Emergency Panic alarm-probably from AD2PI ?Plugin downgrade?
Fri Oct 06, 2023 9:13 am
mintzps offline
At 0923 my alarm went off with an Emergency Panic alarm.
It turns out that this is zone 99 and comes from the keypad panic # and * together.
Never had this happen before.
I can only think that this is from the AD2PI.
Here are the event log lines:
2023-10-06 09:23:53.307 AD2USB Alarm Interface Error Error reading from AlarmPanel:decoding bytes to string - error:'utf-8' codec can't decode byte 0x9a in position 3: invalid start byte
Here are the lines from the plugiin log:
2023-10-06 09:23:31.948 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:216 found in KPM message:"****DISARMED**** READY TO ARM ".
2023-10-06 09:23:37.221 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:216 found in KPM message:"****DISARMED**** READY TO ARM ".
2023-10-06 09:23:42.276 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:216 found in KPM message:"****DISARMED**** READY TO ARM ".
2023-10-06 09:23:47.601 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:216 found in KPM message:"****DISARMED**** READY TO ARM ".
2023-10-06 09:23:52.718 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:216 found in KPM message:"****DISARMED**** READY TO ARM ".
2023-10-06 09:23:53.306 ERROR 123145370869760 Plugin.panelReadWrapper: Error reading from AlarmPanel:decoding bytes to string - error:'utf-8' codec can't decode byte 0x9a in position 3: invalid start byte
2023-10-06 09:23:53.751 INFO 123145370869760 Plugin.setSerialConnection: attempting to connect to:socket://10.0.0.113:10000
2023-10-06 09:23:53.752 INFO 123145370869760 Plugin.setSerialConnection: connected to AlarmDecoder:socket://10.0.0.113:10000
2023-10-06 09:23:53.753 INFO 123145370869760 Plugin.panelReadWrapper: AlarmDecoder communication reset...
2023-10-06 09:23:58.999 INFO 123145370869760 Plugin.panelMsgRead: Alarm tripped by zone:099
2023-10-06 09:24:02.757 INFO 123145370869760 Plugin.panelMsgRead: Alarm tripped by zone:099
2023-10-06 09:24:04.933 INFO 123145370869760 Plugin.panelMsgRead: Alarm tripped by zone:099
2023-10-06 09:24:13.551 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:" DISARMED ZONES IN ALARM ".
2023-10-06 09:24:18.646 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:"ALARM 99 PANIC EMERGENCY ".
2023-10-06 09:24:23.939 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:" DISARMED ZONES IN ALARM ".
2023-10-06 09:24:29.116 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:"ALARM 99 PANIC EMERGENCY ".
2023-10-06 09:25:02.934 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:" DISARMED ZONES IN ALARM ".
2023-10-06 09:25:08.112 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:"ALARM 99 PANIC EMERGENCY ".
2023-10-06 09:25:13.316 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:" DISARMED ZONES IN ALARM ".
2023-10-06 09:25:18.504 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:"ALARM 99 PANIC EMERGENCY ".
2023-10-06 09:25:54.715 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:" DISARMED ZONES IN ALARM ".
2023-10-06 09:25:59.893 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:"ALARM 99 PANIC EMERGENCY ".
2023-10-06 09:26:05.071 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:" DISARMED ZONES IN ALARM ".
2023-10-06 09:26:10.289 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:"ALARM 99 PANIC EMERGENCY ".
2023-10-06 09:26:46.549 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:" DISARMED ZONES IN ALARM ".
2023-10-06 09:26:51.736 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:"ALARM 99 PANIC EMERGENCY ".
2023-10-06 09:26:57.133 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:" DISARMED ZONES IN ALARM ".
2023-10-06 09:27:02.209 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:"ALARM 99 PANIC EMERGENCY ".
2023-10-06 09:27:38.534 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:" DISARMED ZONES IN ALARM ".
2023-10-06 09:27:43.712 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:"ALARM 99 PANIC EMERGENCY ".
