Fresh Starling install: Connection error
Tue Nov 01, 2022 2:58 pm
hwitten offline
Big THANK YOU for the plugin.
A bit of a hiccup to get it going.
Have tried with and without TLS.
Checked and double-checked Hub IP and API Key.
Entered API key manually in case cut/paste acted up.
Deleted/created Starling Hub device several times.
Event Log: Starling Bridge Error           Access Starling Hub failed with a connection error. Retrying . . .
Indigo 2022.1.2
Starling Bridge Plugin Information:
Plugin Name: Starling Bridge
Plugin Version: 2022.0.5
Plugin ID: com.autologplugin.indigoplugin.starlingBridge
Indigo Version: 2022.1.2
Indigo License: ActiveSubscription
Indigo API Version: 3.1
Architecture: arm64
Python Version: 3.10.2
Mac OS Version: 11.7
Plugin Process ID: 56229
All Nest devices are showing in Create New Devices using Type Starling Bridge..
What did I miss?
Starling works ok in HomeKit.
Forgot: Running Indigo on M1 - Big Sur.
Got a successful connect via http from web browser using the API key.
Wed Nov 02, 2022 3:24 am
autolog offline
Re: Fresh Starling install: Connection error
The version of the plugin you have installed (v2022.0.5) is an older one.
Try the latest pre-release, available here: Starling Bridge Pre-Release 2022.0.19
Hopefully that will get you working. :)
Wed Nov 02, 2022 11:38 am
hwitten offline
No luck.
   Starting plugin "Starling Bridge 2022.0.19" (pid 60280)
   Starling Bridge Warning         Filtering active for the following Nest device(s):
                                   Hub Device(s)
   Started plugin "Starling Bridge 2022.0.19"
When I try from a browser:
{"apiVersion":2.5,"apiReady":true,"connectedToNest":true,"appName":"HWnest","permissions":{"read":true,"write":true,"camera":false}}
When I first updated the Plugin I got this error:
   Stopped plugin Starling Bridge
   Upgrading plugin Starling Bridge to newer version 2022.0.19 (previous version moved to trash)
   Loading plugin "Starling Bridge 2022.0.19" using API v3.0
   Starting plugin "Starling Bridge 2022.0.19" (pid 60076)
                                   Hub Device(s)
   Starling Bridge Error           Access Starling Hub failed: 401 Client Error: Unauthorized for url: http://192.168.2.140:3080/api/connect/v1/status?key=xVrEMuNZZcJY%0Aedit%09%0AxVrEMuNZZcJY%0Aedit%09%0AxVrEMuNZZcJY%0Aedit%09%0AxVrEMuNZZcJY
From browser:
{"status":"Error","code":"INVALID_API_KEY","message":"API key specified is invalid, or does not have the right permissions for this request."}
API Key looks right and only got that error the very first time.
Wed Nov 02, 2022 12:42 pm
autolog offline
I think the key is incorrect.
It looks like the key has some line feeds in it (\x0A is the escaped hexadecimal Line Feed) and so you can't see the whole field in the Indigo UI as the field is only one line deep.
You can try performing a CMD-A and then delete or keep pressing the delete button to clear the field.
You can check the key in the Hub by right clicking the Indigo Starling Hub device and click Print Device Details to Event Log. You will see an ownerProps : com.autologplugin.indigoplugin.starlingBridge : (dict) entry that contains a field named api_key. This is the key the plugin is using to send to the Starling Hub.
Wed Nov 02, 2022 2:27 pm
hwitten offline
Key is correct and no leading or trailing spaces.
I'll generate new key and try it.
Should Hub Security be on or off? (SSL/TLS)
Wed Nov 02, 2022 2:35 pm
autolog offline
You checked using the print device to event log?
(SSL/TLS option: doesn't matter which you use, though it is more secure if turned on, which probably isn't an issue on a local network?
Wed Nov 02, 2022 2:40 pm
hwitten offline
Changed API key. Deleted old one. Restarted Starling Hub.
Reloaded Plugin.
Access Starling Hub failed: 401 Client Error: Unauthorized for url: http://192.168.2.140:3080/api/connect/v ... rEMuNZZcJY
The key= is correct as new key
The edit, etc. is the old key.
Wed Nov 02, 2022 2:48 pm
hwitten offline
Yes re Print Device details to event log.
This is current one showing new api key.
works in browser: http://192.168.2.140:3080/api/connect/v ... dmRWWfuK0N
pasted from event log: http://192.168.2.140:3080/api/connect/v ... rEMuNZZcJY
gives error:
Plugin sending too much?
Nov 2, 2022 at 1:40:38 PM
Script address : 192.168.2.140
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
deviceTypeId : starlingHub
displayStateId : status
displayStateImageSel : SensorOff
displayStateValRaw : Disconnected
displayStateValUi : Disconnected
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 0
address : 192.168.2.140 (string)
api_key : kzdmRWWfuK0N
edit
xVrEMuNZZcJY
edit
xVrEMuNZZcJY
edit
xVrEMuNZZcJY (string)
starling_hub_ip : 192.168.2.140 (string)
starling_hub_ssl_tls : false (bool)
lastChanged : 2022-11-02 13:37:31
lastSuccessfulComm : 2022-11-02 13:37:31
model : Starling Hub
edit
xVrEMuNZZcJY
edit
xVrEMuNZZcJY
edit
pluginId : com.autologplugin.indigoplugin.starlingBridge
protocol : Plugin
remoteDisplay : True
states : States : (dict)
api_ready : false (bool)
api_version : 0 (integer)
app_name : (string)
connected_to_nest : false (bool)
permission_camera : false (bool)
permission_read : false (bool)
permission_write : false (bool)
status : Disconnected (string)
status_message : HTTP Error (string)
subModel : Other,ui=Hub
subType : Other
supportsAllOff : False
supportsStatusRequest : False
version : None
Wed Nov 02, 2022 3:29 pm
autolog offline
edit
xVrEMuNZZcJY
edit
xVrEMuNZZcJY
edit
As I suspected, the key is wrong and has been corrupted. It spans across multiple lines.
I suggest you:
  1. Delete the Indigo Starling Hub device.
  2. Then reload the plugin to be on the safe side.
  3. Then create a new Starling Hub device but don't copy and paste the API Key type it in manually.
  4. Then once it is saved, print the device to the log so we can check the key is being saved correctly.
Let's see how that goes? :)
Wed Nov 02, 2022 3:37 pm
hwitten offline
Perfect.
Thank you.
batteryLevel : None
configured : True
description :
displayStateImageSel : SensorOn
displayStateValRaw : Connected
displayStateValUi : Connected
enabled : True
errorState :
folderId : 0
api_key : kzdmRWWfuK0N (string)
version : API: 2.5 (string)
lastChanged : 2022-11-02 14:34:51
lastSuccessfulComm : 2022-11-02 14:34:51
protocol : Plugin
api_ready : true (bool)
api_version : 2.5 (real)
app_name : Nest2 (string)
connected_to_nest : true (bool)
permission_read : true (bool)
permission_write : true (bool)
status : Connected (string)
status_message : OK (string)
subType : Other
version : API: 2.5
