A couple days ago I upgraded indigo to 2023.1 and noticed the AD2USB 3.2.1 was downrev .....this morning I bumped the blueing up to 3.4 and immediately started getting a warning about wire expansion 107 (see below) .
As with most things in this system , they work so well, for so long, that you forget how they were don in the first place Y'all have any thoughts on what the plugin warning is pointing to?
I reinstalled the v 3.2.1 and get no such warning, so it appears like there's something different in the 3.4 plugin
Dec 7, 2023 at 8:36:05 AM
Stopping plugin AD2USB Alarm Interface (pid 1455)
AD2USB Alarm Interface AlarmDecoder StopThread received
AD2USB Alarm Interface runConcurrentThread completed
AD2USB Alarm Interface called with Name:Alarm Keypad, id:1321680986, TypeId:ad2usbInterface
AD2USB Alarm Interface Device stop completed for Alarm Keypad
AD2USB Alarm Interface called with Name:Alarm Zone 1, id:328661344, TypeId:alarmZone
AD2USB Alarm Interface Device stop completed for Alarm Zone 1
AD2USB Alarm Interface called with Name:Alarm Zone 10, id:225134475, TypeId:alarmZone
AD2USB Alarm Interface Device stop completed for Alarm Zone 10
AD2USB Alarm Interface called with Name:Alarm Zone 10 Virtual, id:1245773239, TypeId:alarmZoneVirtual
AD2USB Alarm Interface Device stop completed for Alarm Zone 10 Virtual
AD2USB Alarm Interface called with Name:Alarm Zone 11, id:1417454933, TypeId:alarmZone
AD2USB Alarm Interface Device stop completed for Alarm Zone 11
AD2USB Alarm Interface called with Name:Alarm Zone 11 Virtual, id:705688944, TypeId:alarmZoneVirtual
AD2USB Alarm Interface Device stop completed for Alarm Zone 11 Virtual
AD2USB Alarm Interface called with Name:Alarm Zone 12, id:1829762316, TypeId:alarmZone
AD2USB Alarm Interface Device stop completed for Alarm Zone 12
AD2USB Alarm Interface called with Name:Alarm Zone 12 Virtual, id:1479497037, TypeId:alarmZoneVirtual
AD2USB Alarm Interface Device stop completed for Alarm Zone 12 Virtual
AD2USB Alarm Interface called with Name:Alarm Zone 2, id:1662176307, TypeId:alarmZone
AD2USB Alarm Interface Device stop completed for Alarm Zone 2
AD2USB Alarm Interface called with Name:Alarm Zone 3, id:1827566762, TypeId:alarmZone
AD2USB Alarm Interface Device stop completed for Alarm Zone 3
AD2USB Alarm Interface called with Name:Alarm Zone 4, id:607939709, TypeId:alarmZone
AD2USB Alarm Interface Device stop completed for Alarm Zone 4
AD2USB Alarm Interface called with Name:Alarm Zone 5, id:411886041, TypeId:alarmZone
AD2USB Alarm Interface Device stop completed for Alarm Zone 5
AD2USB Alarm Interface called with Name:Alarm Zone 6, id:1306355967, TypeId:alarmZone
AD2USB Alarm Interface Device stop completed for Alarm Zone 6
AD2USB Alarm Interface called with Name:Alarm Zone 7, id:427909257, TypeId:alarmZone
AD2USB Alarm Interface Device stop completed for Alarm Zone 7
AD2USB Alarm Interface called with Name:Alarm Zone 8, id:306547627, TypeId:alarmZone
AD2USB Alarm Interface Device stop completed for Alarm Zone 8
AD2USB Alarm Interface called with Name:Alarm Zone 9, id:1004546884, TypeId:alarmZone
AD2USB Alarm Interface Device stop completed for Alarm Zone 9
AD2USB Alarm Interface called with Name:Alarm Zone 9 Virtual, id:206912770, TypeId:alarmZoneVirtual
AD2USB Alarm Interface Device stop completed for Alarm Zone 9 Virtual
AD2USB Alarm Interface serial connection is open... attempting to close...
AD2USB Alarm Interface serial connection is closed...
AD2USB Alarm Interface Plugin shutdown completed
Stopped plugin AD2USB Alarm Interface
Upgrading plugin AD2USB Alarm Interface to newer version 3.4.0 (previous version moved to trash)
Loading plugin "AD2USB Alarm Interface 3.4.0" using API v3.0.0
Starting plugin "AD2USB Alarm Interface 3.4.0" (pid 10000)
AD2USB Alarm Interface Indigo logging level set to:INFO (20)
AD2USB Alarm Interface Plugin logging level set to:INFO (20)
AD2USB Alarm Interface Plugin init completed
Started plugin "AD2USB Alarm Interface 3.4.0"
AD2USB Alarm Interface attempting to connect to:socket://192.168.0.XX:10000
AD2USB Alarm Interface connected to AlarmDecoder:socket://192.168.0.XX:10000
AD2USB Alarm Interface AlarmDecoder communication started...
AD2USB Alarm Interface AlarmDecoder VER (version) command sent
AD2USB Alarm Interface AlarmDecoder C (config) command sent
AD2USB Alarm Interface AlarmDecoder communication startup completed successfully
AD2USB Alarm Interface AlarmDecoder initialized and communication started...
AD2USB Alarm Interface Plugin startup completed. Ready to open link to the ad2usb in Basic mode.
AD2USB Alarm Interface Device startup completed for Alarm Keypad
AD2USB Alarm Interface Device startup completed for Alarm Zone 1
AD2USB Alarm Interface Device startup completed for Alarm Zone 10
AD2USB Alarm Interface Device startup completed for Alarm Zone 10 Virtual
AD2USB Alarm Interface Device startup completed for Alarm Zone 11
AD2USB Alarm Interface Device startup completed for Alarm Zone 11 Virtual
AD2USB Alarm Interface Device startup completed for Alarm Zone 12
AD2USB Alarm Interface Device startup completed for Alarm Zone 12 Virtual
AD2USB Alarm Interface Device startup completed for Alarm Zone 2
AD2USB Alarm Interface Device startup completed for Alarm Zone 3
AD2USB Alarm Interface Device startup completed for Alarm Zone 4
AD2USB Alarm Interface Device startup completed for Alarm Zone 5
AD2USB Alarm Interface Device startup completed for Alarm Zone 6
AD2USB Alarm Interface Device startup completed for Alarm Zone 7
AD2USB Alarm Interface Device startup completed for Alarm Zone 8
AD2USB Alarm Interface Device startup completed for Alarm Zone 9
AD2USB Alarm Interface Device startup completed for Alarm Zone 9 Virtual
AD2USB Alarm Interface Enabling trigger:Burglar Alarm
AD2USB Alarm Interface Enabling trigger:Fire Alarm
AD2USB Alarm Interface AlarmDecoder message processing started
AD2USB Alarm Interface AlarmDecoder Firmware Version is: V2.2a.8.8
AD2USB Alarm Interface AlarmDecoder CONFIG message read: MODE=A&CONFIGBITS=ff05&ADDRESS=18&LRR=N&COM=N&EXP=YNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=Y
AD2USB Alarm Interface AlarmDecoder CONFIG setting are now: ADDRESS=18&LRR=N&EXP=YNNNN&REL=NNNN&DEDUPLICATE=Y
Dec 7, 2023 at 8:36:33 AM
AD2USB Alarm Interface Warning Invalid Numeric Code:107 found in KPM message:"CHECK 107 WIRE EXPANSION
(The warning is triggered every minute)