2023-10-06 09:27:48.902 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:" DISARMED ZONES IN ALARM ".
2023-10-06 09:27:54.080 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:"ALARM 99 PANIC EMERGENCY ".
2023-10-06 09:28:30.543 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:" DISARMED ZONES IN ALARM ".
2023-10-06 09:28:35.683 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:"ALARM 99 PANIC EMERGENCY ".
2023-10-06 09:28:40.820 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:" DISARMED ZONES IN ALARM ".
2023-10-06 09:28:45.998 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:"ALARM 99 PANIC EMERGENCY ".
2023-10-06 09:29:22.466 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:" DISARMED ZONES IN ALARM ".
2023-10-06 09:29:27.663 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:"ALARM 99 PANIC EMERGENCY ".
2023-10-06 09:29:32.839 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:" DISARMED ZONES IN ALARM ".
2023-10-06 09:29:38.031 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:"ALARM 99 PANIC EMERGENCY ".
2023-10-06 09:30:14.507 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:" DISARMED ZONES IN ALARM ".
2023-10-06 09:30:19.705 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:"ALARM 99 PANIC EMERGENCY ".
2023-10-06 09:30:25.060 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:" DISARMED ZONES IN ALARM ".
2023-10-06 09:30:30.141 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:"ALARM 99 PANIC EMERGENCY ".
2023-10-06 09:31:02.140 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:" DISARMED ZONES IN ALARM ".
2023-10-06 09:31:07.419 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:"ALARM 99 PANIC EMERGENCY ".
2023-10-06 09:31:12.613 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:" DISARMED ZONES IN ALARM ".
2023-10-06 09:31:17.823 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:"ALARM 99 PANIC EMERGENCY ".
2023-10-06 09:31:38.397 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:299 found in KPM message:" DISARMED Hit * for faults".
2023-10-06 09:31:40.319 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:216 found in KPM message:"FAULT 16 INSIDE GARAGE DOOR ".
2023-10-06 09:31:43.898 WARNING 123145370869760 Plugin.parseMessage_KPM: Invalid Numeric Code:216 found in KPM message:"****DISARMED**** READY TO ARM ".
Here are the lines from the Panel Messages log:
2023-10-06 09:23:37.220 | [10000001000000003A--],216,[f723d4001016801c080200002a2a20],"****DISARMED**** READY TO ARM "
2023-10-06 09:23:42.276 | [10000001000000003A--],216,[f723d4001016801c080200002a2a20],"****DISARMED**** READY TO ARM "
2023-10-06 09:23:47.600 | [10000001000000003A--],216,[f723d4001016801c080200002a2a20],"****DISARMED**** READY TO ARM "
2023-10-06 09:23:52.717 | [10000001000000003A--],216,[f723d4001016801c080200002a2a20],"****DISARMED**** READY TO ARM "
2023-10-06 09:23:56.552 | !ERR:4,4
2023-10-06 09:23:57.057 | !Sending.done
2023-10-06 09:23:57.702 | !KPE:12
2023-10-06 09:23:58.355 | !Sending.done
2023-10-06 09:23:58.995 | [00010701001000003A--],099,[f723d4001099870c09020000000000]," DISARMED ZONES IN ALARM "
2023-10-06 09:23:59.616 | !KPE:12
2023-10-06 09:24:00.266 | !Sending.done
2023-10-06 09:24:00.888 | !KPE:12
2023-10-06 09:24:02.752 | [00010701011000000A--],099,[f723d400109987000b020000000000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:24:04.290 | !KPE:01
2023-10-06 09:24:04.929 | [00010701001000003A--],099,[f723d4001099870c09020000000000]," DISARMED ZONES IN ALARM "
2023-10-06 09:24:05.575 | !KPE:01
2023-10-06 09:24:06.218 | !KPE:01
2023-10-06 09:24:07.170 | !KPE:01
