Not sure if this is an Indigo problem per se, but I decided to mention here in case it is. I use Indigo with a bunch of plugins to interact with my Sqeezebox and Concerto music server. One of the plugins is the iTunes plugin. Since I upgraded to Mavericks, iTunes seams to randomly crash about once a day while running in the background, and I have been assuming this was a Mavericks issue not related to Indigo. However, it occurred to me as I aaas looking at Activity Monitor, that besides com.Apple.MediaLibraryService and kernel_task, IndigoPluginHost is also running at or near 100% CPU much of the time. While Indigo does poll my Concerto every 30 seconds by looking at the serial port, it should not be doing anything that is memory or CPU intensive with iTunes. I am using the latest 6.0.5 Indigo version. I attached my activity log as I write this message. Below is the iTunes crash report from earlier today, along with my posting on the Apple Discussion board.
I am having similar problems with iTunes crashing. Been happening since I installed Mavericks. Have scrubbed my system to remove old software but still the daily crashes. I am seculating that the crash occurs while my iPhone gets backed up, but certainly cannot prove as the backup is a background event so I am not sure. iTunes runs in the background on my system so I do nto know specifically what it does when it crashes. I will make a few observations and post my log, but would love to know the cause or the fix.
My system is a mid 2011 iMac 27", 16 GB memory, 3.4 GHz i7
2) music, movie and TV show files run on a serparate server (10.6.8, mac mini, not crashing)
3) 3 linked Apple TV (version 1), 2 Apple TV version 3 on network that use iTunes with home sharing, 1 linked iPhone, 1 linked iPad (iPad barely used)
4) On start-up, iTunes stalls while syncing with one of my Apple TV 1 units.. I ususally manually terminate this sync - iTunes crash happen 10-20 hours later so I doubt related
5) Looking at activity monitor, two notable things stand out: (a) com.apple,MidiaLibraryService seems to guzzle CPU frequently over 100%; and (b) kernel_task also guzzles CPU over 100% frequently with 104 threads
1)
- Code: Select all
Process: iTunes [2208]
Path: /Applications/iTunes.app/Contents/MacOS/iTunes
Identifier: com.apple.iTunes
Version: 11.1.3 (11.1.3)
Build Info: iTunes-1113011001003008~1
Code Type: X86-64 (Native)
Parent Process: launchd [233]
Responsible: iTunes [2208]
User ID: 501
Date/Time: 2013-11-20 07:06:00.318 -0500
OS Version: Mac OS X 10.9 (13A603)
Report Version: 11
Anonymous UUID: F7624C68-6EFA-CBB1-E5E1-71462752F157
Crashed Thread: 1 Dispatch queue: com.apple.libdispatch-manager
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0xffffffffffffffff
VM Regions Near 0xffffffffffffffff:
--> shared memory 00007ffffff3e000-00007ffffff3f000 [ 4K] r-x/r-x SM=SHM
Thread 0:: iTunes main Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff89f9fa1a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff89f9ed18 mach_msg + 64
2 com.apple.CoreFoundation 0x00007fff8d876315 __CFRunLoopServiceMachPort + 181
3 com.apple.CoreFoundation 0x00007fff8d875939 __CFRunLoopRun + 1161
4 com.apple.CoreFoundation 0x00007fff8d875275 CFRunLoopRunSpecific + 309
5 com.apple.HIToolbox 0x00007fff8f36df0d RunCurrentEventLoopInMode + 226
6 com.apple.HIToolbox 0x00007fff8f36dcb7 ReceiveNextEventCommon + 479
7 com.apple.HIToolbox 0x00007fff8f36dabc _BlockUntilNextEventMatchingListInModeWithFilter + 65
8 com.apple.AppKit 0x00007fff9034d28e _DPSNextEvent + 1434
9 com.apple.AppKit 0x00007fff9034c8db -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 122
10 com.apple.AppKit 0x00007fff903409cc -[NSApplication run] + 553
11 com.apple.iTunes 0x00000001014acc57 0x100b9f000 + 9493591
12 com.apple.iTunes 0x0000000100f2fd4c 0x100b9f000 + 3738956
Thread 1 Crashed:: Dispatch queue: com.apple.libdispatch-manager
0 libdispatch.dylib 0x00007fff955eb54b _dispatch_mach_notify_dead_name + 138
1 libdispatch.dylib 0x00007fff955eb4a4 _Xmach_notify_dead_name + 48
2 libdispatch.dylib 0x00007fff955e8723 libdispatch_internal_protocol_server + 79
3 libdispatch.dylib 0x00007fff955e8674 _dispatch_mach_notify_source_invoke + 21
4 libdispatch.dylib 0x00007fff955e7fd4 _dispatch_kevent_mach_msg_recv + 306
5 libdispatch.dylib 0x00007fff955e537f _dispatch_mgr_invoke + 49
6 libdispatch.dylib 0x00007fff955e5152 _dispatch_mgr_thread + 52
Thread 2:: Dispatch queue: com.apple.root.default-priority
5 com.apple.CoreFoundation 0x00007fff8d92a9d1 CFRunLoopRun + 97
6 com.apple.mobiledevice 0x0000000108900701 __thr_AMRegisterForCallbacks + 217
7 libdispatch.dylib 0x00007fff955e32ad _dispatch_client_callout + 8
8 libdispatch.dylib 0x00007fff955e509e _dispatch_root_queue_drain + 326
9 libdispatch.dylib 0x00007fff955e6193 _dispatch_worker_thread2 + 40
10 libsystem_pthread.dylib 0x00007fff8c690ef8 _pthread_wqthread + 314
11 libsystem_pthread.dylib 0x00007fff8c693fb9 start_wqthread + 13
Thread 3:
6 com.apple.iTunes 0x0000000100bba51f 0x100b9f000 + 111903
7 com.apple.iTunes 0x0000000100ba40f3 0x100b9f000 + 20723
8 libsystem_pthread.dylib 0x00007fff8c68f899 _pthread_body + 138
9 libsystem_pthread.dylib 0x00007fff8c68f72a _pthread_start + 137
10 libsystem_pthread.dylib 0x00007fff8c693fc9 thread_start + 13
Thread 4:
0 libsystem_kernel.dylib 0x00007fff89fa3716 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff8c691c3b _pthread_cond_wait + 727
2 com.apple.iTunes 0x0000000100ba340f 0x100b9f000 + 17423
3 com.apple.iTunes 0x000000010102104b 0x100b9f000 + 4726859
4 com.apple.iTunes 0x000000010102177a 0x100b9f000 + 4728698
5 com.apple.iTunes 0x0000000100ba40f3 0x100b9f000 + 20723
6 libsystem_pthread.dylib 0x00007fff8c68f899 _pthread_body + 138
7 libsystem_pthread.dylib 0x00007fff8c68f72a _pthread_start + 137
8 libsystem_pthread.dylib 0x00007fff8c693fc9 thread_start + 13
Thread 5:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff89fa39aa __select + 10
1 com.apple.CoreFoundation 0x00007fff8d8c1d43 __CFSocketManager + 867
2 libsystem_pthread.dylib 0x00007fff8c68f899 _pthread_body + 138
3 libsystem_pthread.dylib 0x00007fff8c68f72a _pthread_start + 137
4 libsystem_pthread.dylib 0x00007fff8c693fc9 thread_start + 13
Thread 6:
6 com.apple.iTunes 0x00000001010d1694 0x100b9f000 + 5449364
Thread 7:
3 com.apple.iTunes 0x0000000100ba3369 0x100b9f000 + 17257
4 com.apple.iTunes 0x0000000100e13cf2 0x100b9f000 + 2575602
5 com.apple.iTunes 0x0000000100e13cc9 0x100b9f000 + 2575561
