Oddball errors
Sun Jul 09, 2023 8:36 am
racarter offline
Re: Oddball errors
I can't see any instances of Ziggy on/off commands. Please could you turn off comms logging, turn on command logging, then turn Ziggy on and off. What's in the log after that?
New version in store should fix your 'permission deny' errors.
Sun Jul 09, 2023 1:57 pm
dlleon offline
Re: Oddball errors
like this?
Tuya No control functions available for Garage closet temp tuya
Tuya Sending {'commands': [{'code': 'switch_inching', 'value': True}]} to Ziggy Tuya
Tuya Starting Tuya monitoring thread
Tuya Error Ziggy Tuya 'on' command failed
Tuya {'code': 1104, 'msg': 'type is incorrect', 'success': False, 't': 1688932593256, 'tid': 'b4316ed31e9211ee804ade073cb82c5d'}
Tuya Sending {'commands': [{'code': 'switch_inching', 'value': False}]} to Ziggy Tuya
Tuya Error Ziggy Tuya 'off' command failed
Tuya {'code': 1104, 'msg': 'type is incorrect', 'success': False, 't': 1688932593702, 'tid': 'b470985a1e9211ee9fecaa50f188a4b0'}
Tuya Error Error getting readings for Tuya device
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1688932594080, 'tid': 'b4aeb0261e9211ee804ade073cb82c5d'}
Tuya Error Error getting info for Tuya device
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1688932594245, 'tid': 'b4bef9dd1e9211ee804ade073cb82c5d'}
Tuya Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 86, in runConcurrentThread
File "plugin.py", line 241, in getReadings
type: invalid literal for int() with base 10: '{"scene_num":24,"scene_units":[{"bright":0,"h":240,"s":1000,"temperature":0,"unit_change_mode":"gradient","unit_gradient_duration":70,"unit_switch_duration":70,"v":1000},{"bright":0,"h":220,"s":700,"
Tuya Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Tuya {'code': 1104, 'msg': 'type is incorrect', 'success': False, 't': 1688932594606, 'tid': 'b4fedd0a1e9211ee9fecaa50f188a4b0'}
Sun Jul 09, 2023 2:18 pm
racarter offline
Re: Oddball errors
Exactly like that - and it shows up the problem perfectly! That device has two different 'switch' commands and the plugin didn't know which one to use. Naturally, it picked the wrong one. ;)
I'll upload a new version to the store shortly.
Sun Jul 09, 2023 2:39 pm
dlleon offline
Re: Oddball errors
Thanks, you are awesome!
And this plug in is WONDERFUL!
(I had started switching everything over to Tuya before realizing there wasn't a plug in!)
Sun Jul 09, 2023 2:47 pm
racarter offline
Re: Oddball errors
Glad we got things sorted for you :)
Sun Jul 09, 2023 3:27 pm
dlleon offline
Re: Oddball errors
This one worked! The switch is working! WOOHOO!
Here's the latest log:
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1688938036228, 'tid': '607553c81e9f11ee804ade073cb82c5d'}
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1688938036317, 'tid': '6083e2411e9f11ee9fecaa50f188a4b0'}
Sun Jul 09, 2023 3:43 pm
racarter offline
Re: Oddball errors
I'd like to get to the bottom of that 'invalid literal' error. Could you switch on comms logging and capture the data immediately before that error comes up?