2023-10-06 09:24:07.804 | [00010101010000000A--],099,[f723d400109901000a020000000000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:24:13.550 | [00010001000000003A--],299,[f723d4001099800c08020000020000]," DISARMED ZONES IN ALARM "
2023-10-06 09:24:18.646 | [00010001010000000A--],299,[f723d400109980000a020000020000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:24:23.939 | [00010001000000003A--],299,[f723d4001099800c08020000020000]," DISARMED ZONES IN ALARM "
2023-10-06 09:24:29.116 | [00010001010000000A--],299,[f723d400109980000a020000020000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:24:34.277 | [00010001000000003A--],099,[f723d4001099800c08020000000000]," DISARMED ZONES IN ALARM "
2023-10-06 09:24:39.602 | [00010001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:24:42.291 | !RFX:0938312,80
2023-10-06 09:24:44.697 | [00010001000000003A--],099,[f723d4001099800c08020000202045]," DISARMED ZONES IN ALARM "
2023-10-06 09:24:45.353 | !RFX:0938312,00
2023-10-06 09:24:47.501 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:24:52.647 | [00000001000000003A--],099,[f723d4001099800c08020000202045]," DISARMED ZONES IN ALARM "
2023-10-06 09:24:57.794 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:25:02.934 | [00000001000000003A--],299,[f723d4001099800c08020000020000]," DISARMED ZONES IN ALARM "
2023-10-06 09:25:08.111 | [00000001010000000A--],299,[f723d400109980000a020000020000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:25:09.614 | !RFX:0549148,04
2023-10-06 09:25:11.310 | !RFX:0298716,80
2023-10-06 09:25:13.316 | [00000001000000003A--],299,[f723d4001099800c08020000020000]," DISARMED ZONES IN ALARM "
2023-10-06 09:25:14.402 | !RFX:0298716,00
2023-10-06 09:25:18.504 | [00000001010000000A--],299,[f723d400109980000a020000020000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:25:23.712 | [00000001000000003A--],099,[f723d4001099800c08020000000000]," DISARMED ZONES IN ALARM "
2023-10-06 09:25:28.903 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:25:34.080 | [00000001000000003A--],099,[f723d4001099800c08020000202045]," DISARMED ZONES IN ALARM "
2023-10-06 09:25:39.217 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:25:44.355 | [00000001000000003A--],099,[f723d4001099800c08020000202045]," DISARMED ZONES IN ALARM "
2023-10-06 09:25:49.537 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:25:54.714 | [00000001000000003A--],299,[f723d4001099800c08020000020000]," DISARMED ZONES IN ALARM "
2023-10-06 09:25:59.892 | [00000001010000000A--],299,[f723d400109980000a020000020000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:26:05.071 | [00000001000000003A--],299,[f723d4001099800c08020000020000]," DISARMED ZONES IN ALARM "
2023-10-06 09:26:10.289 | [00000001010000000A--],299,[f723d400109980000a020000020000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:26:13.918 | !RFX:0607753,84
2023-10-06 09:26:15.498 | [00000001000000003A--],099,[f723d4001099800c08020000000000]," DISARMED ZONES IN ALARM "
2023-10-06 09:26:20.634 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:26:25.786 | [00000001000000003A--],099,[f723d4001099800c08020000202045]," DISARMED ZONES IN ALARM "
2023-10-06 09:26:30.977 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:26:36.169 | [00000001000000003A--],099,[f723d4001099800c08020000202045]," DISARMED ZONES IN ALARM "
2023-10-06 09:26:41.494 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:26:46.549 | [00000001000000003A--],299,[f723d4001099800c08020000020000]," DISARMED ZONES IN ALARM "
2023-10-06 09:26:51.736 | [00000001010000000A--],299,[f723d400109980000a020000020000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:26:57.133 | [00000001000000003A--],299,[f723d4001099800c08020000020000]," DISARMED ZONES IN ALARM "
