Page 91 of 103
Re: Hue Lights discussion
Posted:
Mon Sep 13, 2021 1:58 am
by nsheldon
Version 1.7.57 Posted- Fixed a bug that would cause continuous Indigo error messages if a motion sensor was disabled on the Hue bridge.
- Added support for a new Hue ambiance candle bulb.
- Added support for a Hue Aurelle panel.
Posted:
Sat Sep 18, 2021 8:32 am
by yassi
Hi Nathan!
Would you please be so kind to add a new bulb to the plugin?
It's a Lightway/Megos E27, 806 lm bulb, 9W.
The model number is
L122CB63H11A or
TS0505B (in the Hue app)
They can be found at ALDI in Germany.
I was able to add it to the Hue app.
Attached the debug log. Had to cut it, because it was way too long. And I've replaced some information (email, API).
For the bulb please look for the strings
TZ3000_kohbva1f and
TS0505B in the log.
Thanks in advance!
Yassi
- Code: Select all
18. Sep 2021 at 15:59:16
Hue Lights Debug logging enabled
Hue Lights Debug Turning on debug logging (due to plugin prefs being updated).
Hue Lights Debug Starting parseAllHueSensorsData.
Hue Lights Debug Starting updateSensorsList.
Hue Lights Debug Starting updateLightsList.
Hue Lights Debug Sending command to bridge: http://192.168.100.105/api/xxx/lights
Hue Lights Debug Got response {u'1': {u'swversion': u'5.130.1.30000', u'name': u'Couchlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-03T13:20:36'}, u'uniqueid': u'00:17:88:01:10:2f:f2:0b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'3': {u'swversion': u'1.88.1', u'name': u'Flurlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2021-08-12T12:25:50'}, u'productid': u'Philips-LWB010-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:86:2a:7c-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'2628EA25', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'2': {u'swversion': u'5.130.1.30000', u'name': u'Papierlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-03T13:20:33'}, u'uniqueid': u'00:17:88:01:02:30:83:9b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'5': {u'swversion': u'V1.04.12', u'name': u'Tischlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-06-08T14:58:57'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:64:a2-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'4': {u'swversion': u'2.0', u'name': u'Bettlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-01-25T16:47:48'}, u'uniqueid': u'00:15:8d:00:02:0a:f5:3c-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.7, 0.3], [0.11, 0.82], [0.12, 0.08]], u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'lselect', u'xy': [0.4578, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 204}, u'manufacturername': u'innr', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'RB 185 C'}, u'7': {u'swversion': u'V1.04.12', u'name': u'Bettlampe links', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2020-11-29T20:21:55'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:5a:0b-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'6': {u'swversion': u'V1.04.12', u'name': u'Bettlampe rechts', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-06-08T17:55:26'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:64:b3-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'8': {u'swversion': u'', u'name': u'X', u'swupdate': {u'state': u'notupdatable', u'lastinstall': None}, u'uniqueid': u'60:a4:23:ff:fe:c1:fe:96-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': True, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.0, 0.0], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 322, u'sat': 35}, u'manufacturername': u'_TZ3000_kohbva1f', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'TS0505B'}}
Hue Lights Debug Loaded lights list - {u'1': {u'swversion': u'5.130.1.30000', u'name': u'Couchlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-03T13:20:36'}, u'uniqueid': u'00:17:88:01:10:2f:f2:0b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'3': {u'swversion': u'1.88.1', u'name': u'Flurlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2021-08-12T12:25:50'}, u'productid': u'Philips-LWB010-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:86:2a:7c-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'2628EA25', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'2': {u'swversion': u'5.130.1.30000', u'name': u'Papierlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-03T13:20:33'}, u'uniqueid': u'00:17:88:01:02:30:83:9b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'5': {u'swversion': u'V1.04.12', u'name': u'Tischlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-06-08T14:58:57'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:64:a2-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'4': {u'swversion': u'2.0', u'name': u'Bettlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-01-25T16:47:48'}, u'uniqueid': u'00:15:8d:00:02:0a:f5:3c-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.7, 0.3], [0.11, 0.82], [0.12, 0.08]], u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'lselect', u'xy': [0.4578, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 204}, u'manufacturername': u'innr', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'RB 185 C'}, u'7': {u'swversion': u'V1.04.12', u'name': u'Bettlampe links', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2020-11-29T20:21:55'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:5a:0b-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'6': {u'swversion': u'V1.04.12', u'name': u'Bettlampe rechts', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-06-08T17:55:26'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:64:b3-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'8': {u'swversion': u'', u'name': u'X', u'swupdate': {u'state': u'notupdatable', u'lastinstall': None}, u'uniqueid': u'60:a4:23:ff:fe:c1:fe:96-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': True, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.0, 0.0], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 322, u'sat': 35}, u'manufacturername': u'_TZ3000_kohbva1f', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'TS0505B'}}
Hue Lights Debug Starting parseAllHueLightsData.
