Colly wrote:No problem - I'll give it a whirl whenever you send out an update. Have a quiet Sunday evening ahead.
Error device "i4_2" state key onOffState not defined (ignoring update request)
Colly wrote:Making some progress..
The i4 has connected but not showing as online.
Getting the following in log after a button press.
- Code: Select all
Colly wrote:That error is with the latest version.
Trigger Shelly NG
Error device "i4_1" state key onOffState not defined (ignoring update request)
Colly wrote:Unfortunately not much change.
- Code: Select all
Trigger Shelly NG
tazswe wrote:Hi Aaron,
Hope that the progress with the new plugin is going by schedule.
Received the following today that can be tested.
Shelly Plus I4
Shelly Plus 2PM
Sent from my iPad with Tapatalk
Colly wrote:Thanks Aaron for all your efforts.
I was running 2021.1 and after latest plugin version update I still got the same errors.
I’ve now updated to 2021.2 and still seeing the same.
One minor difference I’m seeing is that the individual input (e.g. sw1) now updates in Indigo. Previously I had to send status request.
aaronlionsheep wrote:Would you mind recreating the entire Shelly device (all 4 inputs and the I4 main device) in Indigo?
aaronlionsheep wrote:@Clive, have you run into any problems with any of your devices?
CliveS wrote:aaronlionsheep wrote:@Clive, have you run into any problems with any of your devices?
Sorry but we are decorating at present and I have been told to put my 'toys' away so unable to 'play' with the Next Gen Shelly's for a few weeks.