2023-10-06 09:27:02.209 | [00000001010000000A--],299,[f723d400109980000a020000020000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:27:07.498 | [00000001000000003A--],099,[f723d4001099800c08020000000000]," DISARMED ZONES IN ALARM "
2023-10-06 09:27:12.676 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:27:17.853 | [00000001000000003A--],099,[f723d4001099800c08020000202045]," DISARMED ZONES IN ALARM "
2023-10-06 09:27:22.989 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:27:28.142 | [00000001000000003A--],099,[f723d4001099800c08020000202045]," DISARMED ZONES IN ALARM "
2023-10-06 09:27:33.320 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:27:38.534 | [00000001000000003A--],299,[f723d4001099800c08020000020000]," DISARMED ZONES IN ALARM "
2023-10-06 09:27:43.712 | [00000001010000000A--],299,[f723d400109980000a020000020000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:27:48.902 | [00000001000000003A--],299,[f723d4001099800c08020000020000]," DISARMED ZONES IN ALARM "
2023-10-06 09:27:54.080 | [00000001010000000A--],299,[f723d400109980000a020000020000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:27:59.268 | [00000001000000003A--],099,[f723d4001099800c08020000000000]," DISARMED ZONES IN ALARM "
2023-10-06 09:28:04.424 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:28:09.581 | [00000001000000003A--],099,[f723d4001099800c08020000202045]," DISARMED ZONES IN ALARM "
2023-10-06 09:28:14.893 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:28:20.151 | [00000001000000003A--],099,[f723d4001099800c08020000202045]," DISARMED ZONES IN ALARM "
2023-10-06 09:28:23.045 | !RFX:0311880,80
2023-10-06 09:28:25.346 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:28:25.996 | !RFX:0311880,00
2023-10-06 09:28:30.543 | [00000001000000003A--],299,[f723d4001099800c08020000020000]," DISARMED ZONES IN ALARM "
2023-10-06 09:28:35.683 | [00000001010000000A--],299,[f723d400109980000a020000020000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:28:40.820 | [00000001000000003A--],299,[f723d4001099800c08020000020000]," DISARMED ZONES IN ALARM "
2023-10-06 09:28:45.998 | [00000001010000000A--],299,[f723d400109980000a020000020000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:28:51.187 | [00000001000000003A--],099,[f723d4001099800c08020000000000]," DISARMED ZONES IN ALARM "
2023-10-06 09:28:56.364 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:29:01.553 | [00000001000000003A--],099,[f723d4001099800c08020000202045]," DISARMED ZONES IN ALARM "
2023-10-06 09:29:06.761 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:29:12.101 | [00000001000000003A--],099,[f723d4001099800c08020000202045]," DISARMED ZONES IN ALARM "
2023-10-06 09:29:17.178 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:29:22.466 | [00000001000000003A--],299,[f723d4001099800c08020000020000]," DISARMED ZONES IN ALARM "
2023-10-06 09:29:26.505 | !RFX:0316195,04
2023-10-06 09:29:27.663 | [00000001010000000A--],299,[f723d400109980000a020000020000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:29:32.839 | [00000001000000003A--],299,[f723d4001099800c08020000020000]," DISARMED ZONES IN ALARM "
2023-10-06 09:29:38.031 | [00000001010000000A--],299,[f723d400109980000a020000020000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:29:43.271 | [00000001000000003A--],099,[f723d4001099800c08020000000000]," DISARMED ZONES IN ALARM "
2023-10-06 09:29:48.469 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:29:53.759 | [00000001000000003A--],099,[f723d4001099800c08020000202045]," DISARMED ZONES IN ALARM "
2023-10-06 09:29:58.815 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:30:04.151 | [00000001000000003A--],099,[f723d4001099800c08020000202045]," DISARMED ZONES IN ALARM "