6 com.apple.iTunes 0x0000000100ba40f3 0x100b9f000 + 20723
7 libsystem_pthread.dylib 0x00007fff8c68f899 _pthread_body + 138
8 libsystem_pthread.dylib 0x00007fff8c68f72a _pthread_start + 137
9 libsystem_pthread.dylib 0x00007fff8c693fc9 thread_start + 13
Thread 8:
2 com.apple.iTunes 0x0000000100ba34c7 0x100b9f000 + 17607
3 libsystem_pthread.dylib 0x00007fff8c68f899 _pthread_body + 138
4 libsystem_pthread.dylib 0x00007fff8c68f72a _pthread_start + 137
5 libsystem_pthread.dylib 0x00007fff8c693fc9 thread_start + 13
Thread 9:
0 libsystem_kernel.dylib 0x00007fff89fa2e02 __accept + 10
1 com.apple.iTunes 0x00000001017e3c81 0x100b9f000 + 12864641
2 com.apple.iTunes 0x00000001017caecf 0x100b9f000 + 12762831
3 com.apple.iTunes 0x00000001017cae12 0x100b9f000 + 12762642
4 com.apple.iTunes 0x0000000100ba40f3 0x100b9f000 + 20723
5 libsystem_pthread.dylib 0x00007fff8c68f899 _pthread_body + 138
6 libsystem_pthread.dylib 0x00007fff8c68f72a _pthread_start + 137
7 libsystem_pthread.dylib 0x00007fff8c693fc9 thread_start + 13
Thread 10:
Thread 11:
Thread 12:
Thread 13:: com.apple.NSURLConnectionLoader
5 com.apple.Foundation 0x00007fff8c04f907 +[NSURLConnection(Loader) _resourceLoadLoop:] + 348
6 com.apple.Foundation 0x00007fff8c04f70b __NSThread__main__ + 1318
Thread 14:
5 com.apple.AppKit 0x00007fff904ed1ce _NSEventThread + 144
Thread 15:
Thread 16:
Thread 17:
Thread 18:
1 libsystem_pthread.dylib 0x00007fff8c691c77 _pthread_cond_wait + 787
2 com.apple.iTunes 0x0000000100ba344c 0x100b9f000 + 17484
3 com.apple.iTunes 0x0000000100c25983 0x100b9f000 + 551299
4 com.apple.iTunes 0x0000000100c25921 0x100b9f000 + 551201
5 com.apple.iTunes 0x0000000100c2578e 0x100b9f000 + 550798
Thread 19:
1 com.apple.AirTrafficHost 0x000000010d1a70de _readDictionary + 246
2 com.apple.AirTrafficHost 0x000000010d1a7892 ATProcessLinkCopyMessageFromChild + 182
3 com.apple.AirTrafficHost 0x000000010d1a663a ATHostConnectionReadMessage + 82
4 com.apple.iTunes 0x0000000100f716a3 0x100b9f000 + 4007587
Thread 20:
Thread 21:
Thread 22:
Thread 1 crashed with X86 Thread State (64-bit):
rax: 0x000061848fa65a40 rbx: 0xffffffffffffffff rcx: 0x0000618001283ca0 rdx: 0x0000000000000000
rdi: 0x000000000000fde3 rsi: 0x00000000ffffffee rbp: 0x0000000102fde520 rsp: 0x0000000102fde4c0
r8: 0x0000000000000001 r9: 0x0000000000000000 r10: 0x0000000102fde5e0 r11: 0x0000000000000246
r12: 0x0000618001283ca0 r13: 0x0000000000000000 r14: 0x000000000000fde3 r15: 0x0000000102fde4c8
rip: 0x00007fff955eb54b rfl: 0x0000000000010202 cr2: 0xffffffffffffffff
Logical CPU: 0
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x100b9f000 - 0x102241fef com.apple.iTunes (11.1.3 - 11.1.3) <A2A98806-87A0-3DC1-9B56-49D082615D15> /Applications/iTunes.app/Contents/MacOS/iTunes
0x102619000 - 0x102699ff7 com.apple.iTunes.iPodUpdater (10.7 - 10.7) <6DF8BE48-75E5-36DE-AD39-59B0B5A57E0F> /Applications/iTunes.app/Contents/Frameworks/iPodUpdater.framework/Versions/A/iPodUpdater
0x1026da000 - 0x102704ffb com.apple.avfoundationcf (2.0 - 133) <385B4AC1-12A3-3ECC-98CD-31D391FCCEFE> /System/Library/PrivateFrameworks/AVFoundationCF.framework/Versions/A/AVFoundationCF
0x10273e000 - 0x102912fff com.apple.iad.iAdCore (1.0 - 1) <0AC49774-2E81-31D7-B2BA-F272E16FD430> /Applications/iTunes.app/Contents/Frameworks/iAdCore.framework/Versions/A/iAdCore
0x1029e1000 - 0x1029e5fff com.apple.agl (3.2.3 - AGL-3.2.3) <1B85306F-D2BF-3FE3-9915-165237B491EB> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x1029f0000 - 0x1029f3fff com.apple.iPod (1.7 - 20) <9B9FD104-A8EE-3884-8610-B06700AC344E> /System/Library/PrivateFrameworks/iPod.framework/Versions/A/iPod
0x1029fa000 - 0x102d26ff7 +libgnsdk_dsp.1.9.5.dylib (1.9.5) <14636B08-4D26-54CA-3EE8-247B2B708AF0> /Applications/iTunes.app/Contents/MacOS/libgnsdk_dsp.1.9.5.dylib
0x102d50000 - 0x102d87ff7 +libgnsdk_musicid.1.9.5.dylib (1.9.5) <C034C2ED-6A46-315F-89C8-8D54A937B255> /Applications/iTunes.app/Contents/MacOS/libgnsdk_musicid.1.9.5.dylib
0x102d9b000 - 0x102e71fe7 +libgnsdk_sdkmanager.1.9.5.dylib (1.9.5) <D144E870-FABC-E19E-452E-A33D19595B19> /Applications/iTunes.app/Contents/MacOS/libgnsdk_sdkmanager.1.9.5.dylib
0x102e96000 - 0x102ed9ff7 +libgnsdk_submit.1.9.5.dylib (1.9.5) <6689251D-098B-0F8D-08CC-785271E98540> /Applications/iTunes.app/Contents/MacOS/libgnsdk_submit.1.9.5.dylib
0x1030a4000 - 0x1030a6ff7 com.apple.textencoding.unicode (2.6 - 2.6) <0EEF0283-1ACA-3147-89B4-B4E014BFEC52> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x1036b4000 - 0x1036b8ffd com.apple.audio.AppleHDAHALPlugIn (2.5.2 - 2.5.2fc2) <DEB558B7-BACF-3871-A021-B3A904F4FB44> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x1036bd000 - 0x1036c4fff com.apple.URLMount.AFPPlugin (6.0 - 6.0) <3F14475B-992E-311F-8314-7CFA8908227A> /System/Library/Filesystems/NetFSPlugins/afp.bundle/Contents/MacOS/afp
0x1037ee000 - 0x1037fdfff +com.shepmater.A52Codec (1.8.0 - 1.8.0) <E3FD6232-50DD-3C0F-FC8E-9A4FCBCFF13B> /Library/Audio/Plug-Ins/Components/A52Codec.component/Contents/MacOS/A52Codec
0x10516b000 - 0x105ee0fff com.apple.CoreFP (2.5.16 - 2.5.16) <1C390A93-4187-37E7-8A7E-4417876F069B> /System/Library/PrivateFrameworks/CoreFP.framework/CoreFP
0x107446000 - 0x107485ff7 com.apple.AppleShareClientCore (4.0 - 3.0) <C8CF9884-B092-348E-BCCD-2821FDB7B517> /System/Library/Frameworks/AppleShareClientCore.framework/Versions/A/AppleShareClientCore
0x10749a000 - 0x10749dff7 com.apple.iokit.SCSITaskLib (3.6.0 - 3.6.0) <7DE59064-BD1D-33A2-A72F-B98D9D83E711> /System/Library/Extensions/IOSCSIArchitectureModelFamily.kext/Contents/PlugIns/SCSITaskUserClient.kext/Contents/PlugIns/SCSITaskLib.plugin/Contents/MacOS/SCSITaskLib
0x1074b9000 - 0x1074bcff7 com.apple.QuartzComposer.iTunesPlugIn (1.4 - 18) <08330444-D369-3B4F-AE16-8E48F771CEEB> /Library/iTunes/iTunes Plug-ins/Quartz Composer Visualizer.bundle/Contents/MacOS/Quartz Composer Visualizer
0x1074c9000 - 0x1075fdff7 com.apple.CoreADI (1.34.0 - 1.34.0) <33B6ECA7-680E-3517-A1C1-9785BA022516> /System/Library/PrivateFrameworks/CoreADI.framework/CoreADI
0x108600000 - 0x1087d1fff com.apple.audio.units.Components (1.9 - 1.9) <80991B19-4B07-3DBF-A4B3-597DA1AA65B2> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x10887b000 - 0x10896cff7 com.apple.mobiledevice (710.1 - 710.1) <356F402B-7499-3EA6-8541-A3D89F6D119F> /System/Library/PrivateFrameworks/MobileDevice.framework/MobileDevice
0x108a54000 - 0x108c4afff com.apple.audio.codecs.Components (4.0 - 4.0) <05EF9EE8-2047-3FB0-84DA-7A2DD744B64B> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
