Yamaha RX Plugin - a/v receiver control
Thu Oct 01, 2015 10:24 am
Betacruxis offline
Re: Yamaha RX Plugin - a/v receiver control
Hello guys,
Any one had this plugin to work or is working on it?
I own a RX-V779BL and would like to be able to communicate with Indigo.
I'm stuck at the <type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'text' error.
Thanks in advance.
Thu Oct 01, 2015 10:30 am
Betacruxis offline
Thanks Ben,
I'm trying to use it with a RX-V779BL.
Cheers,
Alex
Thu Oct 08, 2015 1:33 pm
Betacruxis offline
Hello again,
Experimenting with the plugin, I advanced just a little.
I must say again, that I don't know anything about Python programing. I'm just using trial-an-error method,
Can anyone identify this Python error:
Yamaha RX Receiver Error Error in plugin execution ExecuteAction:
File "plugin.py", line 104, in putPower
<type 'exceptions.TypeError'>: cannot concatenate 'str' and 'Device' objects
Produced by this method:
def putPower(self, dev, val):
if dev is None:
self.debugLog(u"no device defined")
return
if val is None:
self.debugLog(u"value not defined")
return
xml_string = '<YAMAHA_AV cmd="PUT"><Main_Zone><Power_Control><Power>'+val+'</Power></Power_Control></Main_Zone></YAMAHA_AV>'
root = xmitToReceiver(dev, xml_string)
self.updateStatus(dev)
If we ca make it passing this Python error, we might get the plugin to work, even if it is partially.
Thanks for your time guys.
Regards,
Alejandro
Thu Oct 08, 2015 5:03 pm
Is line 104 this line?
If so, this function is expecting a string as argument 1, but you're sending it a device type object. We'll have to see the code for that function to be sure.
Also, please use the [ c o d e ] tags for actual code.
Thu Oct 08, 2015 5:05 pm
Wait, I missed the "+val+" in your xml string. What's the type of val?
Thu Oct 08, 2015 5:15 pm
Betacruxis offline
Hi Joe,
Thanks for your help.
Depending if you count the first line of code as "0", 104 will be "root = xmitToReceiver(dev, xml_string)"
But if the first line is "1", 104 is the one with the "+val+".
Looks to me that "val" is an integer, but when I tried to use the expression " + vas as string + ", it gave me another error regarding "pluginproperties".
Here are the 4 files composing the plug in:
plugin.py
#! /usr/bin/env python
# -*- coding: utf-8 -*-
import httplib, urllib2, sys, os
import xml.etree.cElementTree as ET
except ImportError:
import xml.etree.ElementTree as ET
def str2bool(v):
return v.lower() in ("yes", "true", "t", "1")
def xmitToReceiver(dev, xml_string):
url = 'http://'+dev.pluginProps['txtip']+'/YamahaRemoteControl/ctrl'
req = urllib2.Request(
url=url,
data=xml_string,
headers={'Content-Type': 'application/xml'})
resp = urllib2.urlopen(req)
status_xml = resp.read()
root = ET.fromstring(status_xml)
return root
def __init__(self, pluginId, pluginDisplayName, pluginVersion, pluginPrefs):
indigo.PluginBase.__init__(self, pluginId, pluginDisplayName, pluginVersion, pluginPrefs)
self.debug = True
def __del__(self):
def startup(self):
self.debugLog(u"startup called")
def shutdown(self):
self.debugLog(u"shutdown called")
def deviceStartComm(self, dev):
# helper methods, these mostly serve to facilitate calls to the device
def updateStatus(self, dev):
# get status from receiver, update locals
self.debugLog(u"updating status...")