2023-10-06 09:30:09.328 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:30:14.507 | [00000001000000003A--],299,[f723d4001099800c08020000020000]," DISARMED ZONES IN ALARM "
2023-10-06 09:30:15.154 | !RFX:0938312,80
2023-10-06 09:30:18.557 | !RFX:0938312,00
2023-10-06 09:30:19.705 | [00000001010000000A--],299,[f723d400109980000a020000020000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:30:25.060 | [00000001000000003A--],299,[f723d4001099800c08020000020000]," DISARMED ZONES IN ALARM "
2023-10-06 09:30:30.141 | [00000001010000000A--],299,[f723d400109980000a020000020000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:30:35.440 | [00000001000000003A--],099,[f723d4001099800c08020000000000]," DISARMED ZONES IN ALARM "
2023-10-06 09:30:40.619 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:30:45.797 | [00000001000000003A--],099,[f723d4001099800c08020000202045]," DISARMED ZONES IN ALARM "
2023-10-06 09:30:50.974 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:30:56.162 | [00000001000000003A--],099,[f723d4001099800c08020000202045]," DISARMED ZONES IN ALARM "
2023-10-06 09:30:57.254 | !RFX:0041904,04
2023-10-06 09:30:59.395 | !RFX:0968286,84
2023-10-06 09:31:01.378 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:31:02.140 | [00000001000000003A--],299,[f723d4001099800c08020000020000]," DISARMED ZONES IN ALARM "
2023-10-06 09:31:07.419 | [00000001010000000A--],299,[f723d400109980000a020000020000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:31:10.612 | !RFX:0080617,84
2023-10-06 09:31:12.613 | [00000001000000003A--],299,[f723d4001099800c08020000020000]," DISARMED ZONES IN ALARM "
2023-10-06 09:31:14.968 | !RFX:0625129,04
2023-10-06 09:31:17.090 | !RFX:0106174,04
2023-10-06 09:31:17.822 | [00000001010000000A--],299,[f723d400109980000a020000020000],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:31:21.564 | [00000001000000003A--],099,[f723d4001099800c08020000000000]," DISARMED ZONES IN ALARM "
2023-10-06 09:31:26.864 | [00000001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:31:29.510 | [00000001000000003A--],099,[f723d4001099800c08020000202045]," DISARMED ZONES IN ALARM "
2023-10-06 09:31:30.160 | !KPE:01
2023-10-06 09:31:30.795 | [00010001010000000A--],099,[f723d400109980000a020000202020],"ALARM 99 PANIC EMERGENCY "
2023-10-06 09:31:31.429 | !KPE:01
2023-10-06 09:31:31.950 | !KPE:01
2023-10-06 09:31:32.591 | !KPE:01
2023-10-06 09:31:33.221 | [10010101000000003A--],099,[f723d4001099011c08020000202045],"****DISARMED**** READY TO ARM "
2023-10-06 09:31:37.447 | [10010001000000003A--],099,[f723d4001099801c08020000202020],"****DISARMED**** READY TO ARM "
2023-10-06 09:31:38.397 | [00010001000000003A--],299,[f723d4001099800c08020000020000]," DISARMED Hit * for faults"
2023-10-06 09:31:39.048 | !Sending.done
2023-10-06 09:31:39.692 | !KPE:12
2023-10-06 09:31:40.319 | [00010001000000000A--],216,[f723d4001016800008020000020000],"FAULT 16 INSIDE GARAGE DOOR "
2023-10-06 09:31:43.898 | [10010001000000003A--],216,[f723d4001016801c08020000020000],"****DISARMED**** READY TO ARM "
I can only think that it is the AD2PI that triggered it. I have been having more problems with using the AD2PI since going to the latest plugin.
I have downgraded the plugin to version 1.8.2
I am now getting the following messages in my event log:
Oct 6, 2023 at 11:02:13 AM
Error device "Alarm Keypad" state key displayState not defined (ignoring update request)
Oct 6, 2023 at 11:02:34 AM
Oct 6, 2023 at 11:03:05 AM
Oct 6, 2023 at 11:03:26 AM
Oct 6, 2023 at 11:03:58 AM
Oct 6, 2023 at 11:04:19 AM
This is annoying but not sure how to stop it.
Is there any issue with the downgrade right now?
