Ramias wrote:Looks fixed. Only observation, and probably not fixable the way it is designed, is what the GUI displays for a second or two after changing, before official state is pulled from the Starling -- if I set it from heat to cool in the gui, it will switch back to heat for just a moment until the Nest service recognizes and displays cool. Not a big issue at all.
Ramias wrote:Will play with it some more and let you know but great work on this and looks very solid.
Ramias wrote:one question - how does motion work on the protects? What is the timeout value (controlled by Starling or Indigo) for when Motion is cleared? is it max 5 seconds delay (Starling polling interval default) for when motion is detected?
Starling Bridge Received "Kitchen Thermostat (Downstairs)" set heating threshold setpoint to 60°F
Starling Bridge Received "Master Bedroom Thermostat (Upstairs)" set cooling threshold setpoint to 76°F
Starling Bridge Received "Master Bedroom Thermostat (Upstairs)" set heating threshold setpoint to 58°F
Starling Bridge Received "Kitchen Thermostat (Downstairs)" set cooling threshold setpoint to 76°F
Ramias wrote:started noticing this the last several days. hundreds of lines in the log. Not sure what is triggering it.
- Code: Select all
Ramias wrote:yes it is still doing it. v 2022.0.16