Sun Jul 09, 2023 4:05 pm
dlleon offline
Re: Oddball errors
Tuya Found control function for Bathroom temp tuya:
Tuya temp_unit_convert
Tuya Found control function for Bedroom TV plug tuya:
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya cycle_time
Tuya random_time
Tuya Found control function for Dining room Tuya Temp:
Tuya maxtemp_set
Tuya minitemp_set
Tuya maxhum_set
Tuya minihum_set
Tuya temp_sensitivity
Tuya hum_sensitivity
Tuya switch
Tuya Found control function for Equipment Closet Temp tuya:
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1688940264433, 'tid': '909174821ea411ee8c70fe98ebe72f12'}
Tuya Found control function for Garage temp tuya:
Tuya Found control function for Great room color lights tuya:
Tuya switch_led
Tuya work_mode
Tuya colour_data_v2
Tuya scene_data_v2
Tuya countdown_1
Tuya music_data
Tuya control_data
Tuya rhythm_mode
Tuya sleep_mode
Tuya wakeup_mode
Tuya power_memory
Tuya cycle_timing
Tuya random_timing
Tuya Found control function for Mud room temp tuya:
Tuya Found control function for Office printer tuya:
Tuya switch_led
Tuya colour_data
Tuya switch_1
Tuya Found control function for Outdoor patio temp:
Tuya maxtemp_set
Tuya minitemp_set
Tuya maxhum_set
Tuya minihum_set
Tuya switch
Tuya Found control function for outdoor side yard fence tuya:
Tuya switch_1
Tuya Found control function for outoor fence light:
Tuya switch_1
Tuya Found control function for Patio bug light tuya:
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya cycle_time
Tuya random_time
Tuya Found control function for Ziggy Tuya:
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya overcharge_switch
Tuya light_mode
Tuya child_lock
Tuya cycle_time
Tuya random_time
Tuya switch_inching
Tuya Device states for Bathroom temp tuya
Tuya {'result': [{'code': 'va_temperature', 'value': 197}, {'code': 'humidity_value', 'value': 61}, {'code': 'temp_unit_convert', 'value': 'f'}], 'success': True, 't': 1688940265468, 'tid': '912f85e51ea411ee9fecaa50f188a4b0'}
Tuya Device info for Bathroom temp tuya
Tuya {'result': {'active_time': 1655347592, 'category': 'wsdcg', 'category_name': 'Temperature and Humidity Sensor', 'create_time': 1655347592, 'gateway_id': '', 'icon': 'smart/icon/ay1525749833414yotNt/60d869bb20b0e1b0f0347a9fd8781a3c.png', 'id': 'ebe17135b2278aadc4ewri', 'ip': '104.50.216.93', 'lat': '32.9000', 'local_key': '668534a7d558d192', 'lon': '-96.7800', 'model': 'TH06WB3S', 'name': 'Master bath', 'online': True, 'owner_id': '72813327', 'product_id': '7akwzwfwhukkdsib', 'product_name': 'T & H Sensor', 'sub': False, 'time_zone': '-05:00', 'update_time': 1688937599, 'uuid': '7d1837d33d0d978d'}, 'success': True, 't': 1688940265570, 'tid': '914015e71ea411ee804ade073cb82c5d'}
Tuya Device states for Bedroom TV plug tuya
Tuya {'result': [{'code': 'switch_1', 'value': True}, {'code': 'countdown_1', 'value': 0}, {'code': 'add_ele', 'value': 13}, {'code': 'cur_current', 'value': 0}, {'code': 'cur_power', 'value': 0}, {'code': 'cur_voltage', 'value': 1197}, {'code': 'relay_status', 'value': 'power_on'}, {'code': 'cycle_time', 'value': ''}, {'code': 'random_time', 'value': ''}], 'success': True, 't': 1688940265678, 'tid': '914fd9cf1ea411ee8c70fe98ebe72f12'}
Tuya Device info for Bedroom TV plug tuya
