Plugin won't load
Tue Mar 14, 2023 4:31 pm
7rdr7 offline
Plugin won't load
Thanks for creating this plugin! Looking forward to getting my devices into Indigo. After installing the plugin, I get the following error in the logs:
Tuya Error Error in plugin execution InitializeMain:
File "plugin.py", line 15, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/Plugins/Tuya.IndigoPlugin/Contents/Server Plugin/tuya_iot/__init__.py", line 2, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/Plugins/Tuya.IndigoPlugin/Contents/Server Plugin/tuya_iot/device.py", line 11, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/Plugins/Tuya.IndigoPlugin/Contents/Server Plugin/tuya_iot/openmq.py", line 13, in <module>
type: No module named 'Crypto'
Stopping plugin "Tuya 2022.2.0" (pid 68005)
The plugin shows a "red" status. I tried downgrading to prior releases, but no change. Do I need to install something else first? I have the bulbs already running in the Tuya app on my iPhone and in Homebridge. Appreciate any guidance. Thanks again!
Wed Mar 15, 2023 5:36 am
siclark offline
Re: Plugin won't load
You need to install the cryptography module.
Pip3 install cryptography
Wed Mar 15, 2023 8:16 am
7rdr7 offline
Thanks siclark. I checked, and it appears that cryptography is already installed.
mediaserver@Pine-Island ~ % Pip3 install cryptography
Requirement already satisfied: cryptography in /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages (37.0.2)
Requirement already satisfied: cffi>=1.12 in /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages (from cryptography) (1.15.0)
Requirement already satisfied: pycparser in /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages (from cffi>=1.12->cryptography) (2.21)
mediaserver@Pine-Island ~ % pip3 show cryptography
Version: 37.0.2
Summary: cryptography is a package which provides cryptographic recipes and primitives to Python developers.
Home-page: https://github.com/pyca/cryptography
Author: The Python Cryptographic Authority and individual contributors
Author-email: cryptography-dev@python.org
License: BSD-3-Clause OR Apache-2.0
Location: /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages
Requires: cffi
Required-by:
Wed Mar 15, 2023 9:25 am
CliveS offline
Looks like you are running an older version (37.0.2), the latest is 39.0.2 so try
pip3 install --upgrade cryptography
CliveS
Wed Mar 15, 2023 9:36 am
7rdr7 offline
Thanks for the suggestion. Upgraded cryptography, restarted, still the same issue:
mediaserver@Pine-Island ~ % pip3 install --upgrade cryptography
Collecting cryptography
Downloading cryptography-39.0.2-cp36-abi3-macosx_10_12_x86_64.whl (2.9 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.9/2.9 MB 12.9 MB/s eta 0:00:00
Installing collected packages: cryptography
Attempting uninstall: cryptography
Found existing installation: cryptography 37.0.2
Uninstalling cryptography-37.0.2:
Successfully uninstalled cryptography-37.0.2
Successfully installed cryptography-39.0.2
Reloading plugin "Tuya 2022.2.0" using API v3.0
Starting plugin "Tuya 2022.2.0" (pid 2945)
Stopping plugin "Tuya 2022.2.0" (pid 2945)
Stopped plugin "Tuya 2022.2.0"
Wed Mar 15, 2023 9:48 am
siclark offline
I’m sure the plug-in is python 3 but maybe try above with pip and not pip3?
Wed Mar 15, 2023 9:53 am
7rdr7 offline
Tried that, no change:
mediaserver@Pine-Island ~ % pip install --upgrade cryptography
Requirement already satisfied: cryptography in /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages (39.0.2)
Wed Mar 15, 2023 11:31 am
racarter offline
Try this:
pip3 install Crypto
Then navigate to:
Macintosh HD/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages
and rename folder 'crypto' to 'Crypto'
** Note that if the Python version has changed you'll need to replace the 3.11s in the above path with the new version number. **
If you get error messages saying Crypto is missing when you start the plugin (sometimes happens with M1 Macs) just copy the version I've included in the Resources folder of the Tapo plugin to the above folder.
This sounds more complicated than it is, but unfortunately it's necessary because the Crypto library has to be installed manually. Several other plugin developers have encountered the same issue, and there seems to be no other way around it.
I missed the fact that this might be required for Tuya. I'd already had to do this for Tapo, so didn't notice.
Wed Mar 15, 2023 11:51 am
7rdr7 offline
Thanks! I followed your instructions and now get:
Disabling plugin "Tuya 2022.2.0"
Enabling plugin "Tuya 2022.2.0" using API v3.0
Starting plugin "Tuya 2022.2.0" (pid 3017)
type: No module named 'Crypto.Cipher'
Is this where I need to install your Tapo plugin, then copy the Resources folder?
Wed Mar 15, 2023 12:06 pm
racarter offline
Actually, if you look in the Resources folder of the Tuya plugin you'll find the folder you need to copy over. :)
Wed Mar 15, 2023 12:14 pm
7rdr7 offline
So I copy the Cypher folder from within the Tuya plugin Resource folder into the Crypto folder within site-packages? Sorry for being a bit of a neophyte.....
Wed Mar 15, 2023 12:16 pm
racarter offline
Not quite. REPLACE the Crypto folder in site packages with the one in my plugin.
Wed Mar 15, 2023 12:20 pm
7rdr7 offline
That's it! Thanks!!
Wed Mar 15, 2023 12:23 pm
racarter offline
Great! I've posted a sticky for others to follow.. :)
Tue Apr 09, 2024 4:23 pm
mgolden50 offline
I've been struggling to get the Taco plugin to load.
I have used pip3 to install Crypto to no avail.
I''m using a M1 Mac and after the install I look here ‭Macintosh HD/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages to find the Crypto folder but none exists.
I need to install the folder said to be available in the plug-in but can't locate it. Can someone provide me with more detail on where to find the Crypto folder in the plug-in?
