Since my NOAA script rarely refreshes correctly according to how the "property variableRefreshRate : 15 * 60" line of code is set, is there any problem in just deleting that
line and executing at set intervals from within Indigo?
Carl
ckeyes888 wrote:Thanks Jay. I realize it's only updated every hour or so but my problem is the script
simply stops refreshing altogether for many hours at a time. I'd prefer, if possible,
to trigger it myself periodically and not rely on the code in the script to refresh the info.
When I do execute the script from within Indigo it always refreshes the data.
bschollnick2 wrote:ckeyes888 wrote:Thanks Jay. I realize it's only updated every hour or so but my problem is the script
An alternative is to take a look at the Weather Conditions plugin ( http://dl.dropbox.com/u/241415/Indigo%2 ... 0v0981.zip )as well. It allows you to set the timed refresh interval, and you can set a trigger action to force a refresh of the weather information as well...
- Ben
Ben, does it work with Indigo 4?
jay wrote:He's talking about the NOAA Weather AppleScript. I'm referring to the new plugin. The About menu item under the "NOAA Weather" plugin takes you to it's wiki page.
hammer32 wrote:Hello,
I'm getting this error, I'm pretty sure it's from the NOAA Weather Script:
GetXMLfile:An error of type -10810 has occurred.(-10810)
Is anyone else getting it also?
