making some progress
Wed Feb 18, 2004 7:40 pm
ddeppe offline
Ok, I figured out I was using an invalid command. Below is the revised script:
-- note: depends on nightly enablment of FishLightActive variable
tell application "Indigo"
  if daylight then
    log "Andrews motion during daylight"
    remove delayed actions for device "Andrews Light"
    remove delayed actions for device "Andrews Closet"
   all off F in 10 * 60
  else -- it is nighttime
    if (FishLitTime <= 120) then
      if (FishLightActive = true) then
        if (on state of device "Andrews Fish Light" is false) then
          log "Turning on Andrews Fish Light"
          turn on "Andrews Fish Light" for 10 * 60
          set value of variable "FishLitTime" to "FishLitTime" + 10
          remove delayed actions for trigger "Andrews Motion"
          set value of variable "FishLightActive" to False
          set value of variable "FishLightActive" to True in 8 * 60
        else -- fish light is already on
          log "Leaving Andrews Fish Light on additional 10 min's"
          remove delayed actions for device "Andrews Fish Light"
          turn off "Andrews Fish Light" in 10 * 60
          set "FishLitTime" to FishLitTime + 8
       end if -- state of fish light
      dim "Andrews Light" by 15  in 35 * 60
      turn off "Andrews Light" in 40 * 60
    else -- FishLitTime has reached daily limit
      set value of variable "FishLitTime" to 0
      log "Andrews fishlight has reached limit - disabling until next night"
     end if -- Fishlight Active
   end if -- FishLitTime
end if -- daylight
end tell
But now I'm getting the following error "Can't get true in 8. Access not allowed." on the following line:
Wed Feb 18, 2004 7:45 pm
Re: making some progress
See my post on the other thread.
Regards,
Matt
Wed Feb 18, 2004 8:00 pm
ddeppe offline
(No subject)
I found the issue - just had to enclose true in () - also made some other fixes. Below is the revised code:
if daylight then
all off (F in 10) * 60
set value of variable "FishLightActive" to false
set value of variable "FishLightActive" to true * 60
set value of "FishLitTime" to FishLitTime + 8
end if -- daylight
end tell
Wed Feb 18, 2004 9:21 pm
ddeppe offline
more progress
Ok, I've made more progress - figured out I simply can't change a variable with a delay - only option was to create a "group" which had the simple reason for existence to modify the variable, and then I was able to execute that "group" with a delay. The next problem I ran into was that I needed to convert a string into an integer - Indigo is storing the value as a string, but I need it as an integer in order to pass the if validation as true. I solved it by creating a local variable as an integer from the string. Not sure if there is a better way. Below is my the current version of my code:
-- note: depends on nightly enablment of FishActive variable
   if daylight then
      if (value of variable "FishActive" = "true") then
         set FishLitTime to (value of variable "FishLitTime")
         if (FishLitTime > 120) then
               set value of variable "FishLitTime" to (value of variable "FishLitTime") + 10
               set value of variable "FishActive" to false
               execute group "Enable FishActive" in 10 * 60
               log "Leaving Andrews Fish Light on additional 10 min's " & value of variable "FishLitTime"
               set value of variable "FishLitTime" to (value of variable "FishLitTime") + 8
               log "new value of FishLitTime is: " & value of variable "FishLitTime"
            log "Andrews fishlight has reached limit - disabling until next night " & value of variable "FishLitTime"
            -- set value of variable "FishActive" to false
            -- set value of variable "FishLitTime" to 0
      else
         log "FishActive is false"
      end if -- FishActive
   end if -- daylight
end tell