Tuya {'result': {'active_time': 1657083137, 'category': 'cz', 'category_name': 'Socket', 'create_time': 1657083137, 'gateway_id': '', 'icon': 'smart/icon/ay15306906879543yc3O/e7a27577e2dbb5eb6ecefa2eaf5f6e25.jpg', 'id': 'eb24aba4aa31cd60b2oigl', 'ip': '104.50.216.93', 'lat': '32.8958', 'local_key': '43e944df0519e3cf', 'lon': '-96.7791', 'model': 'wifi计量插座', 'name': 'Bedroom tv plug', 'online': True, 'owner_id': '72813327', 'product_id': 'xf5vhc7zctkoe7pv', 'product_name': 'Smart Plug', 'sub': False, 'time_zone': '-05:00', 'update_time': 1688937619, 'uuid': 'c5013705d584a6bf'}, 'success': True, 't': 1688940265845, 'tid': '9161b70a1ea411ee804ade073cb82c5d'}
Tuya Device states for Dining room Tuya Temp
Tuya {'result': [{'code': 'va_temperature', 'value': 229}, {'code': 'va_humidity', 'value': 496}, {'code': 'battery_percentage', 'value': 10}, {'code': 'temp_unit_convert', 'value': 'f'}, {'code': 'maxtemp_set', 'value': 40}, {'code': 'minitemp_set', 'value': 10}, {'code': 'maxhum_set', 'value': 90}, {'code': 'minihum_set', 'value': 30}, {'code': 'temp_alarm', 'value': 'cancel'}, {'code': 'hum_alarm', 'value': 'loweralarm'}, {'code': 'bright_value', 'value': 67}, {'code': 'temp_sensitivity', 'value': 3}, {'code': 'hum_sensitivity', 'value': 5}, {'code': 'switch', 'value': False}], 'success': True, 't': 1688940265949, 'tid': '9179f5321ea411ee8c70fe98ebe72f12'}
Tuya Device info for Dining room Tuya Temp
Tuya {'result': {'active_time': 1654730762, 'category': 'wsdcg', 'category_name': 'Temperature and Humidity Sensor', 'create_time': 1653565550, 'gateway_id': '', 'icon': 'smart/icon/ay1522815888395iqsuQ/efec180637780e4c91208680ac12d111.png', 'id': 'ebc2d36daf2ab74d5blpyf', 'ip': '104.50.216.93', 'lat': '32.8958', 'local_key': 'f80f043c6c066aaf', 'lon': '-96.7791', 'model': 'NEO WIFI HT', 'name': 'Dining room', 'online': True, 'owner_id': '72813327', 'product_id': '0k8mzr1ajxzvj5ar', 'product_name': 'WIFI HT', 'sub': False, 'time_zone': '-05:00', 'update_time': 1688938478, 'uuid': 'ae33b6c517328b2f'}, 'success': True, 't': 1688940266104, 'tid': '9189cd4c1ea411ee804ade073cb82c5d'}
Tuya Device states for Equipment Closet Temp tuya
Tuya {'result': [{'code': 'va_temperature', 'value': 261}, {'code': 'humidity_value', 'value': 47}, {'code': 'temp_unit_convert', 'value': 'f'}], 'success': True, 't': 1688940266210, 'tid': '91a1aae21ea411ee804ade073cb82c5d'}
Tuya Device info for Equipment Closet Temp tuya
Tuya {'result': {'active_time': 1675996041, 'category': 'wsdcg', 'category_name': 'Temperature and Humidity Sensor', 'create_time': 1675996041, 'gateway_id': '', 'icon': 'smart/icon/ay1525749833414yotNt/60d869bb20b0e1b0f0347a9fd8781a3c.png', 'id': 'eb14138645cc2ea548f4zs', 'ip': '104.50.216.93', 'lat': '32.9000', 'local_key': '07f6ff9017f3f3f8', 'lon': '-96.7800', 'model': 'TH06WB3S', 'name': 'Equipment closet', 'online': True, 'owner_id': '72813327', 'product_id': '7akwzwfwhukkdsib', 'product_name': 'T & H Sensor', 'sub': False, 'time_zone': '-06:00', 'update_time': 1688937637, 'uuid': '18d49bbf3824f155'}, 'success': True, 't': 1688940266318, 'tid': '91b175f61ea411ee9fecaa50f188a4b0'}
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1688940266426, 'tid': '91c238211ea411ee8c70fe98ebe72f12'}
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1688940266525, 'tid': '91d265671ea411ee9fecaa50f188a4b0'}
Tuya Device states for Garage temp tuya
Tuya {'result': [{'code': 'va_temperature', 'value': 328}, {'code': 'humidity_value', 'value': 42}, {'code': 'temp_unit_convert', 'value': 'f'}], 'success': True, 't': 1688940266624, 'tid': '91e13abe1ea411ee804ade073cb82c5d'}
Tuya Device info for Garage temp tuya
