Requires Indigo 2023.2 - Will not run on earlier versions!
Changes since version 2023.0.66, include:
- Improved python package handling
- Handle MQTT topics produced by Zigbee2mqtt running under Home Assistant with Home Assistant Integration turned on
- Add support for Aqara knob H1 (wireless)
- Add support for Multi Switch e.g. Aqara (Xiaomi QBKG41LM) E1 2 gang switch (with neutral).
- Add tighter integration with indigo for Aqara (Xiaomi ZNXNKG02LM) knob H1 (wireless) by adding a positive only rotation percentage state and updating a user specified variable so that a trigger can be defined for indigo to set device dimmer values from the variable value.
- Add support for Multi Switch e.g. Aqara (Xiaomi QBKG40LM) E1 single gang switch (with neutral).
- Add support for XY Colour
- Rotary Dimmer Enhancements to correctly update associated variable (see edit Device Settings). Also adds in a rotation factor which is used to multiply the returned value so that the value can be increased or decreased at a quicker rate when rotating the dimmer knob.
- Code improvements
