Oddball errors
Sat Jul 01, 2023 9:08 am
dlleon offline
Oddball errors
I have two Tuya devices enabled, both Temp sensors.
The first one, Dining Room, reports a Celsius temp, but with an "F" by it. I tried EPS to convert the C to the F, to no avail.
The second one, a Temp / Humid sensor is in an equipment closet. It's reporting "0" as the temp and throwing errors.
I've put the log entires below.
What am I doing wrong?
Tuya Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Tuya Starting Tuya monitoring thread
Tuya Device states for Dining room Temp (Tuya)
Tuya {'result': [{'code': 'va_temperature', 'value': 229}, {'code': 'va_humidity', 'value': 586}, {'code': 'battery_percentage', 'value': 10}, {'code': 'temp_unit_convert', 'value': 'f'}, {'code': 'maxtemp_set', 'value': 40}, {'code': 'minitemp_set', 'value': 10}, {'code': 'maxhum_set', 'value': 90}, {'code': 'minihum_set', 'value': 30}, {'code': 'temp_alarm', 'value': 'cancel'}, {'code': 'hum_alarm', 'value': 'loweralarm'}, {'code': 'bright_value', 'value': 0}, {'code': 'temp_sensitivity', 'value': 3}, {'code': 'hum_sensitivity', 'value': 5}, {'code': 'switch', 'value': False}], 'success': True, 't': 1688223932399, 'tid': 'b9696f8b182011ee8c70fe98ebe72f12'}
Tuya Device info for Dining room Temp (Tuya)
Tuya {'result': {'active_time': 1654730762, 'category': 'wsdcg', 'category_name': 'Temperature and Humidity Sensor', 'create_time': 1653565550, 'gateway_id': '', 'icon': 'smart/icon/ay1522815888395iqsuQ/efec180637780e4c91208680ac12d111.png', 'id': 'ebc2d36daf2ab74d5blpyf', 'ip': '104.50.216.93', 'lat': '32.8958', 'local_key': 'f80f043c6c066aaf', 'lon': '-96.7791', 'model': 'NEO WIFI HT', 'name': 'Dining room', 'online': True, 'owner_id': '72813327', 'product_id': '0k8mzr1ajxzvj5ar', 'product_name': 'WIFI HT', 'sub': False, 'time_zone': '-05:00', 'update_time': 1688223460, 'uuid': 'ae33b6c517328b2f'}, 'success': True, 't': 1688223932537, 'tid': 'b976a802182011ee8c70fe98ebe72f12'}
Tuya Device states for Equipment Closet (Tuya sensor)
Tuya {'result': [{'code': 'va_temperature', 'value': 274}, {'code': 'humidity_value', 'value': 47}, {'code': 'temp_unit_convert', 'value': 'f'}], 'success': True, 't': 1688223932633, 'tid': 'b98c0c95182011ee9fecaa50f188a4b0'}
Tuya Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 81, in runConcurrentThread
File "plugin.py", line 132, in getReadings
type: list index out of range
NEST Home New Protect added to indigo: Guest Room Nest Protect
Tuya {'result': [{'code': 'va_temperature', 'value': 229}, {'code': 'va_humidity', 'value': 586}, {'code': 'battery_percentage', 'value': 10}, {'code': 'temp_unit_convert', 'value': 'f'}, {'code': 'maxtemp_set', 'value': 40}, {'code': 'minitemp_set', 'value': 10}, {'code': 'maxhum_set', 'value': 90}, {'code': 'minihum_set', 'value': 30}, {'code': 'temp_alarm', 'value': 'cancel'}, {'code': 'hum_alarm', 'value': 'loweralarm'}, {'code': 'bright_value', 'value': 0}, {'code': 'temp_sensitivity', 'value': 3}, {'code': 'hum_sensitivity', 'value': 5}, {'code': 'switch', 'value': False}], 'success': True, 't': 1688223942745, 'tid': 'bf92a8b2182011ee9fecaa50f188a4b0'}
Tuya {'result': {'active_time': 1654730762, 'category': 'wsdcg', 'category_name': 'Temperature and Humidity Sensor', 'create_time': 1653565550, 'gateway_id': '', 'icon': 'smart/icon/ay1522815888395iqsuQ/efec180637780e4c91208680ac12d111.png', 'id': 'ebc2d36daf2ab74d5blpyf', 'ip': '104.50.216.93', 'lat': '32.8958', 'local_key': 'f80f043c6c066aaf', 'lon': '-96.7791', 'model': 'NEO WIFI HT', 'name': 'Dining room', 'online': True, 'owner_id': '72813327', 'product_id': '0k8mzr1ajxzvj5ar', 'product_name': 'WIFI HT', 'sub': False, 'time_zone': '-05:00', 'update_time': 1688223460, 'uuid': 'ae33b6c517328b2f'}, 'success': True, 't': 1688223942908, 'tid': 'bfa1626a182011ee804ade073cb82c5d'}
Tuya {'result': [{'code': 'va_temperature', 'value': 274}, {'code': 'humidity_value', 'value': 47}, {'code': 'temp_unit_convert', 'value': 'f'}], 'success': True, 't': 1688223943010, 'tid': 'bfba7bc1182011ee8c70fe98ebe72f12'}
Mon Jul 03, 2023 2:48 am
racarter offline
Re: Oddball errors
The problem is that your temperature sensors are not reporting some values the plugin expects to see, so any values after the missing ones aren't processed correctly.
