | sudo -S ifconfig " & ethernetInterface2 & " up 2>&1 &" -- start interface: pip in password, options: dont wait, dump output messages
end if
end if
end if
return 60 -- test again in 60 seconds
end idle
on quit
continue quit
return
end quit