Fri Oct 06, 2023 9:51 am
ab39870 offline
Re: Emergency Panic alarm-probably from AD2PI ?Plugin downgr
Sorry you're having these issues. It's definitely bad messages coming from the decoder. The why is the strange part. As versions were released, certain device states an even triggers were changed. I generally had kept this to a minimum.
You will need to re-create Keypad Devices and Zone Groups (if you use them). They certainly changed from v 1.8.
If you see more messages "Error device "<NAME>" state key <SOME_STATE_NAME not defined (ignoring update request)" you're going to want to recreate that device.
Fri Oct 06, 2023 1:57 pm
mintzps offline
What happens when version 1.8 won't work anymore?
Sat Oct 07, 2023 6:51 am
ab39870 offline
I believe you said you were running a network based AlarmDecoder. What are you running on your Raspberry Pi to connect from Indigo? Are you running the ser2sock daemon on the Pi? Or are you running AlarmDecoder's Keypad Program on Mac, Windows, or Linux (ref: https://www.alarmdecoder.com/wiki/index ... der_Keypad)?
I looked at the panelMessage log in some more detail today. It leads me to believe you are running a Keypad Emulator and using Indigo to connect that software.
2023-09-26 00:05:24.952   WARNING   123145399267328 Plugin.panelMsgRead: Unable to parse: - message:!boot....................
2023-09-26 00:05:25.548   WARNING   123145399267328 Plugin.panelMsgRead: Unable to parse: - message:!
2023-09-26 00:05:26.198   WARNING   123145399267328 Plugin.panelMsgRead: Unable to parse: - message:!Ademco Keypad Emulator V2.2a.8.8
2023-09-26 00:05:26.829   WARNING   123145399267328 Plugin.panelMsgRead: Unable to parse: - message:!Copyright (C) 2008-2015 Nu Tech Software Solutions, Inc.
2023-09-26 00:05:27.426   WARNING   123145399267328 Plugin.panelMsgRead: Unable to parse: - message:!Reproduction without permission is prohibited
2023-09-26 00:05:27.932   WARNING   123145399267328 Plugin.panelMsgRead: Unable to parse: - message:!By Sean Mathews <coder@f34r.com>
2023-09-26 00:05:28.564   WARNING   123145399267328 Plugin.panelMsgRead: Unable to parse: - message:!For support email AlarmDecoder@support.nutech.com
2023-09-26 00:05:29.204   WARNING   123145399267328 Plugin.panelMsgRead: Unable to parse: - message:!www.AlarmDecoder.com
2023-09-26 00:05:31.120   WARNING   123145399267328 Plugin.panelMsgRead: Unable to parse: - message:!Ready. Press ! for configuration.
2023-09-26 01:16:28.792   WARNING   123145399267328 Plugin.panelMsgRead: Unable to parse: - message:E11
2023-09-26 08:48:31.413   WARNING   123145399267328 Plugin.panelMsgRead: Unable to parse: - message:!sn:ffffffff
2023-09-26 08:48:35.393   WARNING   123145399267328 Plugin.panelMsgRead: Unable to parse: - message:!boot....................
2023-09-26 08:48:35.971   WARNING   123145399267328 Plugin.panelMsgRead: Unable to parse: - message:!
As for version 1.8.x, in summary: if you're going to use the latest supported version of Indigo, you need to be on the 3.x Plugin.
Indigo 2023.1 was released this month and no longer supports Python 2. See viewtopic.php?f=2&t=27476.
Some history: I took over plugin development from berkinet with version 1.6.1 in April 2022. I did this before Indigo announced their migration to Python 3. So while hadn't planned on making major changes to the plugin when I took it over, I had to make some changes to ensure Python 3 compatibility. Version 3.0 onward requires Python 3. Version 1.8.2 (the last Python 2 version) won't work with Indigo 2023.1 and onward. Given Indigo's path, I don't plan on making and changes to the 1.8.x code. But it's all on GitHub and available and anyone is welcome to it.