if dev is None:
return
xml_string = '<YAMAHA_AV cmd="GET"><Main_Zone><Basic_Status>GetParam</Basic_Status></Main_Zone></YAMAHA_AV>'
#power = root.find("./Main_Zone/Basic_Status/Power_Control/Power").text
#sleep = root.find("./Main_Zone/Basic_Status/Power_Control/Sleep").text
#if(sleep!='Off'): sleep = "n"+sleep
#volume = root.find("./Main_Zone/Basic_Status/Vol/Lvl/Val").text
#mute = root.find("./Main_Zone/Basic_Status/Vol/Mute").text
#inputmode = root.find("./Main_Zone/Basic_Status/Input/Input_Sel").text
#dev.updateStateOnServer("power", power)
#dev.updateStateOnServer("sleep", sleep)
#dev.updateStateOnServer("volume", volume)
#dev.updateStateOnServer("mute", mute)
#dev.updateStateOnServer("input", inputmode)
def putMute(self, dev, val):
if dev is None:
return
if val is None:
return
xml_string = '<YAMAHA_AV cmd="PUT"><Main_Zone><Vol><Mute>'+val+'</Mute></Vol></Main_Zone></YAMAHA_AV>'
def putVolume(self, dev, val):
if dev is None:
return
if val is None:
return
xml_string = '<YAMAHA_AV cmd="PUT"><Main_Zone><Vol><Lvl><Val>'+val+'</Val><Exp>1</Exp><Unit>dB</Unit></Lvl></Vol></Main_Zone></YAMAHA_AV>'
if dev is None:
return
if val is None:
return
def putSleep(self, dev, val):
if dev is None:
return
if val is None:
return
xml_string = '<YAMAHA_AV cmd="PUT"><Main_Zone><Power_Control><Sleep>'+val+'</Sleep></Power_Control></Main_Zone></YAMAHA_AV>'
def putInput(self, dev, val):
if dev is None:
return
if val is None:
return
xml_string = '<YAMAHA_AV cmd="PUT"><Main_Zone><Input><Input_Sel>'+val+'</Input_Sel></Input></Main_Zone></YAMAHA_AV>'
def setInput(self, pluginAction, dev):
self.debugLog(u"setInput called")
val = pluginAction.props['ddlinput'].upper().replace(".","/").replace("_"," ")
self.putInput(dev, val)
Actions.xml
<?xml version="1.0"?>
<Actions>
<Action id="setVolume" deviceFilter="self">
<Name>Set Volume</Name>
<CallbackMethod>putVolume</CallbackMethod>
<ConfigUI>
<Field id="txtvolume" type="textfield" default="-30">
<Label>Level</Label>
<Description>in dB</Description>
</Field>
</ConfigUI>
</Action>
<Action id="increaseVolume" deviceFilter="self">
<Name>Increase Volume</Name>
<CallbackMethod>increaseVolume</CallbackMethod>
<ConfigUI>
<Field id="txtincrement" type="textfield" default="5">
<Label>Increment</Label>
</Field>
</ConfigUI>
</Action>
<Action id="decreaseVolume" deviceFilter="self">
<Name>Decrease Volume</Name>
<CallbackMethod>decreaseVolume</CallbackMethod>
<ConfigUI>
</Field>
</ConfigUI>
</Action>
<Action id="setMute" deviceFilter="self">
<Name>Set Mute</Name>
<CallbackMethod>putMute</CallbackMethod>
<ConfigUI>
<Field id="ddlmute" type="menu">
<Label>Set Mute</Label>
<List>
<Option value="On">On</Option>
<Option value="Off">Off</Option>
</List>
</Field>
</ConfigUI>
</Action>
<Action id="toggleMute" deviceFilter="self">
<Name>Toggle Mute</Name>
<CallbackMethod>toggleMute</CallbackMethod>
</Action>
<Action id="setPower" deviceFilter="self">
<Name>Set Power</Name>
<CallbackMethod>putPower</CallbackMethod>
<ConfigUI>
<Field id="ddlpower" type="menu">
<Label>Set Power</Label>
<List>
<Option value="Standby">Standby</Option>
</List>
</Field>
</ConfigUI>
</Action>
<Action id="togglePower" deviceFilter="self">
<Name>Toggle Power</Name>
<CallbackMethod>togglePower</CallbackMethod>
</Action>
<Action id="setSleep" deviceFilter="self">
<Name>Set Sleep</Name>
<CallbackMethod>putSleep</CallbackMethod>
<ConfigUI>
<Field id="ddlsleep" type="menu">
<Label>Set Sleep</Label>
<List>
<Option value="n30">30</Option>
<Option value="n60">60</Option>
<Option value="n90">90</Option>
<Option value="n120">120</Option>
</List>
</Field>
</ConfigUI>
</Action>
<Action id="setInput" deviceFilter="self">
<Name>Set Input</Name>
<CallbackMethod>setInput</CallbackMethod>
<ConfigUI>
<Field id="ddlinput" type="menu">
<Label>Set Input</Label>
<List>
<Option value="tuner">TUNER</Option>
<Option value="multi_ch">MULTI CH</Option>
<Option value="phono">PHONO</Option>
<Option value="cd">CD</Option>
<Option value="tv">TV</Option>
<Option value="md.cd-r">MD/CD-R</Option>
<Option value="bd.hd_dvd">BD/HD DVD</Option>
<Option value="dvd">DVD</Option>
<Option value="cbl.sat">CBL/SAT</Option>
<Option value="dvr">DVR</Option>
<Option value="vcr">VCR</Option>
<Option value="v-aux">V-AUX</Option>
<Option value="dock">DOCK</Option>
<Option value="pc.mcx">PC/MCX</Option>
<Option value="net_radio">NET RADIO</Option>
<Option value="usb">USB</Option>
</List>
</Field>
</ConfigUI>
</Action>
<Action id="getStatus" deviceFilter="self">
<Name>Get Status</Name>
<CallbackMethod>getStatus</CallbackMethod>
</Action>
</Actions>
Devices.xml
<Devices>
<Device type="custom" id="receiver">
<Name>Yamaha RX Series Receiver</Name>
<ConfigUI>
<Field id="txtip" type="textfield" default="192.168.1.4">
<Label>Receiver IP Address</Label>
<Description>enter the ip address of your reciever</Description>
</Field>
</ConfigUI>
<States>
<State id="power">
<ValueType>
<List>
</List>
</ValueType>
<TriggerLabel>Power</TriggerLabel>
<ControlPageLabel>Power</ControlPageLabel>
</State>
<State id="sleep">
<ValueType>
<List>
</List>
</ValueType>
<TriggerLabel>Sleep</TriggerLabel>
<ControlPageLabel>Sleep</ControlPageLabel>
</State>
<State id="volume">
<TriggerLabel>Volume</TriggerLabel>
<ControlPageLabel>Volume</ControlPageLabel>
</State>
<State id="mute">
<ValueType boolType="OnOff">Boolean</ValueType>
<TriggerLabel>Mute</TriggerLabel>
<ControlPageLabel>Mute</ControlPageLabel>
</State>
<State id="input">
<ValueType>
<List>
<Option value="sirius">SIRIUS</Option>
<Option value="xm">XM</Option>
<Option value="rhapsody">RHAPSODY</Option>
</List>
</ValueType>
<TriggerLabel>Input</TriggerLabel>
<ControlPageLabel>Input</ControlPageLabel>
</State>
</States>
</Device>
</Devices>
PluginConfig.xml
<PluginConfig>
<Field id="lblFoo" type="label">
<Label>No items to config.</Label>
</Field>
</PluginConfig>
Thu Oct 08, 2015 6:10 pm
See the green bar at the top of the posting window with the button that says "Code" on it? Please use it.
