Add Garage Door to Alexa
Fri Sep 08, 2023 5:53 am
MarcoGT offline
Hi all,
I have managed to add a Shelly Plus 1 to Indigo and it works; I have also added to Alexa and set it as "Garage Door Controller"; if I says "Alexa open Garage Door", it asks me for the code, and gives me confirmation but it does not open; it gets opened if I say "Close Garage Door" :D
What am I missing?
Marco
Sat Sep 09, 2023 9:39 am
aaronlionsheep offline
Re: Add Garage Door to Alexa
Does your garage door open correctly when controlling it directly in the Indigo UI?
I'm not an Alexa user, so I want to just eliminate as much as possible first to ensure my plugins aren't causing any issues.
Mon Sep 11, 2023 12:40 pm
MarcoGT offline
Hi Aaron,
To be honest I am a little bit lost.
I created the device and if I am right three devices are actually created (the main one, switch and input).
When turning on the switch it worked (garage door open) but when turning it off nothing happened, I had to turning it on again (auto-off) is set to 20s.
Then everything stopped working and I deleted it.
I try to create it again and I will report back.