Hue Lights Debug parseAllHueLightsData: There are 8 lights on the Hue bridge and 9 Indigo devices controlling Hue devices.
Hue Lights Debug Starting updateGroupsList.
Hue Lights Debug Sending command to bridge: http://192.168.100.105/api/xxx/groups
Hue Lights Debug Got response {u'1': {u'name': u'Wohnzimmer', u'lights': [u'5', u'1', u'2'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'bri': 1, u'ct': 370, u'sat': 0}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Flur', u'lights': [u'3'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'2': {u'name': u'K\xfcche', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}, u'5': {u'name': u'Custom group for $lights', u'lights': [u'5'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'bri': 254, u'ct': 370, u'sat': 0}}, u'4': {u'name': u'Schlafzimmer', u'lights': [u'7', u'6', u'4'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'lselect', u'xy': [0.4578, 0.4101], u'bri': 1, u'ct': 370, u'sat': 204}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'6': {u'name': u'G\xe4stebad', u'lights': [u'8'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.0, 0.0], u'bri': 254, u'ct': 322, u'sat': 35}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bathroom'}}
Hue Lights Debug Loaded groups list - {u'1': {u'name': u'Wohnzimmer', u'lights': [u'5', u'1', u'2'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'bri': 1, u'ct': 370, u'sat': 0}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Flur', u'lights': [u'3'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'2': {u'name': u'K\xfcche', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}, u'5': {u'name': u'Custom group for $lights', u'lights': [u'5'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'bri': 254, u'ct': 370, u'sat': 0}}, u'4': {u'name': u'Schlafzimmer', u'lights': [u'7', u'6', u'4'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'lselect', u'xy': [0.4578, 0.4101], u'bri': 1, u'ct': 370, u'sat': 204}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'6': {u'name': u'G\xe4stebad', u'lights': [u'8'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.0, 0.0], u'bri': 254, u'ct': 322, u'sat': 35}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bathroom'}}
Hue Lights Debug Starting parseAllHueGroupsData.
Hue Lights Debug Starting parseOneHueGroupData.
Hue Lights Debug updateDeviceState: Updating device Schlafzimmer alle Lampen state: alertMode. Old value = . New value = lselect
Hue Lights Debug updateDeviceState: Updating device Schlafzimmer alle Lampen state: effect. Old value = . New value = none
Hue Lights Debug updateDeviceState: Updating device Schlafzimmer alle Lampen state: effect. Old value = none. New value =
Hue Lights Debug updateDeviceState: Updating device Schlafzimmer alle Lampen state: alertMode. Old value = lselect. New value =
Hue Lights Debug Starting didDeviceCommPropertyChange.
Reloading plugin "Hue Lights 1.7.57"
Stopping plugin "Hue Lights 1.7.57" (pid 11083)
Hue Lights Debug runConcurrentThread stopped.
Hue Lights Debug runConcurrentThread exiting.
Hue Lights Debug Stopping device: Alle Hue Lampen
Hue Lights Debug Stopping device: Bettlampe
Hue Lights Debug Stopping device: Bettlampe links
Hue Lights Debug Stopping device: Bettlampe rechts
Hue Lights Debug Stopping device: Couchlampe
Hue Lights Debug Stopping device: Flurlampe
Hue Lights Debug Stopping device: Papierlampe
Hue Lights Debug Stopping device: Schlafzimmer alle Lampen
Hue Lights Debug Stopping device: Tischlampe
Hue Lights Debug Plugin shutdown called.
Stopped plugin "Hue Lights 1.7.57"
Starting plugin "Hue Lights 1.7.57" (pid 11234)
Hue Lights Debug Debug logging started at plugin initialization.
Hue Lights Debug Starting plugin initialization.
Started plugin "Hue Lights 1.7.57"
Hue Lights Debug Startup called.
Hue Lights Debug Running plugin version check (if enabled).
