HomePod support..?
Sat Dec 03, 2022 6:27 pm
durosity offline
HomePod support..?
I know you didn’t plan to add HomePod support to this plugin, but it does seem to find all my HomePods, and the atv GitHub repo has many people reporting it works fine with theirs so I’m hoping there’s a way to get them to work here too. The problem I’m having is that when I try to pair nothing happens on the HomePod. As best I can tell it’s supposed to read out the code, but nothing happens.. any ideas?
Mon Dec 05, 2022 2:01 pm
GlennNZ offline
Re: HomePod support..?
Hi
Unfortunately don’t have a HomePod to test with - although did look… but a bit Alexa dominant in this household and suspect the WAF would drop - with Alexa/Siri confusion!
There also may be some OS16 issues..
Can you PM me a log of the attempt? I’ll have a look - hopefully something simple….
Glenn
Thu Dec 08, 2022 4:17 am
GlennNZ offline
Fixed the lack of a Homepod to test with…
Try version 0.1.1
On github now
Should enable HomePod support and a few other changes…
Glenn
Sat Dec 10, 2022 12:29 am
GlennNZ offline
0.1.1- 0.1.10
Adds & Extend Homepod support
0.1.9-0.1.10
Add Action Group to Send Text to Speech annoucement to HomePods with current OSX System voice
(Change current voice in OSX settings voices)
Allows Device and Variable subsitution so can read weather forcast etc. depending on setup
NEEDS ffmpeg (included in plugin), likely to need quaranatine command run on new install
Add messaging for this.
Converts text to speech with system say command and then converts to mp3 for playback. Add a slight delay but seems to be under a second in my testing.
0.1.1
Add support for Homepod and potentially other devices...
Notes for HomePods
These devices do not need to be paired - but once created setup the connect in the Device Edit screen
Play_URL for Homepod reports unsupported.
However Stream_File, or the Remote setting:
"Stream local file or remote file to device"
Works
Optional Argumment:
https://www.soundhelix.com/examples/mp3 ... Song-1.mp3
or
Local file: (like)
/Users/Indigo/Desktop/doorbell-1.mp3
Works.
To generate voice file:
In terminal
say "Person arrived Home" -o personhome.aiff
Homepod Stream File seems to need a mp3 files
ffmpeg commandline tool can convert say generated aiff
ffmpeg -i Input.aiff -f mp3 -acodec libmp3lame -ab 192000 -ar 44100 Output.mp3
Tempted to add a Action Group to automate all this.. (done in new version 0.1.9 above)
Homepod:
Appears Pause/Play toggle button unsupported.
But volume control and seperate play, and Pause button function fine.
The above Stream file means can use TTS and play your own mp3 files as annoucement action Groups
Sat Dec 10, 2022 9:09 am
durosity offline
Hey sorry for my lack of reply, I’m actually on holiday in NYC at the moment but I will test it out when I get home!
Sun Jan 08, 2023 5:12 pm
durosity offline
Just FYI this seems to be working well! Thank you very much :D
Fri Mar 10, 2023 12:13 pm
anyone offline
Wow! Just wow. Thanks for creating this and then making it so damn flexible.
I got the Text-to-Speech working on a HomePod. I am wondering if you have any suggestions on this implementation.
My solution was to place a bash script in '/Library/Application Support/Perceptive Automation/Scripts' that creates the audio files and does the conversions, storing the files in /tmp.
I then created an Action Group to play the /tmp/output.mp3 on the HomePod with your appleTV Plugin Action.
Then I created a Trigger to watch a variable. When the variable changes, it runs the script, that plays the speech file, on the HomePod.
convert_to_speech.sh
#!/bin/bash
if [ -z "$1" ]
  then
    echo "No argument supplied. Please provide a string to convert to speech."
    exit 1
fi
# Convert text to AIFF audio file, save to /tmp
say "$1" -o /tmp/convertedTo.aiff
# Convert AIFF audio file to MP3 using ffmpeg, save to /tmp
/Library/Application\ Support/Perceptive\ Automation/Indigo\ 2022.2/Plugins/appleTV.indigoPlugin/Contents/Server\ Plugin/ffmpeg/ffmpeg -i /tmp/convertedTo.aiff -y -f mp3 -acodec libmp3lame -ab 192000 -ar 44100 /tmp/output.mp3
Fri Mar 10, 2023 12:55 pm
anyone offline
I see it now. I took the long way.. you modified it so you don't have to do that. Just do the announce plugin action.
Awesome.
