Been having a problem for quite a long time but it was very intermitant and did not have time to investigate what was causing it. After upgrading to Mustangs it is now happing all the time so I started investigating.
It is related to a few triggers that run from Berkienet’s AD2USB alarm interface plugin (don’t worry Richard it’s not your plugin) I have many triggers that run with the plugin that cause no trouble, but have now found it;s the ones that access the calendar program. The trouble is a number of imbedded applescripts. They write an entry to few different calendars indicating when the alarm is turned on and off, when a door is locked or unlocked, also when any of the outdoor motion detectors see’s motion. "It's great I can look back 2 years ago and see the date and time when the UPS guy left a package behind my delivery door".
This is one version of the script:
tell application "Calendar"
tell calendar "Outside"
set theDate to current date
make new event at end with properties {summary:"Backyard Motion", start date:theDate}
end tell
end tell
Now running Mavericks any time any version of the script is run the server hangs, client computers get an error “server not responding”. The hang lasts a few minutes than starts working at which point I get the following errors:
Nov 9, 2013, 4:31:12 PM
Trigger Back Yard Motion Speak and count NIGHT
Sent INSTEON "Deck Spots" on to 100
Schedule Back Yard Motion Speak and count NIGHT (delayed action)
Nov 9, 2013, 4:33:23 PM
TED 5000 Plugin Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 66, in runConcurrentThread
<type 'exceptions.StandardError'>: ServerCommunicationError -- timeout waiting for response
TED 5000 Plugin Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
WeatherSnoop Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 222, in runConcurrentThread
WeatherSnoop Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
TED 5000 Plugin Polling Interval: 120
Error script error: Calendar got an error: AppleEvent timed out. (-1712)
Tried running the script in the applescript editor, the results screen shows running for a few minutes, than shows error:
error "Calendar got an error: AppleEvent timed out." number -1712
The script still works in that the information is send to the proper calendar, even that it timed out.
The intermittent hangs before mavericks gave the same type of error (plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)) but not every time, now with mavericks it happens every time.
Thanks for any suggestions
Elwood