Hue Lights Debug pluginPrefs contains 30 presets.
Hue Lights Debug pluginPrefs are:
Prefs : (dict)
address : 192.168.100.105 (string)
debugLabel : (string)
emailLabel : (string)
hostId : 7HYhiGzk0Fu8DBfvRn4aKFOapMVGPrZbsQCck5cq (string)
instructions0 : (string)
instructions1 : (string)
instructions2 : (string)
instructions3 : (string)
labelAddress : (string)
labelHostId : (string)
maxPresetCount : 30 (string)
maxPresetCountLabel : (string)
noticeLabel : (string)
noticeLabel0 : (string)
presets : (list)
Item : (list)
Item : Preset #1 Tischlampe (string)
Item : (dict)
alertMode : lselect (string)
alertMode.ui : lselect (string)
blueLevel : 0 (real)
blueLevel.ui : 0 (string)
brightnessLevel : 0 (integer)
brightnessLevel.ui : 0 (string)
colorBlue : 0 (integer)
colorBlue.ui : 0 (string)
colorGreen : 0 (integer)
colorGreen.ui : 0 (string)
colorMode : hs (string)
colorMode.ui : hs (string)
colorRed : 0 (integer)
colorRed.ui : 0 (string)
colorTemp : 2933 (integer)
colorTemp.ui : 2933 (string)
colorX : 0.4396 (real)
colorX.ui : 0.4396 (string)
colorY : 0.3711 (real)
colorY.ui : 0.3711 (string)
effect : none (string)
effect.ui : none (string)
greenLevel : 0 (real)
greenLevel.ui : 0 (string)
hue : 28 (integer)
hue.ui : 28 (string)
onOffState : false (bool)
online : true (bool)
online.ui : True (string)
redLevel : 0 (real)
redLevel.ui : 0 (string)
saturation : 65 (integer)
saturation.ui : 65 (string)
whiteLevel : 35 (real)
whiteLevel.ui : 35 (string)
whiteTemperature : 2933 (real)
whiteTemperature.ui : 2933 (string)
Item : -1 (integer)
Item : (list)
Item : Preset #1 Bettlampe (string)
Item : (dict)
blueLevel : 35 (real)
blueLevel.ui : 35 (string)
brightnessLevel : 100 (integer)
brightnessLevel.ui : 100 (string)
colorBlue : 90 (integer)
colorBlue.ui : 90 (string)
colorGreen : 167 (integer)
colorGreen.ui : 167 (string)
colorRed : 254 (integer)
colorRed.ui : 254 (string)
greenLevel : 65 (real)
greenLevel.ui : 65 (string)
hue : 28 (integer)
onOffState : true (bool)
redLevel : 100 (real)
redLevel.ui : 100 (string)
Item : -1 (integer)
Item : (list)
Item : Preset 3 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 4 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 5 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 6 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 7 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 8 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 9 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 10 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 11 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 12 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 13 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 14 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 15 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 16 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 17 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 18 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 19 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 20 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 21 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 22 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 23 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 24 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 25 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 26 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 27 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 28 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 29 (string)
Item : (dict)
Item : -1 (integer)
Item : (list)
Item : Preset 30 (string)
Item : (dict)
Item : -1 (integer)
sep0 : (string)
sep00 : (string)
sep1 : (string)
sep2 : (string)
showDebugInfo : true (bool)
startPairingButton : (string)
title : (string)
updaterEmail : notify@xxx.de (string)
updaterEmailsEnabled : true (bool)
updaterLastCheck : 1631973504 (real)
updaterLastVersionEmailed : 1.7.55 (string)
Hue Lights Debug The username Hue Lights uses to connect to the Hue bridge is 7HYhiGzk0Fu8DBfvRn4aKFOapMVGPrZbsQCck5cq
Hue Lights Debug Starting getHueConfig.