I also added support for the latest AlarmDecoder firmware in version 3.2.0. AlarmDecoder firmware versions 2.2a.6 and the newer version 2.2a.8.8 are the only two versions that I have tested and work with the plugin. AlarmDecoder made major changes to LRR messages in their latest firmware.
I don't recommend sticking w/1.8 for the long term. I appreciate everything was working fine before your upgrade. And I know that is frustrating. But I think you have something else going on.
Sat Oct 07, 2023 2:51 pm
mintzps offline
I understand that you came in in the middle and are in a difficult place.
I have a brand new AD2PI with the Raspberry Pi system as loaded by Alarm Decoder.
I used the Keypad Webapp provided by them to configure the AD2PI.
I know nothing about ser2sock . I think Alarm Decoder people have loaded it into the AD2PI.
I have to admit that I am "stupid" when it comes to Linux and certainly Python.
Basically, I just want to plug things in and have them work.
Right now, nothing works. I am using version 1.8.2 of the Plugin. Indigo 2022.2, and the firmware on the PI is 2.2a..8.8.
The keypad device doesn't have the current state. Right now the alarm is disarmed but the keypad status is as below
If you have any suggestions, including a detailed step by step process, to help me I would greatly appreciate it. Otherwise, I guess,bottom line, is that I am SOL and I just have to accept that.
Screenshot 2023-10-07 at 4.43.38 PM.png (435.77 KiB) Viewed 3293 times
Sat Oct 07, 2023 6:44 pm
ab39870 offline
I am wondering if you're running BOTH ser2sock and the Web Interface. That should be easy to check.
1. I am assuming you have a Pi with the AlarmDecoder image installed as referenced here: https://www.alarmdecoder.com/wiki/index ... spberry_Pi
2. Login to the Raspberry Pi via a terminal. Run the command:
ps -ef | grep ser2sock
If you see output similar to this, you're running ser2sock.
$ ps -ef | grep ser2sock
pi         341     1  0  2022 ?        2-23:56:16 /usr/local/bin/ser2sock -d -f /etc/ser2sock/ser2sock.conf -P /var/run/ser2sock/ser2sock.pid
3. Where is the AlarmDecoder WebApp running? The Pi? Your Mac w/Indigo? Another computer?
Sat Oct 07, 2023 8:01 pm
mintzps offline
I assume I am running with that version of the Alarm Decoder image.
I logged into the pi (a major step with Linux for me) and ran the command you suggested.
Here is the result:
pi@AlarmDecoder:~ $ ps -ef | grep ser2sock
pi 386 1 0 Sep27 ? 01:09:20 /usr/local/bin/ser2sock -d -f /etc/ser2sock/ser2sock.conf -P /var/run/ser2sock/ser2sock.pid
pi 3898 3883 0 18:45 pts/0 00:00:00 grep --color=auto ser2sock
pi@AlarmDecoder:~ $
I think that means that ser2sock is running.
I don't know where the WebApp is running. I access it like a web page from a browser on the Mac running the indigo local server and another Mac on the Network.
I use the address: http://alarmdecoder.local
I follow the documentation: https://www.alarmdecoder.com/wiki/index ... der_WebApp
Sun Oct 08, 2023 6:41 am
ab39870 offline
Yes, it looks like ser2sock is running. I am guessing both ser2sock and the AlarmDecoder Web App are both set to read from the serial port. It's just a guess, but that may be what is causing you trouble. If you're running ser2sock you want the WebApp to use that connection instead of connecting to the serial port. I use ser2sock (it is the default on AlarmDecoder's Pi image) and have no issues. Four steps to try this: check ser2sock settings, change WebApp Settings to use ser2sock, Reboot Pi, and upgrade to latest Plugin.
