Error after Indigo update and various plugin
Sun Nov 19, 2023 11:40 am
MarcoGT offline
I have update Indigo to 2023.1.1 and a couple of plugins (I do not remember if related to MQTT and Zigbee2MQTT was also updated).
Now I have following error:
Zigbee2mqtt Bridge Error        ''ZD_FRIENDLY_NAME'' in module 'plugin.py', method 'action_control_device'
   Failing statement [line 227]: 'friendly_name = self.globals[ZD][zigbee_coordinator_ieee][zigbee_device_ieee][ZD_FRIENDLY_NAME]'
I noticed that the Zigbee Device in the Edit menu is empty I cannot select anything, that is really strange
Plug-in restart does not help (MQTT plugin neither).
Any hint?
Mon Nov 20, 2023 4:10 am
MarcoGT offline
Re: Error after Indigo update and various plugin
I have solved the problem by restarting the Zigbee2MQTT process.
Mon Nov 20, 2023 1:12 pm
autolog offline
Pleased you have recovered Zigbee access. :)