Hue Lights Debug Got response {u'rules': {u'10': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'33:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'status': 0}, u'method': u'PUT', u'address': u'/sensors/5/state'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'false', u'address': u'/groups/5/state/all_on'}, {u'operator': u'dx', u'address': u'/groups/5/state/all_on'}, {u'operator': u'gt', u'value': u'0', u'address': u'/sensors/5/state/status'}]}, u'3': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'21:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'JOrd2tQKbGzRdd-'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'0', u'address': u'/sensors/5/state/status'}, {u'operator': u'dx', u'address': u'/sensors/5/state/lastupdated'}, {u'operator': u'eq', u'value': u'true', u'address': u'/groups/5/state/all_on'}]}, u'2': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'20:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'storelightstate': True}, u'method': u'PUT', u'address': u'/scenes/JOrd2tQKbGzRdd-'}, {u'body': {u'scene': u'lrC6RwPn-8LjnFS'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'dx', u'address': u'/sensors/5/state/status'}]}, u'5': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'28:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'y7El64GXzhzIGkJ'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:01:00', u'address': u'/sensors/5/state/lastupdated'}]}, u'4': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'27:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'nVpH9TdzRbEeEUb'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:00:01', u'address': u'/sensors/5/state/lastupdated'}]}, u'7': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'30:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'XAVo7dYKhN6HXsf'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:03:00', u'address': u'/sensors/5/state/lastupdated'}]}, u'6': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'29:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'VXPFSFZx81MGTah'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:02:00', u'address': u'/sensors/5/state/lastupdated'}]}, u'9': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'32:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'status': 1}, u'method': u'PUT', u'address': u'/sensors/5/state'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:05:00', u'address': u'/sensors/5/state/lastupdated'}]}, u'8': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'31:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'aSGOie4t7NLFOKg'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:04:00', u'address': u'/sensors/5/state/lastupdated'}]}}, u'resourcelinks': {u'57987': {u'classid': 2, u'name': u'Autumn living scenes', u'links': [u'/rules/10', u'/rules/9', u'/rules/8', u'/rules/7', u'/rules/6', u'/rules/5', u'/rules/4', u'/rules/3', u'/rules/2', u'/scenes/aSGOie4t7NLFOKg', u'/scenes/XAVo7dYKhN6HXsf', u'/scenes/VXPFSFZx81MGTah', u'/scenes/y7El64GXzhzIGkJ', u'/scenes/nVpH9TdzRbEeEUb', u'/scenes/lrC6RwPn-8LjnFS', u'/scenes/JOrd2tQKbGzRdd-', u'/sensors/5', u'/groups/5', u'/lights/5'], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'Link', u'description': u'-HucBhPLKto0tAXF693k8g:0:DSbafeG6CfheFO2ohGfOfisbk9M'}, u'11496': {u'classid': 1, u'name': u'HueLabs 2.0', u'links': [u'/resourcelinks/57987'], u'recycle': False, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'Link', u'description': u'All installed formulas'}}, u'scenes': {u'-cndADBHxR71zS9': {u'picture': u'', u'group': u'3', u'name': u'Gedimmt', u'appdata': {u'version': 1, u'data': u'R2BaF_r03_d06'}, u'lights': [u'3'], u'image': u'8c74b9ba-6e89-4083-a2a7-b10a1e566fed', u'lastupdated': u'2017-08-19T10:18:21', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'c37A8UgQg5CTb03': {u'picture': u'', u'group': u'4', u'name': u'Entspannen', u'appdata': {u'version': 1, u'data': u'vJEIV_r04_d01'}, u'lights': [u'4', u'6', u'7'], u'image': u'a1f7da49-d181-4328-abea-68c9dc4b5416', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'WZnkjWsKhaR3A0v': {u'picture': u'', u'group': u'4', u'name': u'Lesen', u'appdata': {u'version': 1, u'data': u'taa8l_r04_d02'}, u'lights': [u'4', u'6', u'7'], u'image': u'e101a77f-9984-4f61-aac8-15741983c656', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'0U5B7gai07Ju1UY': {u'picture': u'', u'group': u'4', u'name': u'Energie tanken', u'appdata': {u'version': 1, u'data': u'AB5Ky_r04_d04'}, u'lights': [u'4', u'6', u'7'], u'image': u'7fd2ccc5-5749-4142-b7a5-66405a676f03', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'nVpH9TdzRbEeEUb': {u'picture': u'', u'locked': True, u'name': u'Scene