0x109068000 - 0x10906eff7 com.apple.BookKit (1.0.1 - 158) <34C7F87F-63B6-3E53-A7B1-8A6656405F41> /System/Library/PrivateFrameworks/BookKit.framework/BookKit
0x10b119000 - 0x10b123ff7 AppleIntelSNBVA (8.18.27) <34FF10F3-27DF-3AAA-A3A9-C2A144118F53> /System/Library/Extensions/AppleIntelSNBVA.bundle/Contents/MacOS/AppleIntelSNBVA
0x10cd33000 - 0x10cd46fff com.apple.MediaLibrary (1.0 - 637) <CB99F701-D188-34A1-A53B-0331A352C8A3> /System/Library/Frameworks/MediaLibrary.framework/MediaLibrary
0x10d1a4000 - 0x10d325fff com.apple.AirTrafficHost (351 - 351) <0453A5B3-8F63-3CEF-AEAF-6D705970B244> /System/Library/PrivateFrameworks/AirTrafficHost.framework/AirTrafficHost
0x10d9d9000 - 0x10da84fff com.apple.AppleGVAFramework (6.0.38 - 6.0.38) <778BD26C-91E5-3300-B78E-917CE26317E7> /System/Library/PrivateFrameworks/AppleGVA.framework/AppleGVA
0x112e78000 - 0x112ebeff7 com.apple. AMDRadeonVADriver (1.14.21 - 1.1.4) <92A985B1-7A39-3CAD-B438-F47FCB71421C> /System/Library/Extensions/AMDRadeonVADriver.bundle/Contents/MacOS/AMDRadeonVADriver
0x122998000 - 0x122a8fff7 com.apple.AppleIntelHD3000GraphicsVADriver (8.18.27 - 8.1.8) <868D08A0-A9AF-3DD5-BF39-6441A889B67E> /System/Library/Extensions/AppleIntelHD3000GraphicsVADriver.bundle/Contents/MacOS/AppleIntelHD3000GraphicsVADriver
0x122ad0000 - 0x122d4dfff com.apple.CoreKE (1.7.0 - 1.7.0) <596CAF69-A1EA-33D6-9D2E-805DA761D3D8> /System/Library/PrivateFrameworks/CoreKE.framework/CoreKE
0x123480000000 - 0x123480294ff7 com.apple.AMDRadeonX3000GLDriver (1.14.21 - 1.1.4) <3133F944-09A8-3B30-B8B0-1C68FC2119F2> /System/Library/Extensions/AMDRadeonX3000GLDriver.bundle/Contents/MacOS/AMDRadeonX3000GLDriver
0x7fff66fd2000 - 0x7fff67005817 dyld (239.3) <D1DFCF3F-0B0C-332A-BCC0-87A851B570FF> /usr/lib/dyld
0x7fff898df000 - 0x7fff898ebff7 com.apple.OpenDirectory (10.9 - 173.1.1) <6B78BD7B-5622-38E6-8FC6-86A117E3ACCA> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff898ec000 - 0x7fff89a79ff7 GLEngine (9.0.83) <26CCE609-D645-3945-A678-517ED5B65785> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff89a7a000 - 0x7fff89adeff9 com.apple.Heimdal (4.0 - 2.0) <E7D20A4D-4674-37E1-A949-635FFF7C439A> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff89b07000 - 0x7fff89b07fff com.apple.Accelerate.vecLib (3.9 - vecLib 3.9) <F8D0CC77-98AC-3B58-9FE6-0C25421827B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff89b08000 - 0x7fff89b14ff7 com.apple.KerberosHelper (4.0 - 1.0) <6D64703B-D7A3-3EF7-89AB-16F7F89333FC> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
0x7fff89b78000 - 0x7fff89c07ff7 com.apple.Metadata (10.7.0 - 800.12) <04486C95-3E49-36C4-89B6-925E925BB417> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff89c08000 - 0x7fff89c35ff2 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <43A137C4-3E72-37DC-945F-92569C12AAD4> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff89c36000 - 0x7fff89cfffff com.apple.LaunchServices (572.23 - 572.23) <8D955BDE-2C4C-3DD4-B4D7-2D916174FE1D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff89d00000 - 0x7fff89ddffff libcrypto.0.9.8.dylib (50) <B95B9DBA-39D3-3EEF-AF43-44608B28894E> /usr/lib/libcrypto.0.9.8.dylib
0x7fff89e67000 - 0x7fff89f38ff1 com.apple.DiskImagesFramework (10.9 - 371.1) <D456ED08-4C1D-341F-BAB8-85E34A7275C5> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff89f8e000 - 0x7fff89faaff7 libsystem_kernel.dylib (2422.1.72) <D14913DB-47F1-3591-8DAF-D4B4EF5F8818> /usr/lib/system/libsystem_kernel.dylib
0x7fff89fab000 - 0x7fff8a1f3fff com.apple.CoreData (107 - 481) <E5AFBA07-F73E-3B3F-9099-F51224EE8EAD> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff8a1f6000 - 0x7fff8a200ff7 libcsfde.dylib (380) <3A54B430-EC05-3DE9-86C3-00C1BEAC7F9B> /usr/lib/libcsfde.dylib
0x7fff8a201000 - 0x7fff8a489ff7 com.apple.CommerceKit (1.2.0 - 232) <442AE798-E07F-3E68-BB80-4C41B61408E3> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/CommerceKit
0x7fff8a48a000 - 0x7fff8a48bff7 libDiagnosticMessagesClient.dylib (100) <4CDB0F7B-C0AF-3424-BC39-495696F0DB1E> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff8a48c000 - 0x7fff8a54fff7 com.apple.backup.framework (1.5 - 1.5) <92C8038F-CC00-3202-90D8-3C3AEC90986F> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff8a550000 - 0x7fff8a55efff com.apple.CommerceCore (1.0 - 42) <ACC2CE3A-913A-39E0-8344-B76F8F694EF5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x7fff8a55f000 - 0x7fff8a587ffb libRIP.A.dylib (599.7) <6F528EE3-99F8-3871-BD60-1306495C27D5> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff8a588000 - 0x7fff8a5b2ff7 libpcap.A.dylib (42) <91D3FF51-D6FE-3C05-98C9-1182E0EC3D58> /usr/lib/libpcap.A.dylib
0x7fff8a5d2000 - 0x7fff8a5d5fff libCoreVMClient.dylib (58.1) <EBC36C69-C896-3C3D-8589-3E9023E7E56F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff8a5d6000 - 0x7fff8a617fff com.apple.PerformanceAnalysis (1.47 - 47) <784ED7B8-FAE4-36CE-8C76-B7D300316C9F> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff8a6d2000 - 0x7fff8a702fff com.apple.IconServices (25 - 25.17) <4751127E-FBD5-3ED5-8510-08D4E4166EFE> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff8a75b000 - 0x7fff8a75dfff libCVMSPluginSupport.dylib (9.0.83) <E2AED858-6EEB-36C6-8C06-C3CF649A3CD5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff8a75e000 - 0x7fff8a761fff com.apple.AppleSystemInfo (3.0 - 3.0) <4D032152-AA40-350E-BB96-44BC55C5C69C> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff8a762000 - 0x7fff8ab95ffb com.apple.vision.FaceCore (3.0.0 - 3.0.0) <F42BFC9C-0B16-35EF-9A07-91B7FDAB7FC5> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff8ac01000 - 0x7fff8ac97fff com.apple.PackageKit (3.0 - 329) <F619E170-BE26-37E8-8F6E-C74D68522083> /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/PackageKit
0x7fff8acbd000 - 0x7fff8acd8ff7 libPng.dylib (1038) <EF781AF8-C2E6-3179-B8A1-A584783070F1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff8acd9000 - 0x7fff8ace6ff0 libbz2.1.0.dylib (29) <0B98AC35-B138-349C-8063-2B987A75D24C> /usr/lib/libbz2.1.0.dylib
0x7fff8ace7000 - 0x7fff8acf0ffb libCGInterfaces.dylib (271) <68EFBEFE-7506-3235-99A2-5B69EDBFD7B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Resources/libCGInterfaces.dylib
0x7fff8acf1000 - 0x7fff8acf6fff libmacho.dylib (845) <1D2910DF-C036-3A82-A3FD-44FF73B5FF9B> /usr/lib/system/libmacho.dylib
