Below are the errors as well as the detailed communications logs. Do I have a setting wrong?
Tuya Error Error getting readings for Tuya device
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1679013174371, 'tid': '41cc0e99c45b11edb7680e743b151476'}
Tuya Error Error getting info for Tuya device
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1679013174478, 'tid': '41dfad1ec45b11eda2c5dae7169ea2b8'}
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1679013174608, 'tid': '41eff6a7c45b11edb7680e743b151476'}
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1679013174712, 'tid': '42034066c45b11eda2c5dae7169ea2b8'}
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1679013174842, 'tid': '4214423dc45b11edaf0496a4ff7c2925'}
Tuya {'code': 1106, 'msg': 'permission deny', 'success': False, 't': 1679013174953, 'tid': '4227b32bc45b11edb7680e743b151476'}
Tuya Device states for Birch Tree 1
Tuya {'result': [{'code': 'switch_led', 'value': True}, {'code': 'work_mode', 'value': 'white'}, {'code': 'bright_value_v2', 'value': 1000}, {'code': 'temp_value_v2', 'value': 1000}, {'code': 'colour_data_v2', 'value': '{"h":0,"s":0,"v":1000}'}, {'code': 'scene_data_v2', 'value': '{"scene_num":1,"scene_units":[{"bright":200,"h":0,"s":0,"temperature":0,"unit_change_mode":"static","unit_gradient_duration":13,"unit_switch_duration":14,"v":0}]}'}, {'code': 'countdown_1', 'value': 0}, {'code': 'music_data', 'value': ''}, {'code': 'control_data', 'value': ''}, {'code': 'rhythm_mode', 'value': 'AAAAAAA='}, {'code': 'sleep_mode', 'value': 'AAA='}, {'code': 'wakeup_mode', 'value': 'AAA='}, {'code': 'power_memory', 'value': 'AAEAfAPoA+gD6AAn'}, {'code': 'do_not_disturb', 'value': False}, {'code': 'remote_switch', 'value': True}, {'code': 'cycle_timing', 'value': 'AAAA'}, {'code': 'random_timing', 'value': 'AAAA'}], 'success': True, 't': 1679013175068, 'tid': '42382ffcc45b11eda2c5dae7169ea2b8'}
Tuya Device info for Birch Tree 1
Tuya {'result': {'active_time': 1670369417, 'category': 'dj', 'category_name': 'Light Source', 'create_time': 1670369417, 'gateway_id': '', 'icon': 'smart/icon/bay1639113809492JnLT/af29a8edfcad3e09eb5a7cc5222d4557.png', 'id': 'eb8d28258adccc1a64aewq', 'ip': '173.73.126.188', 'lat': '38.7877', 'local_key': 'b742da5e2a785f4a', 'lon': '-77.4259', 'model': 'SPC2-3W-MR16', 'name': 'Birch Tree Up-light 1', 'online': True, 'owner_id': '90495352', 'product_id': 'tkkcdfxabavpsshj', 'product_name': 'YX-WIFI-CB2S-5L-1', 'sub': False, 'time_zone': '-05:00', 'update_time': 1678911062, 'uuid': 'a6e2d4e836689f6a'}, 'success': True, 't': 1679013175321, 'tid': '424a5586c45b11edaf0496a4ff7c2925'}
Tuya Device states for Birch Tree 2