scene1 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'FknzutOGHm4BYsX': {u'picture': u'', u'group': u'1', u'name': u'Nachtlicht', u'appdata': {u'version': 1, u'data': u'usdOu_r01_d07'}, u'lights': [u'1', u'2', u'5'], u'image': u'28bbfeff-1a0c-444e-bb4b-0b74b88e0c95', u'lastupdated': u'2019-06-22T16:10:42', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'hQaXlPphHWVOxDF': {u'picture': u'', u'group': u'4', u'name': u'Hell', u'appdata': {u'version': 1, u'data': u'eSBHw_r04_d05'}, u'lights': [u'4', u'6', u'7'], u'image': u'732ff1d9-76a7-4630-aad0-c8acc499bb0b', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'aSGOie4t7NLFOKg': {u'picture': u'', u'locked': True, u'name': u'Scene scene5 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'y7El64GXzhzIGkJ': {u'picture': u'', u'locked': True, u'name': u'Scene scene2 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'JOrd2tQKbGzRdd-': {u'picture': u'', u'group': u'5', u'name': u'Scene storageScene ', u'appdata': {}, u'lights': [u'5'], u'lastupdated': u'2020-11-30T19:52:00', u'recycle': True, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': True, u'type': u'GroupScene'}, u'dXMWPRKM1o19CJb': {u'picture': u'', u'group': u'4', u'name': u'Nordlichter', u'appdata': {u'version': 1, u'data': u'yTx1G_r04_d17'}, u'lights': [u'4', u'6', u'7'], u'image': u'1e42b2e8-d02e-40d2-9c8d-b1fd8216c686', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'yQ17vjEsOf3udxO': {u'picture': u'', u'group': u'4', u'name': u'Nachtlicht', u'appdata': {u'version': 1, u'data': u'ehrih_r04_d07'}, u'lights': [u'4', u'6', u'7'], u'image': u'28bbfeff-1a0c-444e-bb4b-0b74b88e0c95', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'XAVo7dYKhN6HXsf': {u'picture': u'', u'locked': True, u'name': u'Scene scene4 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'Pu5spbERsxuPreh': {u'picture': u'', u'group': u'4', u'name': u'Konzentrieren', u'appdata': {u'version': 1, u'data': u'6ztbk_r04_d03'}, u'lights': [u'4', u'6', u'7'], u'image': u'b90c8900-a6b7-422c-a5d3-e170187dbf8c', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'VXPFSFZx81MGTah': {u'picture': u'', u'locked': True, u'name': u'Scene scene3 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'yFwsHk1yJxSFl89': {u'picture': u'', u'group': u'3', u'name': u'Hell', u'appdata': {u'version': 1, u'data': u'lNgcI_r03_d05'}, u'lights': [u'3'], u'image': u'732ff1d9-76a7-4630-aad0-c8acc499bb0b', u'lastupdated': u'2017-08-19T10:18:21', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'kdzO5Ko18osmZD3': {u'picture': u'', u'group': u'4', u'name': u'Gedimmt', u'appdata': {u'version': 1, u'data': u'fNBn4_r04_d06'}, u'lights': [u'4', u'6', u'7'], u'image': u'8c74b9ba-6e89-4083-a2a7-b10a1e566fed', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'lrfEjORNiWi57sk': {u'picture': u'', u'group': u'4', u'name': u'Tropend\xe4mmerung', u'appdata': {u'version': 1, u'data': u'oZLWi_r04_d16'}, u'lights': [u'4', u'6', u'7'], u'image': u'a6a03e6a-fe6e-45bc-b686-878137f3ba91', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'9Emql0TziBf5wSL': {u'picture': u'', u'group': u'4', u'name': u'Sonnenuntergang Savanne', u'appdata': {u'version': 1, u'data': u'L4qxq_r04_d15'}, u'lights': [u'4', u'6', u'7'], u'image': u'4f2ed241-5aea-4c9d-8028-55d2b111e06f', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'S0mKdDgaKyvV-Me': {u'picture': u'', u'group': u'3', u'name': u'Nachtlicht', u'appdata': {u'version': 1, u'data': u'1Iamu_r03_d07'}, u'lights': [u'3'], u'image': u'28bbfeff-1a0c-444e-bb4b-0b74b88e0c95', u'lastupdated': u'2017-08-19T10:18:21', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'h9bdCAjaKr5tpVq': {u'picture': u'', u'group': u'1', u'name': u'Hell', u'appdata': {u'version': 1, u'data': u'1VI5t_r01_d05'}, u'lights': [u'1', u'2', u'5'], u'image': u'732ff1d9-76a7-4630-aad0-c8acc499bb0b', u'lastupdated': u'2019-06-22T16:10:42', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'7QgI7NTQy8fZcu3': {u'picture': u'', u'group': u'4', u'name': u'Fr\xfchlingsbl\xfcten', u'appdata': {u'version': 1, u'data': u'Q5MeU_r04_d18'}, u'lights': [u'4', u'6', u'7'], u'image': u'adfa9c3e-e9aa-4b65-b9d3-c5b2c0576715', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'UusHfDe9hOQiIAW': {u'picture': u'', u'group': u'1', u'name': u'Gedimmt', u'appdata': {u'version': 1, u'data': u'tMqXz_r01_d06'}, u'lights': [u'1', u'2', u'5'], u'image': u'8c74b9ba-6e89-4083-a2a7-b10a1e566fed', u'lastupdated': u'2019-06-22T16:10:42', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'lrC6RwPn-8LjnFS': {u'picture': u'', u'locked': True, u'name': u'Scene