Python counts lines starting with 1. Giving you the exact line that throws the error is always handy.
If 'val' is an integer, change that line of code to
 ...'+ str(val) + '...
"val as string" is not Python. Is it C++?
Fri Oct 09, 2015 6:47 am
Betacruxis offline
Thanks again.
I don't really know, it could be C++.
I can barely program some Applescript.
I actually came with that solution as I found it in internet, in a Python forum.
I also don't have a Python editor. I'm using Xcode.
Sorry to bother you with all of this.
Although I can understand the "estructure and concept" of the plugin code, this is trial-and-error for me.
Since this plugin thread and the plugin itself is dead, I was just trying to make it work.
Trying your solution "+ str(val) +" gives the following error:
File "plugin.py", line 92, in putVolume
File "plugin.py", line 14, in xmitToReceiver
<type 'exceptions.AttributeError'>: 'PluginAction' object has no attribute 'pluginProps'
Line 14: url = 'http://'+dev.pluginProps['txtip']+'/YamahaRemoteControl/ctrl'
Line 92: xml_string = '<YAMAHA_AV cmd="PUT"><Main_Zone><Vol><Lvl><Val>'+ str(val) +'</Val><Exp>1</Exp><Unit>dB</Unit></Lvl></Vol></Main_Zone></YAMAHA_AV>'
And that one I don't really have any idea of what could it be.
Fri Oct 09, 2015 2:53 pm
Betacruxis offline
Oh, I'm sorry Joe about posting code as regular text.
I just got it...
I thought you were referring to a Python editor function, since we were talking about lines of code.
Sorry again.
Anyway, just in case it could be better, just downloaded Editra editor.
Regards,
Alejandro
Sat Oct 10, 2015 6:08 am
IMO, the best free programming editor for Macs is TextWrangler. It's the free version of BBEdit.
Sat Oct 10, 2015 6:29 am
+1 for TextWrangler. I use it every day.
Sat Oct 10, 2015 6:31 am
Fun tip for using TextWrangler - you can open the .plugin file wrapper in TextEdit, giving access to all the components of the plugin at the same time. ;)
Sat Oct 10, 2015 8:50 am
Yes, that's how I do it too. You can also run scripts right in TW to debug, or send them to the shell.
I was just running some UDP broadcast script tests in TW last night to fine tune a setting (running the script thousands of times).
Sun Oct 18, 2015 1:30 pm
BenX10 offline
Betacruxis:
Assumed you're using "my" version of the plugin it seems that your RX-V779 needs different command strings for power control than my RX-V775. Does yours have zone control? And if so do you have 3 different power control options in its web interface as shown in the attached screen shot? Did you find any documentation for your model how to control it by http commands?
Cheers,
Ben
Bereichsaufnahme 1.png (195.16 KiB) Viewed 24921 times
Sun Oct 18, 2015 2:39 pm
Betacruxis offline
Hi Ben,
Thanks again for your answer.
I am using the "original" plugin from "discgolfer1138" (Chad Francis / github.com), modified according to his website latest mods (Feb 2015).
Sadly seems that all his threads are dead.
In spite of that, I found that this receivers series share a lot of commands (also IR), so some of them might actually be working for both models.
I don't really know which is "your" version. Will be nice to try it, if you send me a link to download it.
As you mentioned, 779 has 2 zones, therefore 3 different power commands.
Thing is I cannot get the plugin working at all, because in spite I caught several errors, I still get some others regarding the ".py" file, which I have no idea what they are.
(Let me remind you I don't know Python programing)
Also, I couldn't yet find any documentation at all in reference to the http commands. I tried some commands manually (sort of RESTful URLs) and got no results. Just an unrelated "elapsed time" info of net radio.
Cheers,
Alejandro