0x7fff8acf7000 - 0x7fff8ad31ff3 com.apple.bom (12.0 - 192) <989690DB-B9CC-3DB5-89AE-B5D33EDC474E> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff8ad32000 - 0x7fff8ad34ff7 com.apple.securityhi (9.0 - 55005) <405E2BC6-2B6F-3B6B-B48E-2FD39214F052> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff8ad35000 - 0x7fff8ad3cfff com.apple.NetFS (6.0 - 4.0) <8E26C099-CE9D-3819-91A2-64EA929C6137> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff8ad86000 - 0x7fff8adcdfff libFontRegistry.dylib (127) <A77A0480-AA5D-3CC8-8B68-69985CD546DC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff8adce000 - 0x7fff8ae21fff com.apple.ScalableUserInterface (1.0 - 1) <CF745298-7373-38D2-B3B1-727D5A569E48> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x7fff8ae22000 - 0x7fff8ae25ff7 com.apple.LoginUICore (3.0 - 3.0) <1ECBDA90-D6ED-3333-83EB-9C8232DFAD7C> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fff8ae7a000 - 0x7fff8aea9fff com.apple.DebugSymbols (106 - 106) <E1BDED08-523A-36F4-B2DA-9D5C712F0AC7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff8aeaa000 - 0x7fff8aeb6ff3 com.apple.AppleFSCompression (56 - 1.0) <5652B0D0-EB08-381F-B23A-6DCF96991FB5> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff8af02000 - 0x7fff8b2e3ffe libLAPACK.dylib (1094.5) <7E7A9B8D-1638-3914-BAE0-663B69865986> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff8b2e4000 - 0x7fff8b370ff7 com.apple.ink.framework (10.9 - 207) <8A50B893-AD03-3826-8555-A54FEAF08F47> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff8b371000 - 0x7fff8b39afff GLRendererFloat (9.0.83) <1F1160A8-5047-3CEE-AC1E-D29520D0B367> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff8b39b000 - 0x7fff8b3a3ffc libGFXShared.dylib (9.0.83) <11A621C3-37A0-39CE-A69B-8739021BD79D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff8b3a4000 - 0x7fff8b3a6fff com.apple.EFILogin (2.0 - 2) <C360E8AF-E9BB-3BBA-9DF0-57A92CEF00D4> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff8b3a7000 - 0x7fff8b3b2ff7 com.apple.NetAuth (5.0 - 5.0) <C811E662-9EC3-3B74-808A-A75D624F326B> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff8b3b3000 - 0x7fff8b3bcff3 libsystem_notify.dylib (121) <52571EC3-6894-37E4-946E-064B021ED44E> /usr/lib/system/libsystem_notify.dylib
0x7fff8b3bd000 - 0x7fff8b4dfff1 com.apple.avfoundation (2.0 - 651.12) <03E595B7-A559-3D4D-90E9-BCA603E3A39E> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff8b518000 - 0x7fff8b5a1ff7 libsystem_c.dylib (997.1.1) <61833FAA-7281-3FF9-937F-686B6F20427C> /usr/lib/system/libsystem_c.dylib
0x7fff8b5a2000 - 0x7fff8b918ffa com.apple.JavaScriptCore (9537 - 9537.65) <7E76880C-832E-385B-9591-ACCF57A68385> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff8b919000 - 0x7fff8b971ff7 com.apple.Symbolication (1.4 - 129) <16D42516-7B5E-357C-898A-FAA9EE7642B3> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff8b972000 - 0x7fff8b979ff7 liblaunch.dylib (842.1.4) <FCBF0A02-0B06-3F97-9248-5062A9DEB32C> /usr/lib/system/liblaunch.dylib
0x7fff8b97a000 - 0x7fff8b97afff com.apple.Cocoa (6.8 - 20) <E90E99D7-A425-3301-A025-D9E0CD11918E> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff8b97b000 - 0x7fff8ba46fff libvDSP.dylib (423.32) <3BF732BE-DDE0-38EB-8C54-E4E3C64F77A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff8ba47000 - 0x7fff8ba59fff com.apple.ImageCapture (9.0 - 9.0) <BE0B65DA-3031-359B-8BBA-B9803D4ADBF4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff8ba5a000 - 0x7fff8bab3fff libTIFF.dylib (1038) <5CBFE0C2-9DD8-340B-BA63-A94CE2E476F2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff8bab4000 - 0x7fff8babcfff libMatch.1.dylib (19) <021293AB-407D-309A-87F5-8E782F46753E> /usr/lib/libMatch.1.dylib
0x7fff8bae5000 - 0x7fff8bb80ff7 com.apple.PDFKit (2.9 - 2.9) <AD968A31-6567-30A7-A699-154C88DB56D0> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff8bb81000 - 0x7fff8bb93ff7 com.apple.MultitouchSupport.framework (245.13 - 245.13) <D5E7416D-45AB-3690-86C6-CC4B5FCEA2D2> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff8bb94000 - 0x7fff8bbadff7 com.apple.Ubiquity (1.3 - 289) <C7F1B734-CE81-334D-BE41-8B20D95A1F9B> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x7fff8bbae000 - 0x7fff8bbb3fff com.apple.DiskArbitration (2.6 - 2.6) <F8A47F61-83D1-3F92-B7A8-A169E0D187C0> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff8bbb4000 - 0x7fff8bbcfff7 libsystem_malloc.dylib (23.1.10) <FFE5C472-B23A-318A-85BF-77CDE61900D1> /usr/lib/system/libsystem_malloc.dylib
0x7fff8bbd0000 - 0x7fff8bbd7ff3 libcopyfile.dylib (103) <5A881779-D0D6-3029-B371-E3021C2DDA5E> /usr/lib/system/libcopyfile.dylib
0x7fff8bbd8000 - 0x7fff8bc11ff7 com.apple.QD (3.50 - 298) <C1F20764-DEF0-34CF-B3AB-AB5480D64E66> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff8bc12000 - 0x7fff8bd78fff libGLProgrammability.dylib (9.0.83) <9C97E814-F674-30F8-8C2D-C45FC1E7D934> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff8bf8b000 - 0x7fff8bfdcfff com.apple.QuickLookFramework (5.0 - 622.3) <AB6CCD09-ECDF-3F01-9C42-34B37DDCF12D> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff8bfdd000 - 0x7fff8bfe7ff7 com.apple.CrashReporterSupport (10.9 - 538) <B487466B-3AA1-3854-A808-A61F049FA794> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff8bfe8000 - 0x7fff8c2e7fff com.apple.Foundation (6.9 - 1056) <D608EDFD-9634-3573-9B7E-081C7D085F7A> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff8c2e8000 - 0x7fff8c2ebff7 libdyld.dylib (239.3) <62F4D752-4089-31A8-8B73-B95A68893B3C> /usr/lib/system/libdyld.dylib
0x7fff8c2ec000 - 0x7fff8c359fff com.apple.SearchKit (1.4.0 - 1.4.0) <B9B8D510-A27E-36B0-93E9-17146D9E9045> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff8c3c5000 - 0x7fff8c3c6ff7 libsystem_sandbox.dylib (278.10) <A47E7E11-3C76-318E-B67D-98972B86F094> /usr/lib/system/libsystem_sandbox.dylib
0x7fff8c3c7000 - 0x7fff8c3cbff7 libGIF.dylib (1038) <C29B4323-1B9E-36B9-96C2-7CEDBAA124F0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff8c3eb000 - 0x7fff8c42afff libGLU.dylib (9.0.83) <8B457205-513B-3477-AE9C-3AD979D5FE11> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff8c42b000 - 0x7fff8c683ff1 com.apple.security (7.0 - 55471) <233831C5-C457-3AD5-AFE7-E3E2DE6929C9> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff8c684000 - 0x7fff8c68dfff com.apple.CommonAuth (4.0 - 2.0) <1D263127-5F27-3128-996D-7397660D0C6E> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff8c68e000 - 0x7fff8c695ff7 libsystem_pthread.dylib (53.1.4) <AB498556-B555-310E-9041-F67EC9E00E2C> /usr/lib/system/libsystem_pthread.dylib
0x7fff8c696000 - 0x7fff8c6c0ff7 libsandbox.1.dylib (278.10) <B4183FA8-F7E2-3301-8BF9-0EEFB793A5D5> /usr/lib/libsandbox.1.dylib