Tuya {'result': [{'code': 'switch_led', 'value': True}, {'code': 'work_mode', 'value': 'white'}, {'code': 'bright_value_v2', 'value': 1000}, {'code': 'temp_value_v2', 'value': 1000}, {'code': 'colour_data_v2', 'value': '{"h":0,"s":0,"v":10700}'}, {'code': 'scene_data_v2', 'value': '{"scene_num":1,"scene_units":[{"bright":200,"h":0,"s":0,"temperature":0,"unit_change_mode":"static","unit_gradient_duration":13,"unit_switch_duration":14,"v":0}]}'}, {'code': 'countdown_1', 'value': 0}, {'code': 'music_data', 'value': ''}, {'code': 'control_data', 'value': ''}, {'code': 'rhythm_mode', 'value': 'AAAAAAA='}, {'code': 'sleep_mode', 'value': 'AAA='}, {'code': 'wakeup_mode', 'value': 'AAA='}, {'code': 'power_memory', 'value': 'AAEAAAAAKcwD6APo'}, {'code': 'do_not_disturb', 'value': False}, {'code': 'remote_switch', 'value': True}, {'code': 'cycle_timing', 'value': 'AAAA'}, {'code': 'random_timing', 'value': 'AAAA'}], 'success': True, 't': 1679013175440, 'tid': '42708e39c45b11edaf0496a4ff7c2925'}
Tuya Device info for Birch Tree 2
Tuya {'result': {'active_time': 1670368515, 'category': 'dj', 'category_name': 'Light Source', 'create_time': 1670368515, 'gateway_id': '', 'icon': 'smart/icon/bay1639113809492JnLT/af29a8edfcad3e09eb5a7cc5222d4557.png', 'id': 'eb156bd147ec5f8634wf4j', 'ip': '173.73.126.188', 'lat': '38.7876', 'local_key': 'a33418fb9d552786', 'lon': '-77.4259', 'model': 'SPC2-3W-MR16', 'name': 'Birch Tree Up-light 2', 'online': True, 'owner_id': '90495352', 'product_id': 'tkkcdfxabavpsshj', 'product_name': 'YX-WIFI-CB2S-5L-1', 'sub': False, 'time_zone': '-05:00', 'update_time': 1673230638, 'uuid': '386652376aa22995'}, 'success': True, 't': 1679013175627, 'tid': '42829c38c45b11edaf0496a4ff7c2925'}
Tuya Device states for Birch Tree 3
Tuya {'result': [{'code': 'switch_led', 'value': True}, {'code': 'work_mode', 'value': 'white'}, {'code': 'bright_value_v2', 'value': 1000}, {'code': 'temp_value_v2', 'value': 1000}, {'code': 'colour_data_v2', 'value': '{"h":0,"s":0,"v":10980}'}, {'code': 'scene_data_v2', 'value': '{"scene_num":1,"scene_units":[{"bright":200,"h":0,"s":0,"temperature":0,"unit_change_mode":"static","unit_gradient_duration":13,"unit_switch_duration":14,"v":0}]}'}, {'code': 'countdown_1', 'value': 0}, {'code': 'music_data', 'value': ''}, {'code': 'control_data', 'value': ''}, {'code': 'rhythm_mode', 'value': 'AAAAAAA='}, {'code': 'sleep_mode', 'value': 'AAA='}, {'code': 'wakeup_mode', 'value': 'AAA='}, {'code': 'power_memory', 'value': 'AAEAcgPoA+gD6APo'}, {'code': 'do_not_disturb', 'value': False}, {'code': 'remote_switch', 'value': True}, {'code': 'cycle_timing', 'value': 'AAAA'}, {'code': 'random_timing', 'value': 'AAAA'}], 'success': True, 't': 1679013175739, 'tid': '429f2118c45b11eda2c5dae7169ea2b8'}
Tuya Device info for Birch Tree 3
Tuya {'result': {'active_time': 1670366960, 'category': 'dj', 'category_name': 'Light Source', 'create_time': 1670366960, 'gateway_id': '', 'icon': 'smart/icon/bay1639113809492JnLT/af29a8edfcad3e09eb5a7cc5222d4557.png', 'id': 'eb6be9a019a1a0a734ahzo', 'ip': '173.73.126.188', 'lat': '38.7877', 'local_key': 'cf7c307118f832c4', 'lon': '-77.4259', 'model': 'SPC2-3W-MR16', 'name': 'Birch Tree Up-light 3', 'online': True, 'owner_id': '90495352', 'product_id': 'tkkcdfxabavpsshj', 'product_name': 'YX-WIFI-CB2S-5L-1', 'sub': False, 'time_zone': '-05:00', 'update_time': 1676849709, 'uuid': '66fe458df3e00c8b'}, 'success': True, 't': 1679013175901, 'tid': '42afa92bc45b11edb7680e743b151476'}
