Starling Bridge Plugin Beta
Sun Jun 19, 2022 1:41 pm
Ramias offline
Re: Starling Bridge Plugin Beta
one question - how does motion work on the protects? What is the timeout value (controlled by Starling or Indigo) for when Motion is cleared? is it max 5 seconds delay (Starling polling interval default) for when motion is detected?
Sun Jun 19, 2022 2:09 pm
autolog offline
Ramias wrote:
Looks fixed. Only observation, and probably not fixable the way it is designed, is what the GUI displays for a second or two after changing, before official state is pulled from the Starling -- if I set it from heat to cool in the gui, it will switch back to heat for just a moment until the Nest service recognizes and displays cool. Not a big issue at all.
I'll take a look at that to make sure there isn't something funny going on. But as a principle, the plugin only changes the Indigo states once they have been confirmed by the Starling Home hub.
Ramias wrote:
Will play with it some more and let you know but great work on this and looks very solid.
Thanks. :)
Sun Jun 19, 2022 2:13 pm
autolog offline
The plugin just responds to the input it gets from the Starling Home Hub. So it is the Starling Home Hub that is turning the motion on and off.
I could look at setting a configurable timer in Indigo to turn it off, rarther than taking the off from the message received from the Starling Home Hub.
You could try reducing the polling time to 2 seconds and see what happens?
Mon Jun 20, 2022 11:26 am
autolog offline
New updated posted on Github: Update For Fan Running Issue
This update contains:
  • Partial bug fix for Fan Running - still more debugging to be done on this!
  • Add in additional log messages for change of Fan, Humidifier and Hot Water states
  • Add in initial support for Thermostat, Preset Selected field (October 2020 Google Nest Thermostat only). Presets can be viewed but not set at the moment.
Tue Jun 21, 2022 7:42 am
autolog offline
Another update available on Github: Further Update for Fan Running :)
This update reflects the fan running state in main thermostat device.
Note that the secondary fan device should be showing the correct on off state?
Tue Jun 21, 2022 11:28 am
Ramias offline
The secondary fan devices show current correct state. Will check my system throughout the day and see if they change correctly.
