Issues with ShellyNGMQTT after two weeks of use
Posted: Sun Jul 31, 2022 7:10 am
Minor oints I think:
1) When Indigo starts up after rebooting my system, my device MQTT Broker Connector comes up red. I find that be reloading the MQTT Connector plugin, this fixes itself. Not sure why I need to do this but its been repeated 5 or 6 times now.
2) At random other time, it seems like the MQTT connections to the broker are not going through, even though the MQTT broker plugin says its running. Reloading the MQTT broker plugin fixes this issue. There is nothing in the logs to indicate there was a problem, but my lights simply did not turn on or off when the system command was issued and log says relay went on or off. Looking at MQTT explorer I see broker not functioning properly, and as I said, reloading broker plugin is a fix. I am not sure what initiates this issue when it occurs.