0x7fff8c6e8000 - 0x7fff8c9bcfc7 com.apple.vImage (7.0 - 7.0) <D241DBFA-AC49-31E2-893D-EAAC31890C90> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff8ca3b000 - 0x7fff8ca80ff6 com.apple.HIServices (1.22 - 466) <21807AF8-3BC7-32BB-AB96-7C35CB59D7F6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff8ca81000 - 0x7fff8cae7fff com.apple.framework.CoreWiFi (2.0 - 200.21.1) <5491896D-78C5-30B6-96E9-D8DDECF3BE73> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff8cb0f000 - 0x7fff8cb54ff7 libcurl.4.dylib (78) <A722B4F0-1F6C-3E16-9CB1-4C6ADC15221E> /usr/lib/libcurl.4.dylib
0x7fff8cb55000 - 0x7fff8cc05ff7 libvMisc.dylib (423.32) <049C0735-1808-39B9-943F-76CB8021744F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff8ccd0000 - 0x7fff8cd88ff7 com.apple.DiscRecording (8.0 - 8000.4.6) <CDAAAD04-A1D0-3C67-ABCC-EFC9E8D44E7E> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff8cde6000 - 0x7fff8ce0afff libxpc.dylib (300.1.17) <4554927A-9467-365C-91F1-5A116989DD7F> /usr/lib/system/libxpc.dylib
0x7fff8cea9000 - 0x7fff8cfd9ff7 com.apple.desktopservices (1.8 - 1.8) <09DC9BB8-432F-3C7A-BB08-956A2DDFC2DE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff8cfdd000 - 0x7fff8cfdeff7 libSystem.B.dylib (1197.1.1) <BFC0DC97-46C6-3BE0-9983-54A98734897A> /usr/lib/libSystem.B.dylib
0x7fff8d094000 - 0x7fff8d0a8fff com.apple.aps.framework (4.0 - 4.0) <F529A05B-FB03-397E-B06A-3A60B808FA11> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff8d0ea000 - 0x7fff8d0eefff com.apple.IOAccelerator (98.7.1 - 98.7.1) <C0D16D6F-8729-3110-BEBA-BE4F53444470> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff8d0ef000 - 0x7fff8d3bdff4 com.apple.CoreImage (9.0.54) <74BB8685-69A9-3A45-8DED-EA26BD39D710> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff8d3be000 - 0x7fff8d43efff com.apple.CoreSymbolication (3.0 - 141) <B018335C-698B-3F87-AF1C-6115C4FA8954> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff8d79b000 - 0x7fff8d7b4ff7 com.apple.Kerberos (3.0 - 1) <F108AFEB-198A-3BAF-BCA5-9DFCE55EFF92> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff8d7b5000 - 0x7fff8d7b5fff com.apple.Carbon (154 - 157) <45A9A40A-78FF-3EA0-8FAB-A4F81052FA55> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff8d7bc000 - 0x7fff8d802ff7 com.apple.DiskManagement (6.0 - 744) <FE9F0616-FFCA-31D2-A0B5-E6C943326543> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0x7fff8d805000 - 0x7fff8d9eaff7 com.apple.CoreFoundation (6.9 - 855.11) <E22C6A1F-8996-349C-905E-96C3BBE07C2F> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff8d9eb000 - 0x7fff8d9eeffa libCGXType.A.dylib (599.7) <2FC9C2BC-B5C5-3C27-93F9-51C6C4512E9D> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x7fff8d9ef000 - 0x7fff8d9effff com.apple.ApplicationServices (48 - 48) <3E3F01A8-314D-378F-835E-9CC4F8820031> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff8d9f0000 - 0x7fff8d9f7fff libcompiler_rt.dylib (35) <4CD916B2-1B17-362A-B403-EF24A1DAC141> /usr/lib/system/libcompiler_rt.dylib
0x7fff8da00000 - 0x7fff8dbb8ff3 libicucore.A.dylib (511.25) <3ED7B656-416E-3071-AEC8-E85C90232F78> /usr/lib/libicucore.A.dylib
0x7fff8dc04000 - 0x7fff8dc0aff7 libsystem_platform.dylib (24.1.4) <331BA4A5-55CE-3B95-99EB-44E0C89D7FB8> /usr/lib/system/libsystem_platform.dylib
0x7fff8dc0b000 - 0x7fff8dc82fff com.apple.CoreServices.OSServices (600.4 - 600.4) <36B2B009-C35E-3F21-824E-E0D00E7808C7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff8dc83000 - 0x7fff8dcaffff com.apple.CoreServicesInternal (184.8 - 184.8) <707E05AE-DDA8-36FD-B0FF-7F15A061B46A> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff8dd03000 - 0x7fff8de71ff7 libBLAS.dylib (1094.5) <DE93A590-5FA5-32A2-A16C-5D7D7361769F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff8de72000 - 0x7fff8de72ff7 libkeymgr.dylib (28) <3AA8D85D-CF00-3BD3-A5A0-E28E1A32A6D8> /usr/lib/system/libkeymgr.dylib
0x7fff8de75000 - 0x7fff8de75ffd libOpenScriptingUtil.dylib (157) <19F0E769-0989-3062-9AFB-8976E90E9759> /usr/lib/libOpenScriptingUtil.dylib
0x7fff8df1d000 - 0x7fff8df34fff com.apple.PackageKit.PackageUIKit (3.0 - 329) <2B237B93-D088-33B7-AD28-79E5BC27576B> /System/Library/PrivateFrameworks/PackageKit.framework/Frameworks/PackageUIKit.framework/Versions/A/PackageUIKit
0x7fff8df88000 - 0x7fff8dfd6fff libcorecrypto.dylib (161.1) <F3973C28-14B6-3006-BB2B-00DD7F09ABC7> /usr/lib/system/libcorecrypto.dylib
0x7fff8dfd7000 - 0x7fff8dfd8fff libunc.dylib (28) <62682455-1862-36FE-8A04-7A6B91256438> /usr/lib/system/libunc.dylib
0x7fff8dfd9000 - 0x7fff8dfddff7 libcache.dylib (62) <BDC1E65B-72A1-3DA3-A57C-B23159CAAD0B> /usr/lib/system/libcache.dylib
0x7fff8e20e000 - 0x7fff8e221ff7 com.apple.AppContainer (3.0 - 1) <A90C058D-46E8-3BAB-AF17-AF9C7C273069> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff8e263000 - 0x7fff8e266fff com.apple.help (1.3.3 - 46) <AE763646-D07A-3F9A-ACD4-F5CBD734EE36> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff8e267000 - 0x7fff8e269fff com.apple.Mangrove (1.0 - 1) <72F5CBC7-4E78-374E-98EA-C3700136904E> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff8e26a000 - 0x7fff8e29fffc com.apple.LDAPFramework (2.4.28 - 194.5) <7E31A674-C6AB-33BE-BD5E-F5E3C6E22894> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff8e2a0000 - 0x7fff8e2a6fff com.apple.AOSNotification (1.7.0 - 760.3) <7901B867-60F7-3645-BB3E-18C51A6FBCC6> /System/Library/PrivateFrameworks/AOSNotification.framework/Versions/A/AOSNotification
0x7fff8e2a7000 - 0x7fff8e395fff libJP2.dylib (1038) <6C8179F5-8063-3ED6-A7C2-D5603DECDF28> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff8e896000 - 0x7fff8eb12ff7 com.apple.RawCamera.bundle (5.01 - 718) <6CC4A1E5-A89A-369D-96C4-7A5ED40B487B> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff8eb13000 - 0x7fff8ecafff7 com.apple.QuartzCore (1.8 - 332.0) <994D1E0A-64B6-398C-B9A2-C362F02DE943> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff8ecb0000 - 0x7fff8eceeff7 libGLImage.dylib (9.0.83) <C08048A7-03CC-3E40-BCDC-7791D87AC8E4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff8ecef000 - 0x7fff8f009ff7 com.apple.MediaToolbox (1.0 - 1273.29) <6260E68B-7E50-3D49-8C0A-7145614C13D8> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff8f030000 - 0x7fff8f030fff com.apple.CoreServices (59 - 59) <7A697B5E-F179-30DF-93F2-8B503CEEEFD5> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff8f051000 - 0x7fff8f059ff3 libCGCMS.A.dylib (599.7) <92AA4E85-7633-36E2-BAD0-7B1A2E48E75C> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
