A bit of a hiccup to get it going.
Have tried with and without TLS.
Checked and double-checked Hub IP and API Key.
Entered API key manually in case cut/paste acted up.
Deleted/created Starling Hub device several times.
- Code: Select all
Event Log: Starling Bridge Error Access Starling Hub failed with a connection error. Retrying . . .
Indigo 2022.1.2
Starling Bridge Plugin Information:
Plugin Name: Starling Bridge
Plugin Version: 2022.0.5
Plugin ID: com.autologplugin.indigoplugin.starlingBridge
Indigo Version: 2022.1.2
Indigo License: ActiveSubscription
Indigo API Version: 3.1
Architecture: arm64
Python Version: 3.10.2
Mac OS Version: 11.7
Plugin Process ID: 56229
All Nest devices are showing in Create New Devices using Type Starling Bridge..
What did I miss?
Starling works ok in HomeKit.
Forgot: Running Indigo on M1 - Big Sur.
Got a successful connect via http from web browser using the API key.
