Indigo server doesn't' take condition in applescript
Sun Jun 02, 2013 12:16 pm
domlazar offline
My script works in applescript editor but doesn't take the condition to adjust Indigo variable as soon I try to execute it from IndigoServer.
here is the script, someone would have an idea
thanks
set the result to "0.0"
set theIP to "192.168.1.110"
set theTimeout to 20
set theResult to do shell script "/sbin/ping -qon -c 1 -W " & theTimeout & " " & theIP & " | /usr/bin/grep % | /usr/bin/sed \"s/.*,\\ //\" | /usr/bin/sed \"s/%.*//\""
if theResult is "" then
set theResult to 100
end if
if theResult = "0.0" then
set value of variable "iphone" to "home"
end tell
else
set value of variable "iphone" to "out"
end tell
end if
Mac OS Montery 12.2.1 macmini
Indigo Pro 2021.2
Powerlinc 2413U
Sun Jun 02, 2013 3:52 pm
Re: Indigo server doesn't' take condition in applescript
What do you mean by "doesn't take condition to adjust Indigo variable"?
Are you running this script as an embedded script or as a script file? You should run it as a script file because the do shell script (even though you set a timeout) could hang up.
Tue Jun 04, 2013 8:34 am
domlazar offline
Sorry for my previous explanation, I wrote that just before leaving for work,... :oops:
I have a variable called "iPhone" in Indigo. If i'm away the variable should be "out" and "home" if i'm home. This is done by doing ping to my Iphone IP on my home network. With applescript editor everything is OK. The condition is respected applescript does the variable change in Indigo.
As soon I introduce the script in Indigo, as file or embedded the Indigo variable doesn't want to change as appropriate.
I've tried different scripts and the result is the same, outside Indigo (applescript editor)everything works fine, as soon as the script is in Indigo as file, the script return "out" in every situation.
here is a new script that I tried
end tell
try
do shell script "ping -s 1 -i 11 -o -t 2 192.168.1.110"
on error
end tell
end try
Indigo Pro 2021.2
Powerlinc 2413U
Tue Jun 04, 2013 8:43 am
You need to use the full path to the ping executable (/sbin/ping), and I think it should work.
Tue Jun 04, 2013 9:35 am
domlazar offline
You're a wizard
thanks you so much,
after several of trial/errors that finally works
Indigo Pro 2021.2
Powerlinc 2413U
Users browsing this forum: No registered users and 25 guests