Tuya {'result': {'active_time': 1664758916, 'category': 'wsdcg', 'category_name': 'Temperature and Humidity Sensor', 'create_time': 1653565959, 'gateway_id': '', 'icon': 'smart/icon/ay1525749833414yotNt/60d869bb20b0e1b0f0347a9fd8781a3c.png', 'id': 'ebe5167145c6680595bw3k', 'ip': '104.50.216.93', 'lat': '32.9000', 'local_key': '774279eb5186da1b', 'lon': '-96.7800', 'model': 'TH06WB3S', 'name': 'Garage temp', 'online': True, 'owner_id': '72813327', 'product_id': '7akwzwfwhukkdsib', 'product_name': 'T & H Sensor', 'sub': False, 'time_zone': '-05:00', 'update_time': 1688937600, 'uuid': '917564a22d1af0fd'}, 'success': True, 't': 1688940266733, 'tid': '91f0ae221ea411ee804ade073cb82c5d'}
Tuya Device states for Great room color lights tuya
Tuya {'result': [{'code': 'switch_led', 'value': False}, {'code': 'work_mode', 'value': 'colour'}, {'code': 'colour_data_v2', 'value': '{"h":240,"s":1000,"v":500}'}, {'code': 'scene_data_v2', 'value': '{"scene_num":24,"scene_units":[{"bright":0,"h":240,"s":1000,"temperature":0,"unit_change_mode":"gradient","unit_gradient_duration":70,"unit_switch_duration":70,"v":1000},{"bright":0,"h":220,"s":700,"temperature":0,"unit_change_mode":"gradient","unit_gradient_duration":70,"unit_switch_duration":70,"v":1000}]}'}, {'code': 'countdown_1', 'value': 0}, {'code': 'music_data', 'value': ''}, {'code': 'control_data', 'value': ''}, {'code': 'rhythm_mode', 'value': ''}, {'code': 'sleep_mode', 'value': ''}, {'code': 'wakeup_mode', 'value': ''}, {'code': 'power_memory', 'value': ''}, {'code': 'cycle_timing', 'value': ''}, {'code': 'random_timing', 'value': ''}], 'success': True, 't': 1688940266842, 'tid': '9201897c1ea411ee9fecaa50f188a4b0'}
Mon Jul 10, 2023 1:02 am
racarter offline
Re: Oddball errors
Try latest release.
Mon Jul 10, 2023 7:48 pm
dlleon offline
Re: Oddball errors
so close!
Tuya Error Error getting readings for Garage closet temp tuya
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1689040067274, 'tid': 'efb32f6d1f8c11ee8c70fe98ebe72f12'}
Tuya Error Error getting info for Garage closet temp tuya
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1689040067361, 'tid': 'efc218401f8c11ee804ade073cb82c5d'}
File "plugin.py", line 258, in getReadings
type: local variable 'colourTemp' referenced before assignment
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1689040080112, 'tid': 'f7532bc11f8c11ee8c70fe98ebe72f12'}
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1689040080203, 'tid': 'f76879cd1f8c11ee804ade073cb82c5d'}
dlleon offline
Re: Oddball errors
Mon Jul 10, 2023 10:32 pm
racarter offline
Re: Oddball errors
See new version in store. :)
Tue Jul 11, 2023 7:24 am
dlleon offline
Re: Oddball errors
The errors are getting shorter!
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1689081853077, 'tid': '39fa6ff21fee11ee804ade073cb82c5d'}
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1689081853160, 'tid': '3a09096e1fee11ee8c70fe98ebe72f12'}
File "plugin.py", line 219, in getReadings
type: list index out of range
Tue Jul 11, 2023 7:54 am
racarter offline
Re: Oddball errors
Latest version (in store now) should fix the 'index out of range' error.
No idea why you're getting the 'permission denied' error for one device. If you could go into the Tuya API Explorer and query the properties of that device, then query the properties of a device that works, and copy and paste the URLs the API Explorer uses it should help me find the problem.
Do you have any idea how hard it is to debug devices I don't have? ;) :P
Tue Jul 11, 2023 11:05 pm
dlleon offline
Re: Oddball errors
I think that did it!
It's still doing the permission deny, but now it's actually reporting the temp. I won't know until tomorrow if it's accurate (or an old temp) but wow!