Step 1, confirm ser2sock settings. From a Terminal on your pi the cat command will list the contents of the ser2sock configuration file. The command is
cat /etc/ser2sock/ser2sock.conf
...and the output should look like this:
$ cat /etc/ser2sock/ser2sock.conf
# ser2sock sample configuration
[ser2sock]
# Fork into the background?  Default: 0
daemonize = 1
# Serial device
device = /dev/serial0
# Serial device baudrate
baudrate = 115200
# Port to listen for connections on.  Default: 10000
port = 10000
# Enable encryption?  Default: 0
#encrypted = 1
# CA certificate for this install
#ca_certificate = /etc/ser2sock/certs/ca.pem
# SSL certificate
#ssl_certificate = /etc/ser2sock/certs/server.pem
# SSL key
#ssl_key = /etc/ser2sock/certs/server.key
# SSL CRL location
#ssl_crl = /etc/ser2sock/ser2sock.crl
# Allow binding only to a specific interface.  Default: 0.0.0.0
#bind_ip = 127.0.0.1
# Send terminal init string.  Default: 0
#send_terminal_init = 0
# Raw communications mode disables all sending of !SER2SOCK messages. Default: 0
raw_device_mode = 1
# Keep incoming connections open when the serial device is disconnected?  Default: 0
preserve_connections = 1
# Delay (in milliseconds) between attempts to open the serial device.  Default: 5000
#device_open_delay = 5000
Please post your config file o the forum. There's nothing sensitive in it and it's probably the defaults. Take note of the port settings. Its is probably set to 10000 (the default).
Step 2, using the AlarmDecoder Web App run through the Initial Setup again. You can find this via the links for "Settings", "Advanced", and "Setup" from the Alarm Decoder Web App home page. This is the reference from AlarmDecoder for Setup. https://www.alarmdecoder.com/wiki/index ... tial_Setup. Follow along their guide and my notes below.
1. In the "Device Type Settings" screen, I am guess your "Device Location" is set to "Local Device." (I've attached the screen from the AlarmDecoder guide). Change it to "Network Device." This means the WebApp will communicate with the AlarmDecoder via ser2sock since that is already running versus over the serial port of the Raspberry Pi.
2. In the "Network Device Settings" enter the IP address for your Raspberry Pi in the "Address" field (I am guessing is is 10.0.0.113 from your logs) and the ser2sock port settings in the "Port field". This is probably 10000.
3. In the "AlarmDecoder Settings" make sure you're using "Honeywell/Ademco", the "Keypad Address" you configured on your panel is correct, the "AlarmDecoder Address Mask" is "FFFFFFFF" and select "Deduplicate messages." I am guessing you do not need to enable "Emulate Long Range Radio" or Zone and Relay expanders but I can't be sure. I recommend you leave it off if unsure.
Step 3. Once all those changes are made reboot your Pi. You can do this from the Terminal program with:
sudo reboot
Step 4. You're on the newer firmware so its best to go back to the latest version of the Plugin.
Sun Oct 08, 2023 10:16 am
mintzps offline
Here is what I got. I believe they match your post:
pi@AlarmDecoder:~ $ cat /etc/ser2sock/ser2sock.conf
[ser2sock]
daemonize = 1
# Serial device
baudrate = 115200
port = 10000
#encrypted = 1
# SSL certificate
# SSL key
# SSL CRL location
raw_device_mode = 1
I have used the WebApp to make your suggested changes.
The device location has always been set as a "network" device" not local.
I did change the address from "Local" to the IP adress of 10.0.0.113
The rest were already as you suggested.
Screenshot 2023-10-08 at 12.03.18 PM.png (243.18 KiB) Viewed 3202 times
Screenshot 2023-10-08 at 12.04.24 PM.png (217.42 KiB) Viewed 3202 times
Sun Oct 08, 2023 11:23 am
ab39870 offline
Any change in error messages after going to 3.x plugin?
Mon Oct 09, 2023 6:16 pm
mintzps offline
In short, no.
For a while I couldn't even talk to the Alarm Decoder. The server would time out trying to read the configuration. It was only after I created a new Keypad device and even saved the partition that I stopped getting the server timeout.
I am still getting the 216 and 116 error messages. If I do enable the "Deduplicate" they stop do stop coming but that, I think, is just hiding the problem.