I've uploaded a new version of the plugin which should handle cases like this.
Sat Jul 08, 2023 12:05 am
dlleon offline
Re: Oddball errors
It's reporting the temp, but it looks like it's in C not F. It's set to F on the Tuya App and the local display has F.
I tried EPS to convert it, but EPS Device extensions can't fix it.
Sat Jul 08, 2023 4:08 am
racarter offline
Re: Oddball errors
Devices always report temperatures in degC but send a flag to indicate degF is required. Turns out that the plugin has to do the conversion.
New version in store.
Sat Jul 08, 2023 8:50 am
dlleon offline
Re: Oddball errors
I have the new version loaded, still getting this:
Started plugin "Tuya 2022.6.3"
Tuya Starting Tuya plugin
File "plugin.py", line 139, in getCommands
type: ('result',)
Tuya Error Error in plugin execution ExecuteAction:
File "plugin.py", line 481, in actionControlDevice
type: ('ebde4418ef1785bd74awbh',)
type: ('result',)
type: ('result',)
Sat Jul 08, 2023 9:40 am
racarter offline
Re: Oddball errors
This error signifies that the plugin cannot retrieve the device's control function list from the Tuya servers. I've added code to enable a listing of found functions to the Event Log if you have the comms tickbox ticked, and also some error handling if the device is not reporting any control functions - although this would seem strange for a plug or bulb device...
Update in store.
Sat Jul 08, 2023 10:20 am
dlleon offline
Re: Oddball errors
I think you're on to something!
All the plugs except Ziggy are now working!
File "plugin.py", line 85, in runConcurrentThread
File "plugin.py", line 174, in getReadings
Tuya Error Ziggy Tuya 'on' command failed
Tuya {'code': 1104, 'msg': 'type is incorrect', 'success': False, 't': 1688833150819, 'tid': '2be13ce31dab11ee8c70fe98ebe72f12'}
Tuya Found control function for Bathroom temp tuya:
Tuya temp_unit_convert
Tuya Found control function for Bedroom TV plug tuya:
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya cycle_time
Tuya random_time
Tuya Found control function for Dining room Tuya Temp:
Tuya maxtemp_set
Tuya minitemp_set
Tuya maxhum_set
Tuya minihum_set
Tuya temp_sensitivity
Tuya hum_sensitivity
Tuya switch
Tuya Found control function for Equipment Closet Temp tuya:
Tuya Cannot get control functions for Garage closet temp tuya
Tuya Found control function for Garage temp tuya:
Tuya Found control function for Great room color lights tuya:
Tuya switch_led
Tuya work_mode
Tuya colour_data_v2
Tuya scene_data_v2
Tuya countdown_1
Tuya music_data
Tuya control_data
Tuya rhythm_mode
Tuya sleep_mode
Tuya wakeup_mode
Tuya power_memory
Tuya cycle_timing
Tuya random_timing
Tuya Found control function for Mud room temp tuya:
Tuya Found control function for Office printer tuya:
Tuya switch_led
Tuya colour_data
Tuya switch_1