0x7fff8f05a000 - 0x7fff8f076fff libresolv.9.dylib (54) <11C2C826-F1C6-39C6-B4E8-6E0C41D4FA95> /usr/lib/libresolv.9.dylib
0x7fff8f077000 - 0x7fff8f07bfff libsystem_stats.dylib (93.1.26) <B9E26A9E-FBBC-3938-B8B7-6CF7CA8C99AD> /usr/lib/system/libsystem_stats.dylib
0x7fff8f07c000 - 0x7fff8f08cffb libsasl2.2.dylib (170) <C8E25710-68B6-368A-BF3E-48EC7273177B> /usr/lib/libsasl2.2.dylib
0x7fff8f08d000 - 0x7fff8f0ecfff com.apple.framework.CoreWLAN (4.0 - 400.45.1) <775F9444-8059-30A2-8058-7F7ACD68CCF1> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff8f331000 - 0x7fff8f33efff com.apple.Sharing (132.2 - 132.2) <F983394A-226D-3244-B511-FA51FDB6ADDA> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff8f33f000 - 0x7fff8f5e9ffd com.apple.HIToolbox (2.1 - 695) <C4DE35FF-D0AC-35C3-A7E6-F54CD153825C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff8f6e7000 - 0x7fff8f6f9fff com.apple.login (3.0 - 3.0) <B825A996-7F9C-3F47-B76F-A0F9B4BEB373> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff8f920000 - 0x7fff8fa11ff9 libiconv.2.dylib (41) <BB44B115-AC32-3877-A0ED-AEC6232A4563> /usr/lib/libiconv.2.dylib
0x7fff8fa12000 - 0x7fff8fa1dfff libkxld.dylib (2422.1.72) <C88EF3E6-B31F-3E12-BE9B-562D912BA733> /usr/lib/system/libkxld.dylib
0x7fff8fa1e000 - 0x7fff8fa24ff7 com.apple.XPCService (2.0 - 1) <2CE632D7-FE57-36CF-91D4-C57D0F2E0BFE> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fff8fa2f000 - 0x7fff8fa60fff com.apple.MediaKit (15 - 709) <23E33409-5C39-3F93-9E73-2B0E9EE8883E> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff8fa61000 - 0x7fff8fa6cff7 com.apple.DirectoryService.Framework (10.9 - 173.1.1) <F8566D1F-450F-3571-911F-75C68E45919F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff8fa6d000 - 0x7fff8fb99fff com.apple.MediaControlSender (1.9 - 190.4) <F5E934E1-D004-3C84-815A-961319F8C522> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSender
0x7fff8fb9a000 - 0x7fff8fbc2ffb libxslt.1.dylib (13) <C9794936-633C-3F0C-9E71-30190B9B41C1> /usr/lib/libxslt.1.dylib
0x7fff8fbc6000 - 0x7fff8fbcfff7 libcldcpuengine.dylib (2.3.58) <A2E1ED7B-FC7E-31F6-830A-FF917689766B> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff8fbd0000 - 0x7fff8fc08ff7 com.apple.RemoteViewServices (2.0 - 94) <3F34D630-3DDB-3411-BC28-A56A9B55EBDA> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff8fc09000 - 0x7fff8fc6dff3 com.apple.datadetectorscore (5.0 - 354.0) <9ACF24B8-3268-3134-A5BC-D72C9371A195> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff8fc75000 - 0x7fff8fc77ff7 com.apple.SecCodeWrapper (3.0 - 1) <F5107AD0-20CD-328C-8B2E-74CB6F3169F6> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff8fcbe000 - 0x7fff8fd47ff7 com.apple.SoftwareUpdate.framework (6 - 574) <A24BDCFF-6164-3028-8892-D3C00B7C5658> /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Versions/A/SoftwareUpdate
0x7fff8fd48000 - 0x7fff8fdd3fff libCoreStorage.dylib (380) <AE14C2F3-0EF1-3DCD-BF2B-A24D97D3B372> /usr/lib/libCoreStorage.dylib
0x7fff8fdd7000 - 0x7fff8fedcfff com.apple.ImageIO.framework (3.3.0 - 1038) <2C058216-C6D8-3380-A7EA-92A3F04520C1> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff8fefa000 - 0x7fff8ff4cfff libc++.1.dylib (120) <4F68DFC5-2077-39A8-A449-CAC5FDEE7BDE> /usr/lib/libc++.1.dylib
0x7fff8ff4d000 - 0x7fff900a0ff7 com.apple.audio.toolbox.AudioToolbox (1.9 - 1.9) <A0B7B007-9BD8-30E2-B644-47856DA29FEE> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff900a1000 - 0x7fff900b8ffa libAVFAudio.dylib (32.2) <52DA516B-DE79-322C-9E1B-2658019289D7> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
0x7fff900b9000 - 0x7fff900baffb libScreenReader.dylib (333.2) <0172E6E2-9D4B-36BF-81DC-428FF0668E78> /usr/lib/libScreenReader.dylib
0x7fff900bb000 - 0x7fff901f0ffa com.apple.WebKit (9537 - 9537.71) <8A07478D-B2CA-3724-81E4-ADC10E1AD3EA> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff901f1000 - 0x7fff901f5fff com.apple.ServerInformation (2.0 - 1) <E628F08A-0F6F-384B-AFD5-1BC1BBF56F1F> /System/Library/PrivateFrameworks/ServerInformation.framework/Versions/A/ServerInformation
0x7fff90248000 - 0x7fff9030aff1 com.apple.CoreText (352.0 - 367.15) <E5C70FC8-C861-39B8-A491-595E5B55CFC8> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff9030b000 - 0x7fff9030cff7 libsystem_blocks.dylib (63) <FB856CD1-2AEA-3907-8E9B-1E54B6827F82> /usr/lib/system/libsystem_blocks.dylib
0x7fff9030d000 - 0x7fff9030dffd com.apple.audio.units.AudioUnit (1.9 - 1.9) <6E89F3CB-CC41-3728-9F9A-FDFC151E8261> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff90327000 - 0x7fff90328ff7 libodfde.dylib (20) <C00A4EBA-44BC-3C53-BFD0-819B03FFD462> /usr/lib/libodfde.dylib
0x7fff90329000 - 0x7fff90e9dff7 com.apple.AppKit (6.9 - 1265) <0E9FC8BF-DA3C-34C5-91CC-12BC922B5F01> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff90f2e000 - 0x7fff90f30fff com.apple.loginsupport (1.0 - 1) <4772DFF0-E8FD-3F27-9C3B-39563B904E1C> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff90f31000 - 0x7fff90f34fff com.apple.TCC (1.0 - 1) <32A075D9-47FD-3E71-95BC-BFB0D583F41C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff90f35000 - 0x7fff90f90ffb com.apple.AE (665.5 - 665.5) <BBA230F9-144C-3CAB-A77A-0621719244CD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff90ffc000 - 0x7fff91030fff libssl.0.9.8.dylib (50) <B15F967C-B002-36C2-9621-3456D8509F50> /usr/lib/libssl.0.9.8.dylib
0x7fff91031000 - 0x7fff91078ff7 libcups.2.dylib (372) <348EED62-6C20-35D6-8EFB-E80943965100> /usr/lib/libcups.2.dylib
0x7fff91079000 - 0x7fff910a7ff7 com.apple.securityinterface (9.0 - 55047) <0346D8A9-2CAA-38F3-A741-5FBA5E9F1E7C> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff910a8000 - 0x7fff910a9ff7 com.apple.print.framework.Print (9.0 - 260) <EE00FAE1-DA03-3EC2-8571-562518C46994> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff910c7000 - 0x7fff91198ff7 com.apple.QuickLookUIFramework (5.0 - 622.3) <9741E66B-3978-35F6-8846-B6C528945611> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff91199000 - 0x7fff911b4ff7 libCRFSuite.dylib (34) <FFAE75FA-C54E-398B-AA97-18164CD9789D> /usr/lib/libCRFSuite.dylib
0x7fff91248000 - 0x7fff9125ffff com.apple.CFOpenDirectory (10.9 - 173.1.1) <3FB4D5FE-860B-3BDE-BAE2-3531D919EF10> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff912c1000 - 0x7fff9130cfff com.apple.ImageCaptureCore (5.0 - 5.0) <F529EDDC-E2F5-30CA-9938-AF23296B5C5B> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff9130d000 - 0x7fff91336ff7 libc++abi.dylib (48) <8C16158F-CBF8-3BD7-BEF4-022704B2A326> /usr/lib/libc++abi.dylib
