Devices not responding/updating 2023.2 [Fixed in1.2.26]
Thu Jan 25, 2024 3:01 pm
GlennNZ offline
Re: Devices not responding/updating after update to 2023.2
Thanks.
Have isolated and reproduced the problem.
Relates to the incorrect version of Cryptography being installed. A new incompatible version was released 2 days ago , and since packages only downloaded once/on first install I haven't seen it.
Nothing to do with Intel and ARM.
Question is
- Why wrong version installed?
- to Fix
Work-around at very least won't take very long.
Glenn
Thu Jan 25, 2024 3:17 pm
GlennNZ offline
New version 1.2.26
In store.
https://www.indigodomo.com/pluginstore/283/
Fixes on my testing. Please double check everyone!
Cryptography one of the main crypto libraries, only in the last 2 days has had a breaking new release (this is why I didn't see, as installed a few days earlier that 2 days)
pyatv dist packages is not following its own requirements and uses this new now breaking library…. I have raised an issue there.. but can overcome here by forcing the version before the pyatv library.
Thu Jan 25, 2024 3:20 pm
7rdr7 offline
I noticed from @Korey post that I was a release behind on pyatv. I upgraded to the latest. Reloaded plugin and no change. Also interesting, the plugin will find my old AirPort Express audio device, but none of my "current" devices.
Started plugin "appleTV Plugin 1.2.20"
   appleTV Plugin                  appleTV Bedroom TV Device has been Setup, attempting to connect.
   appleTV Plugin                  appleTV Kitchen Device has been Setup, attempting to connect.
   appleTV Plugin                  appleTV Media Room TV Device has been Setup, attempting to connect.
   appleTV Plugin                  appleTV Pool Airplay Device has been Setup, attempting to connect.
   appleTV Plugin                  HomePod Bedroom 1 Device has been Setup, attempting to connect.
   appleTV Plugin                  HomePod Bedroom 2 Device has been Setup, attempting to connect.
   appleTV Plugin                  HomePod Family Room 1 Device has been Setup, attempting to connect.
   appleTV Plugin                  HomePod Family Room 2 Device has been Setup, attempting to connect.
   appleTV Plugin                  HomePod Kitchen1 Device has been Setup, attempting to connect.
   appleTV Plugin                  HomePod Kitchen2 Device has been Setup, attempting to connect.
   appleTV Plugin                  HomePod Office Device has been Setup, attempting to connect.
   appleTV Plugin                  Scanning for device using IP address: 192.168.1.229 and using Unicast.
   appleTV Plugin                  Scanning for device using IP address: 192.168.1.118 and using Unicast.
   appleTV Plugin                  Scanning for device using IP address: 192.168.1.249 and using Unicast.
   appleTV Plugin                  Scanning for device using IP address: 192.168.1.250 and using Unicast.
   appleTV Plugin                  Scanning for device using IP address: 192.168.1.245 and using Unicast.
   appleTV Plugin                  Scanning for device using IP address: 192.168.1.241 and using Unicast.
   appleTV Plugin                  Scanning for device using IP address: 192.168.1.244 and using Unicast.
   appleTV Plugin                  Scanning for device using IP address: 192.168.1.145 and using Unicast.
   appleTV Plugin                  Scanning for device using IP address: 192.168.1.242 and using Unicast.
   appleTV Plugin                  Scanning for device using IP address: 192.168.1.240 and using Unicast.
   appleTV Plugin                  Scanning for device using IP address: 192.168.1.246 and using Unicast.
   appleTV Plugin                  appleTV Pool Airplay successfully connected and real-time Push updating enabled. (if available!)
Thu Jan 25, 2024 3:23 pm
7rdr7 offline
That seems to work for me. I'll report back if otherwise. Thanks!!!
Thu Jan 25, 2024 3:37 pm
Korey offline
Thanks Glenn!!!
:D :D :D
   Upgrading plugin appleTV Plugin to newer version 1.2.26 (previous version moved to trash)
   Loading plugin "appleTV Plugin 1.2.26" using API v3.4
   Starting plugin "appleTV Plugin 1.2.26" (pid 13093)
   Processing requirements for plugin "appleTV Plugin 1.2.26"
   Requirements installing, this may take a few seconds...
   Finished installing requirements for "appleTV Plugin 1.2.26", continuing startup
   appleTV Plugin
   appleTV Plugin                  ================================================ Initializing New Plugin Session =================================================
   appleTV Plugin                  Plugin name:                   appleTV Plugin
   appleTV Plugin                  Plugin version:                1.2.26
   appleTV Plugin                  Plugin ID:                     com.GlennNZ.indigoplugin.appleTV
   appleTV Plugin                  Indigo version:                2023.2.0
   appleTV Plugin                  Silicon version:               arm64
   appleTV Plugin                  Ffmpeg Path:                   /Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/appleTV.indigoPlugin/Contents/Packages/homekitlink_ffmpeg/ffmpeg_binaries/arm/ffmpeg
   appleTV Plugin                  Python version:                3.11.6 (v3.11.6:8b6ee5ba3b, Oct  2 2023, 11:18:21) [Clang 13.0.0 (clang-1300.0.29.30)]
   appleTV Plugin                  Python Directory:              /Library/Frameworks/Python.framework/Versions/3.11
   appleTV Plugin
   appleTV Plugin                  ================================================== End Initializing New Plugin  ==================================================
   Started plugin "appleTV Plugin 1.2.26"
   appleTV Plugin                  appleTV Bedroom ATV Device has been Setup, attempting to connect.
   appleTV Plugin                  appleTV Great Room Device has been Setup, attempting to connect.
   appleTV Plugin                  appleTV Theatre ATV Device has been Setup, attempting to connect.
   appleTV Plugin                  Scanning for device using IP address: 192.168.0.200 and using Unicast.
   appleTV Plugin                  Scanning for device using IP address: 192.168.0.201 and using Unicast.
   appleTV Plugin                  Scanning for device using IP address: 192.168.0.202 and using Unicast.
   appleTV Plugin                  Connecting to 192.168.0.201
   appleTV Plugin                  Connecting to 192.168.0.202
   appleTV Plugin                  Connecting to 192.168.0.200
   appleTV Plugin                  appleTV Theatre ATV successfully connected and real-time Push updating enabled. (if available!)
   appleTV Plugin                  appleTV Bedroom ATV successfully connected and real-time Push updating enabled. (if available!)
   appleTV Plugin                  appleTV Great Room successfully connected and real-time Push updating enabled. (if available!)
Korey
Thu Jan 25, 2024 5:10 pm
Re: Devices not responding/updating 2023.2 [Fixed in1.2.26]
Yep that seems to have solved it!
Thu Jan 25, 2024 5:40 pm
GlennNZ offline
Thumbs Up Emoji!
Thu Jan 25, 2024 6:13 pm
Thanks for all the effort you’ve put in with this. It’s really appreciated!
