Multiple Home Assistant Servers
Fri Feb 16, 2024 2:50 pm
wamartei offline
Can this plugin access multiple HASS servers at the same time? if not, do I need to duplicate the plugin in the Application Support folder for each HASS instance I'd like to control? Thanks!
Fri Feb 16, 2024 3:46 pm
Re: Multiple Home Assistant Servers
It only supports one HA instance. If you really need multiples, then you will need to make additional copies of the plugin. Don't forget to change the name AND plugin ID in the info.plist file.