Tuya Found control function for Outdoor patio temp:
Tuya maxtemp_set
Tuya minitemp_set
Tuya maxhum_set
Tuya minihum_set
Tuya switch
Tuya Found control function for outdoor side yard fence tuya:
Tuya switch_1
Tuya Found control function for outoor fence light:
Tuya switch_1
Tuya Found control function for Patio bug light tuya:
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya cycle_time
Tuya random_time
Tuya Found control function for Ziggy Tuya:
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya overcharge_switch
Tuya light_mode
Tuya child_lock
Tuya cycle_time
Tuya random_time
Tuya switch_inching
Tuya Device states for Bathroom temp tuya
Tuya {'result': [{'code': 'va_temperature', 'value': 211}, {'code': 'humidity_value', 'value': 61}, {'code': 'temp_unit_convert', 'value': 'f'}], 'success': True, 't': 1688833153819, 'tid': '2dab75b01dab11ee9fecaa50f188a4b0'}
Tuya Error Ziggy Tuya 'off' command failed
Tuya {'code': 1104, 'msg': 'type is incorrect', 'success': False, 't': 1688833156382, 'tid': '2f33495b1dab11ee804ade073cb82c5d'}
Tuya {'code': 1104, 'msg': 'type is incorrect', 'success': False, 't': 1688833157460, 'tid': '2fcebe181dab11ee8c70fe98ebe72f12'}
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya cycle_time
Tuya random_time
Tuya maxtemp_set
Tuya minitemp_set
Tuya maxhum_set
Tuya minihum_set
Tuya switch
Tuya switch_led
Tuya work_mode
Tuya colour_data_v2
Tuya scene_data_v2
Tuya countdown_1
Tuya music_data
Tuya control_data
Tuya rhythm_mode
Tuya sleep_mode
Tuya wakeup_mode
Tuya power_memory
Tuya cycle_timing
Tuya random_timing
Tuya switch_led
Tuya colour_data
Tuya switch_1
Tuya maxtemp_set
Tuya minitemp_set
Tuya maxhum_set
Tuya minihum_set
Tuya switch
Tuya switch_1
Tuya switch_1
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya cycle_time
Tuya random_time
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya light_mode
Tuya child_lock
Tuya cycle_time
Tuya random_time
Tuya switch_inching
Tuya {'result': [{'code': 'va_temperature', 'value': 211}, {'code': 'humidity_value', 'value': 61}, {'code': 'temp_unit_convert', 'value': 'f'}], 'success': True, 't': 1688833165277, 'tid': '347ad0d81dab11ee9fecaa50f188a4b0'}
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya cycle_time
Tuya random_time
Sat Jul 08, 2023 10:35 am
racarter offline
Re: Oddball errors
Could you let me have log entries for device states and device info for Ziggy?
Sat Jul 08, 2023 12:10 pm
dlleon offline
Re: Oddball errors
Like this?
Tuya {'code': 1104, 'msg': 'type is incorrect', 'success': False, 't': 1688839813341, 'tid': 'af0e1c671dba11ee8c70fe98ebe72f12'}
Sat Jul 08, 2023 1:06 pm
racarter offline
Re: Oddball errors
No - I mean the data that’s returned for that device during normal polling.
Sat Jul 08, 2023 5:35 pm
dlleon offline
Re: Oddball errors
Hmm.. does this help?
