Is it possible to pull in a chart that is created in HA
Sat Feb 03, 2024 7:16 pm
norcoscia offline
I have HA up and running and I noticed it is tracking a sensor value and building a graph - I can see the sensor value and pull it into Indigo via your plug in. Wondering if there is a way to pull in the chart into Indigo.
Example of the chart below - when I click on the sensor value on my HA dashboard the chart pops open....
Screenshot 2024-02-03 at 5.15.04 PM.png (149.3 KiB) Viewed 349 times
_______
Norm
Sat Feb 03, 2024 7:20 pm
Re: Is it possible to pull in a chart that is created in HA
Not through the HAA plugin.
If that chart has a consistent URL, you could use some other method (even a simple Python script) to fetch it and save it somewhere.
Or just use one of the Indigo native plugins that charts sensor values.
Sat Feb 03, 2024 8:00 pm
norcoscia offline
OK, thanks - I’ll check for a URL but did not see anything that was obvious - I was hoping to avoid building the chart manually, but I think I can remember how I did that with another value a few years ago.
_______
Norm
Sat Feb 03, 2024 8:35 pm
Right click on the image and see if it opens in it's own window.
Sun Feb 04, 2024 7:26 am
norcoscia offline
No Joy - I think it is some sort of helper thing. No worries I still have a lot to figure out with HA…
_______
Norm
Sun Feb 04, 2024 12:55 pm
I don't know where that image is actually being shown, but if you can save it as an image file then you can reference that on a refreshing image control (if you're looking to put it in a control page).