0x7fff91337000 - 0x7fff91348ff7 libz.1.dylib (53) <42E0C8C6-CA38-3CA4-8619-D24ED5DD492E> /usr/lib/libz.1.dylib
0x7fff91349000 - 0x7fff9134dfff libpam.2.dylib (20) <B93CE8F5-DAA8-30A1-B1F6-F890509513CB> /usr/lib/libpam.2.dylib
0x7fff9134e000 - 0x7fff9179cfff com.apple.VideoToolbox (1.0 - 1273.29) <6E38291D-7A81-3033-AFB9-61ABD38B6371> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff9179d000 - 0x7fff917eeff3 com.apple.audio.CoreAudio (4.2.0 - 4.2.0) <BF4C2FE3-8BC8-30D1-8347-2A7221268794> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff917ef000 - 0x7fff917f9ff7 com.apple.bsd.ServiceManagement (2.0 - 2.0) <2D27B498-BB9C-3D88-B05A-76908A8A26F3> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff917fa000 - 0x7fff91823fff com.apple.DictionaryServices (1.2 - 208) <A539A058-BA57-35EE-AA08-D0B0E835127D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff91824000 - 0x7fff9186dfff com.apple.CoreMedia (1.0 - 1273.29) <4ACD30BA-E9FE-3842-A8B7-E3BD63747867> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff9186e000 - 0x7fff9187fff7 libsystem_asl.dylib (217.1.4) <655FB343-52CF-3E2F-B14D-BEBF5AAEF94D> /usr/lib/system/libsystem_asl.dylib
0x7fff92144000 - 0x7fff9214cff7 com.apple.AppleSRP (5.0 - 1) <ABC7F088-1FD5-3768-B9F3-847F355E90B3> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff9214d000 - 0x7fff92157fff libcommonCrypto.dylib (60049) <8C4F0CA0-389C-3EDC-B155-E62DD2187E1D> /usr/lib/system/libcommonCrypto.dylib
0x7fff92158000 - 0x7fff9223fff7 libxml2.2.dylib (26) <A1DADD11-89E5-3DE4-8802-07186225967F> /usr/lib/libxml2.2.dylib
0x7fff92240000 - 0x7fff9252afff com.apple.CoreServices.CarbonCore (1077.13 - 1077.13) <21324540-8B84-3333-ADB8-D3D5181D4639> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff9252b000 - 0x7fff9252cfff liblangid.dylib (117) <9546E641-F730-3AB0-B3CD-E0E2FDD173D9> /usr/lib/liblangid.dylib
0x7fff9252d000 - 0x7fff9252dfff com.apple.Accelerate (1.9 - Accelerate 1.9) <509BB27A-AE62-366D-86D8-0B06D217CF56> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff9252e000 - 0x7fff92553ff7 com.apple.ChunkingLibrary (2.0 - 155.1) <B845DC7A-D1EA-31E2-967C-D1FE0C628036> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff92554000 - 0x7fff92559ff7 com.apple.MediaAccessibility (1.0 - 43) <D309D83D-5FAE-37A4-85ED-FFBDA8B66B82> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff9255a000 - 0x7fff925a7fff com.apple.AppleVAFramework (5.0.27 - 5.0.27) <D01B7D87-4BDC-3E48-A79B-951D05075F9D> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff925a8000 - 0x7fff92692fff libsqlite3.dylib (158) <00269BF9-43BE-39E0-9C85-24585B9923C8> /usr/lib/libsqlite3.dylib
0x7fff92ace000 - 0x7fff92ad2ff7 libheimdal-asn1.dylib (323.12) <063A01C2-E547-39D9-BB42-4CC8E64ADE70> /usr/lib/libheimdal-asn1.dylib
0x7fff92ad3000 - 0x7fff92bc2fff libFontParser.dylib (111.1) <835A8253-6AB9-3AAB-9CBF-171440DEC486> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff930c4000 - 0x7fff93111ff2 com.apple.print.framework.PrintCore (9.0 - 428) <8D8253E3-302F-3DB2-9C5C-572CB974E8B3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff93112000 - 0x7fff93a2e05f com.apple.CoreGraphics (1.600.0 - 599.7) <7D0FD5A7-A061-39BA-8E00-723825D2C4DD> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff93a34000 - 0x7fff93a42fff com.apple.opengl (9.0.83 - 9.0.83) <AF467644-7B1D-327A-AC47-CECFCAF61990> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff93b14000 - 0x7fff93b43ff5 com.apple.GSS (4.0 - 2.0) <ED98D992-CC14-39F3-9ABC-8D7F986487CC> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff93b44000 - 0x7fff93cf1f27 libobjc.A.dylib (551.1) <AD7FD984-271E-30F4-A361-6B20319EC73B> /usr/lib/libobjc.A.dylib
0x7fff93cf2000 - 0x7fff93cf7ff7 libunwind.dylib (35.3) <78DCC358-2FC1-302E-B395-0155B47CB547> /usr/lib/system/libunwind.dylib
0x7fff93cf8000 - 0x7fff93cfcfff com.apple.CommonPanels (1.2.6 - 96) <6B434AFD-50F8-37C7-9A56-162C17E375B3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff93cfd000 - 0x7fff93d06fff com.apple.DisplayServicesFW (2.8 - 360.8.14) <816A9CED-1BC0-3C76-8103-1B9BE0F723BB> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff93d07000 - 0x7fff93d2eff7 libsystem_network.dylib (241.3) <8B1E1F1D-A5CC-3BAE-8B1E-ABC84337A364> /usr/lib/system/libsystem_network.dylib
0x7fff93d2f000 - 0x7fff93d45fff com.apple.CoreMediaAuthoring (2.2 - 947) <B01FBACC-DDD5-30A8-BCCF-57CE24ABA329> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff93d46000 - 0x7fff93d5eff7 com.apple.GenerationalStorage (2.0 - 160.2) <79629AC7-896F-3302-8AC1-4939020F08C3> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff93d5f000 - 0x7fff93d81fff com.apple.framework.familycontrols (4.1 - 410) <4FDBCD10-CAA2-3A9C-99F2-06DCB8E81DEE> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x7fff93d85000 - 0x7fff93de5ff2 com.apple.CoreUtils (1.9 - 190.4) <CBB5B4DC-2801-32B3-A31C-8811CCF99873> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff93de6000 - 0x7fff93e6ffff com.apple.ColorSync (4.9.0 - 4.9.0) <B756B908-9AD1-3F5D-83F9-7A0B068387D2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff9402c000 - 0x7fff94078ffe com.apple.CoreMediaIO (401.0 - 4544) <44EBC0FE-DAD5-3711-96CB-05250F350A16> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff940bc000 - 0x7fff940c9ff4 com.apple.Librarian (1.2 - 1) <F1A2744D-8536-32C7-8218-9972C6300DAE> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
0x7fff94163000 - 0x7fff94fafff5 com.apple.WebCore (9537 - 9537.70) <7A90E9D3-4F26-3049-9C96-C6B8CB1395C8> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff94fb0000 - 0x7fff94ffeff9 libstdc++.6.dylib (60) <0241E6A4-1368-33BE-950B-D0A175C41F54> /usr/lib/libstdc++.6.dylib
0x7fff94fff000 - 0x7fff95017ff7 com.apple.openscripting (1.4 - 157) <B3B037D7-1019-31E6-9D17-08E699AF3701> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff9504a000 - 0x7fff9504bffb libremovefile.dylib (33) <3543F917-928E-3DB2-A2F4-7AB73B4970EF> /usr/lib/system/libremovefile.dylib