Tuya {'result': [{'code': 'va_temperature', 'value': 222}, {'code': 'humidity_value', 'value': 57}, {'code': 'temp_unit_convert', 'value': 'f'}], 'success': True, 't': 1688859284228, 'tid': '049b862c1de811ee9fecaa50f188a4b0'}
Tuya {'code': 1104, 'msg': 'type is incorrect', 'success': False, 't': 1688859286423, 'tid': '05e9144c1de811ee9fecaa50f188a4b0'}
Tuya {'code': 1104, 'msg': 'type is incorrect', 'success': False, 't': 1688859286926, 'tid': '06368d8a1de811ee8c70fe98ebe72f12'}
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya cycle_time
Tuya random_time
Tuya maxtemp_set
Tuya minitemp_set
Tuya maxhum_set
Tuya minihum_set
Tuya switch
Tuya switch_led
Tuya work_mode
Tuya colour_data_v2
Tuya scene_data_v2
Tuya countdown_1
Tuya music_data
Tuya control_data
Tuya rhythm_mode
Tuya sleep_mode
Tuya wakeup_mode
Tuya power_memory
Tuya cycle_timing
Tuya random_timing
Tuya switch_led
Tuya colour_data
Tuya switch_1
Tuya maxtemp_set
Tuya minitemp_set
Tuya maxhum_set
Tuya minihum_set
Tuya switch
Tuya switch_1
Tuya switch_1
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya cycle_time
Tuya random_time
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya light_mode
Tuya child_lock
Tuya cycle_time
Tuya random_time
Tuya switch_inching
Tuya {'result': [{'code': 'va_temperature', 'value': 222}, {'code': 'humidity_value', 'value': 57}, {'code': 'temp_unit_convert', 'value': 'f'}], 'success': True, 't': 1688859295783, 'tid': '0b7e35c11de811ee9fecaa50f188a4b0'}
Sat Jul 08, 2023 10:53 pm
racarter offline
Re: Oddball errors
I was looking for something like this, but for Ziggy:
Sat Jul 08, 2023 11:59 pm
dlleon offline
Re: Oddball errors
I think I got it at the bottom
Tuya {'code': 1104, 'msg': 'type is incorrect', 'success': False, 't': 1688882357010, 'tid': 'bd0f518c1e1d11ee804ade073cb82c5d'}
Tuya {'code': 1104, 'msg': 'type is incorrect', 'success': False, 't': 1688882357309, 'tid': 'bd3cdcc81e1d11ee804ade073cb82c5d'}
Tuya {'code': 1104, 'msg': 'type is incorrect', 'success': False, 't': 1688882357490, 'tid': 'bd563a541e1d11ee9fecaa50f188a4b0'}
Tuya {'code': 1104, 'msg': 'type is incorrect', 'success': False, 't': 1688882357625, 'tid': 'bd6d0bd91e1d11ee804ade073cb82c5d'}
Tuya {'code': 1104, 'msg': 'type is incorrect', 'success': False, 't': 1688882357800, 'tid': 'bd87b8c71e1d11ee804ade073cb82c5d'}
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya cycle_time
Tuya random_time
Tuya maxtemp_set
Tuya minitemp_set
Tuya maxhum_set
Tuya minihum_set
Tuya switch
Tuya switch_led
Tuya work_mode
Tuya colour_data_v2
Tuya scene_data_v2
Tuya countdown_1
Tuya music_data
Tuya control_data
Tuya rhythm_mode
Tuya sleep_mode
Tuya wakeup_mode
Tuya power_memory
Tuya cycle_timing
Tuya random_timing
Tuya switch_led
Tuya colour_data
Tuya switch_1
Tuya maxtemp_set
Tuya minitemp_set
Tuya maxhum_set
Tuya minihum_set
Tuya switch
Tuya switch_1
Tuya switch_1
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya cycle_time
Tuya random_time
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya light_mode
Tuya child_lock
Tuya cycle_time
Tuya random_time
Tuya switch_inching
Tuya {'result': [{'code': 'va_temperature', 'value': 196}, {'code': 'humidity_value', 'value': 52}, {'code': 'temp_unit_convert', 'value': 'f'}], 'success': True, 't': 1688882359725, 'tid': 'beac779d1e1d11ee8c70fe98ebe72f12'}
Tuya {'code': 1104, 'msg': 'type is incorrect', 'success': False, 't': 1688882364084, 'tid': 'c145ec7a1e1d11ee8c70fe98ebe72f12'}
Tuya {'code': 1104, 'msg': 'type is incorrect', 'success': False, 't': 1688882364213, 'tid': 'c15a4a3b1e1d11ee804ade073cb82c5d'}
Tuya {'code': 1104, 'msg': 'type is incorrect', 'success': False, 't': 1688882364354, 'tid': 'c16ebcb11e1d11ee8c70fe98ebe72f12'}
Sun Jul 09, 2023 12:17 am
racarter offline
Re: Oddball errors
I need to see Device States and Device Info. Don’t try to operate the device; just enable comms logging and let it run for a minute.
Also, I've uploaded a new version with an additional Config tick box to log commands sent. Please tick this then try to operate Ziggy and post the result.
Sun Jul 09, 2023 7:06 am
dlleon offline
Re: Oddball errors
You are too awesome. Okay, here's a new log dump, with the new module and the new log ticked:
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya cycle_time
Tuya random_time
Tuya maxtemp_set
Tuya minitemp_set
Tuya maxhum_set
Tuya minihum_set
Tuya switch
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1688907956648, 'tid': '57a0680f1e5911ee804ade073cb82c5d'}
Tuya switch_led
Tuya work_mode
Tuya colour_data_v2
Tuya scene_data_v2
Tuya countdown_1
Tuya music_data
Tuya control_data
Tuya rhythm_mode
Tuya sleep_mode
Tuya wakeup_mode
Tuya power_memory
Tuya cycle_timing
Tuya random_timing
Tuya switch_led
Tuya colour_data
Tuya switch_1
Tuya maxtemp_set
Tuya minitemp_set
Tuya maxhum_set
Tuya minihum_set
Tuya switch
Tuya switch_1
Tuya switch_1
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya cycle_time
Tuya random_time
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya light_mode
Tuya child_lock
Tuya cycle_time
Tuya random_time
Tuya switch_inching
Tuya {'result': [{'code': 'va_temperature', 'value': 189}, {'code': 'humidity_value', 'value': 71}, {'code': 'temp_unit_convert', 'value': 'f'}], 'success': True, 't': 1688907957606, 'tid': '5832807d1e5911ee8c70fe98ebe72f12'}
File "plugin.py", line 86, in runConcurrentThread
File "plugin.py", line 187, in getReadings
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya cycle_time
Tuya random_time
Tuya maxtemp_set
Tuya minitemp_set
Tuya maxhum_set
Tuya minihum_set
Tuya switch
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1688907968093, 'tid': '5e742e521e5911ee804ade073cb82c5d'}
Tuya switch_led
Tuya work_mode
Tuya colour_data_v2
Tuya scene_data_v2
Tuya countdown_1
Tuya music_data
Tuya control_data
Tuya rhythm_mode
Tuya sleep_mode
Tuya wakeup_mode
Tuya power_memory
Tuya cycle_timing
Tuya random_timing
Tuya switch_led
Tuya colour_data
Tuya switch_1
Tuya maxtemp_set
Tuya minitemp_set
Tuya maxhum_set
Tuya minihum_set
Tuya switch
Tuya switch_1
Tuya switch_1
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya cycle_time
Tuya random_time
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya light_mode
Tuya child_lock
Tuya cycle_time
Tuya random_time
Tuya switch_inching
Tuya {'result': [{'code': 'va_temperature', 'value': 189}, {'code': 'humidity_value', 'value': 71}, {'code': 'temp_unit_convert', 'value': 'f'}], 'success': True, 't': 1688907969251, 'tid': '5f2444a31e5911ee804ade073cb82c5d'}
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya cycle_time
Tuya random_time
Tuya maxtemp_set
Tuya minitemp_set
Tuya maxhum_set
Tuya minihum_set
Tuya switch
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1688907979789, 'tid': '656c6b651e5911ee8c70fe98ebe72f12'}
DSC Alarm Alarm Zone 'Alarm zone 4 family motion' Opened.
Tuya switch_led
Tuya work_mode
Tuya colour_data_v2
Tuya scene_data_v2
Tuya countdown_1
Tuya music_data
Tuya control_data
Tuya rhythm_mode
Tuya sleep_mode
Tuya wakeup_mode
Tuya power_memory
Tuya cycle_timing
Tuya random_timing
Tuya switch_led
Tuya colour_data
Tuya switch_1
Tuya maxtemp_set
Tuya minitemp_set
Tuya maxhum_set
Tuya minihum_set
Tuya switch
Tuya switch_1
Tuya switch_1
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya cycle_time
Tuya random_time
Tuya switch_1
Tuya countdown_1
Tuya relay_status
Tuya light_mode
Tuya child_lock
Tuya cycle_time
Tuya random_time
Tuya switch_inching
Tuya {'result': [{'code': 'va_temperature', 'value': 189}, {'code': 'humidity_value', 'value': 71}, {'code': 'temp_unit_convert', 'value': 'f'}], 'success': True, 't': 1688907980796, 'tid': '6605a90f1e5911ee9fecaa50f188a4b0'}
DSC Alarm Alarm Zone 'Alarm zone 4 family motion' Closed.