0x7fff9504c000 - 0x7fff951bcff6 com.apple.CFNetwork (673.0.3 - 673.0.3) <42CFC3DB-35C8-3652-AF37-4BCC73D8BDEF> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff951e1000 - 0x7fff95321fff com.apple.QTKit (7.7.3 - 2826) <7A110F61-D4DD-3C84-950D-E5F486DE5765> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff95322000 - 0x7fff9532cfff com.apple.AppSandbox (3.0 - 1) <55717299-8164-3D79-918F-BD64706735CF> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff95393000 - 0x7fff953f6ff7 com.apple.SystemConfiguration (1.13 - 1.13) <F05F4149-981B-380B-8F50-51CE804BBB89> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff953f7000 - 0x7fff95402fff libGPUSupportMercury.dylib (9.0.83) <A9DF1DD1-8C1E-3A86-AF96-BF3A7D4C8C1B> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff95403000 - 0x7fff95427fff com.apple.quartzfilters (1.8.0 - 1.7.0) <39C08086-9866-372F-9420-81F5689149DF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff95428000 - 0x7fff954b0ff7 com.apple.CorePDF (4.0 - 4) <92D15ED1-D2E1-3ECB-93FF-42888219A99F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff954b1000 - 0x7fff954bcfff libGL.dylib (9.0.83) <984A960A-C159-3AE5-8B40-E2B451F6C712> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff9550d000 - 0x7fff95534ffb libsystem_info.dylib (449.1.3) <7D41A156-D285-3849-A2C3-C04ADE797D98> /usr/lib/system/libsystem_info.dylib
0x7fff95535000 - 0x7fff9559fff7 com.apple.framework.IOKit (2.0.1 - 907.1.13) <C1E95F5C-B79B-31BE-9F2A-1B25163C1F16> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff955e2000 - 0x7fff955fcfff libdispatch.dylib (339.1.9) <46878A5B-4248-3057-962C-6D4A235EEF31> /usr/lib/system/libdispatch.dylib
0x7fff9560f000 - 0x7fff9565dfff com.apple.opencl (2.3.57 - 2.3.57) <FC03A80D-543A-3448-83FF-D399C3A240D9> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff9565e000 - 0x7fff956a0ff7 libauto.dylib (185.5) <F45C36E8-B606-3886-B5B1-B6745E757CA8> /usr/lib/libauto.dylib
0x7fff956a1000 - 0x7fff956b0ff8 com.apple.LangAnalysis (1.7.0 - 1.7.0) <8FE131B6-1180-3892-98F5-C9C9B79072D4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff95730000 - 0x7fff95731fff com.apple.TrustEvaluationAgent (2.0 - 25) <334A82F4-4AE4-3719-A511-86D0B0723E2B> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff95732000 - 0x7fff9574fff7 com.apple.framework.Apple80211 (9.0 - 900.47) <C897AFE6-DD73-387D-816A-67252A564207> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff95750000 - 0x7fff95758fff libsystem_dnssd.dylib (522.1.11) <270DCF6C-502D-389A-AA9F-DE4624A36FF7> /usr/lib/system/libsystem_dnssd.dylib
0x7fff9576d000 - 0x7fff9576fff3 libsystem_configuration.dylib (596.12) <C4F633D9-94C8-35D9-BB2D-84C5122533C7> /usr/lib/system/libsystem_configuration.dylib
0x7fff95770000 - 0x7fff95773ffc com.apple.IOSurface (91 - 91) <07CA8A59-1E32-3FB6-B506-18DAF58A8CE0> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff95774000 - 0x7fff95858fff com.apple.coreui (2.1 - 231) <432DB40C-6B7E-39C8-9FB5-B95917930056> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff95859000 - 0x7fff95888ff7 com.apple.CoreAVCHD (5.7.0 - 5700.4.3) <404369C0-ED9F-3010-8D2F-BC55285F7808> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff958c8000 - 0x7fff958edff7 com.apple.CoreVideo (1.8 - 117.2) <4674339E-26D0-35FA-9958-422832B39B12> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff958ee000 - 0x7fff958f0fff libRadiance.dylib (1038) <55F99274-5074-3C73-BAC5-AF234E71CF38> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff95904000 - 0x7fff95930ff7 com.apple.framework.SystemAdministration (1.0 - 1.0) <36C562FF-5D91-318C-A19C-6B4453FB78B9> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fff95a2b000 - 0x7fff95a38ff7 libxar.1.dylib (202) <5572AA71-E98D-3FE1-9402-BB4A84E0E71E> /usr/lib/libxar.1.dylib
0x7fff95a39000 - 0x7fff95a42fff com.apple.speech.synthesis.framework (4.6.2 - 4.6.2) <0AAE45F0-FC6E-36B6-A6A7-73E6950A74AC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff95a43000 - 0x7fff95a45ff7 libquarantine.dylib (71) <7A1A2BCB-C03D-3A25-BFA4-3E569B2D2C38> /usr/lib/system/libquarantine.dylib
0x7fff95a46000 - 0x7fff95a46fff com.apple.quartzframework (1.5 - 1.5) <3B2A72DB-39FC-3C5B-98BE-605F37777F37> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff95cd9000 - 0x7fff95ce1ff7 com.apple.speech.recognition.framework (4.2.4 - 4.2.4) <98BBB3E4-6239-3EF1-90B2-84EA0D3B8D61> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff95cef000 - 0x7fff9625ffff com.apple.CoreAUC (6.22.08 - 6.22.08) <F306D552-2220-3160-88EA-C916193C5EFD> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff96502000 - 0x7fff96504ffb libutil.dylib (34) <DAC4A6CF-A1BB-3874-9569-A919316D30E8> /usr/lib/libutil.dylib
0x7fff96505000 - 0x7fff96578ffb com.apple.securityfoundation (6.0 - 55122) <119D1C53-B292-3378-AEE1-A3B1FB02F43F> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff96579000 - 0x7fff96594fff com.apple.DistributionKit (700 - 845) <E3D1ECC4-C5D1-35DC-B7E4-800FE0FFBF56> /System/Library/PrivateFrameworks/Install.framework/Frameworks/DistributionKit.framework/Versions/A/DistributionKit
0x7fff96595000 - 0x7fff96ab9fff com.apple.QuartzComposer (5.1 - 316) <B20E93C3-8517-3E5C-83B6-C312C839C5D0> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff96aba000 - 0x7fff96adeff7 libJPEG.dylib (1038) <86F349A8-882D-3326-A0B0-63257F68B1A7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff96af9000 - 0x7fff96b68ff1 com.apple.ApplicationServices.ATS (360 - 363.1) <88976B22-A9B8-3E7B-9AE6-0B8E09A968FC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff96b82000 - 0x7fff96b92fff libbsm.0.dylib (33) <2CAC00A2-1352-302A-88FA-C567D4D69179> /usr/lib/libbsm.0.dylib
0x7fff96ba1000 - 0x7fff96bd0fd2 libsystem_m.dylib (3047.16) <B7F0E2E4-2777-33FC-A787-D6430B630D54> /usr/lib/system/libsystem_m.dylib
0x7fff97327000 - 0x7fff97588ff7 com.apple.imageKit (2.5 - 770) <33BCF627-EB1A-3CC1-98AB-2324B6DFB329> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 93
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 35070
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=278.8M resident=114.4M(41%) swapped_out_or_unallocated=164.4M(59%)
Writable regions: Total=99.7G written=12.6G(13%) resident=3.5G(4%) swapped_out=9.2G(9%) unallocated=96.2G(96%)
REGION TYPE VIRTUAL
CG backing stores 5344K
CG image 16.1M
CG raster data 6324K
CG shared images 204K
Foundation 4K
IOKit 4776K
Image IO 4528K
Kernel Alloc Once 8K
MALLOC 99.6G
MALLOC (admin) 32K
Memory Tag 241 112K
Memory Tag 242 12K
Memory Tag 249 156K
Memory Tag 251 8K
OpenGL GLSL 1664K
STACK GUARD 56.1M
Stack 18.3M
VM_ALLOCATE 16.4M
__DATA 37.6M
__IMAGE 528K
__LINKEDIT 69.0M
__TEXT 209.8M
__UNICODE 544K
mapped file 68.6M
shared memory 68K
TOTAL 100.1G
Just to add one comment - I have three plugins running - (a) Concerto; (b) iTunes; (c) Squeezebox. I just tried deactivating one by one and it seems that the Squeezebox Plugin is the one that is causing the increased CPU usage. I am not sure why but even witch Concerto off, so I do not believe I actively duo anything with that plugin, the IndigoPluginHost is at the top of my CPU usage list.