scene0 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}}, u'lights': {u'1': {u'swversion': u'5.130.1.30000', u'name': u'Couchlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-03T13:20:36'}, u'uniqueid': u'00:17:88:01:10:2f:f2:0b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'3': {u'swversion': u'1.88.1', u'name': u'Flurlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2021-08-12T12:25:50'}, u'productid': u'Philips-LWB010-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:86:2a:7c-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'2628EA25', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'2': {u'swversion': u'5.130.1.30000', u'name': u'Papierlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-03T13:20:33'}, u'uniqueid': u'00:17:88:01:02:30:83:9b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'5': {u'swversion': u'V1.04.12', u'name': u'Tischlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-06-08T14:58:57'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:64:a2-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'4': {u'swversion': u'2.0', u'name': u'Bettlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-01-25T16:47:48'}, u'uniqueid': u'00:15:8d:00:02:0a:f5:3c-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.7, 0.3], [0.11, 0.82], [0.12, 0.08]], u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'lselect', u'xy': [0.4578, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 204}, u'manufacturername': u'innr', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'RB 185 C'}, u'7': {u'swversion': u'V1.04.12', u'name': u'Bettlampe links', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2020-11-29T20:21:55'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:5a:0b-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'6': {u'swversion': u'V1.04.12', u'name': u'Bettlampe rechts', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-06-08T17:55:26'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:64:b3-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'8': {u'swversion': u'', u'name': u'X', u'swupdate': {u'state': u'notupdatable', u'lastinstall': None}, u'uniqueid': u'60:a4:23:ff:fe:c1:fe:96-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': True, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.0, 0.0], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 322, u'sat': 35}, u'manufacturername': u'_TZ3000_kohbva1f', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'TS0505B'}}, u'groups': {u'1': {u'name': u'Wohnzimmer', u'lights': [u'5', u'1', u'2'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'bri': 1, u'ct': 370, u'sat': 0}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Flur', u'lights': [u'3'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'2': {u'name': u'K\xfcche', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}, u'5': {u'name': u'Custom group for $lights', u'lights': [u'5'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'bri': 254, u'ct': 370, u'sat': 0}}, u'4': {u'name': u'Schlafzimmer', u'lights': [u'7', u'6', u'4'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'lselect', u'xy': [0.4578, 0.4101], u'bri': 1, u'ct': 370, u'sat': 204}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'6': {u'name': u'G\xe4stebad', u'lights': [u'8'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.0, 0.0], u'bri': 254, u'ct': 322, u'sat': 35}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bathroom'}}, u'schedules': {}, u'sensors': {u'1': {u'name': u'Daylight', u'config': {u'on': True, u'configured': False, u'sunriseoffset': 30, u'sunsetoffset': -30}, u'swversion': u'1.0', u'state': {u'daylight': None, u'lastupdated': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'type': u'Daylight', u'modelid': u'PHDL00'}, u'2': {u'name': u'HL-S00-5000', u'uniqueid': u'4c:61:70:41:70:70:73-HL-00-00', u'config': {u'on': True, u'reachable': True}, u'swversion': u'1.0', u'state': {u'status': 0, u'lastupdated': u'none'}, u'manufacturername': u'LapApps, LLC', u'recycle': False, u'type': u'CLIPGenericStatus', u'modelid': u'HL_STATE'}, u'5': {u'name': u'Tischlampe, Falling leaves, 30', u'uniqueid': u'2:10:bc5b-aef1-4b40-be99', u'config': {u'on': True, u'reachable': True}, u'swversion': u'2.0', u'state': {u'status': 0, u'lastupdated': u'2020-11-30T19:52:08'}, u'manufacturername': u'Philips', u'recycle': True, u'type': u'CLIPGenericStatus', u'modelid': u'HUELABSVTOGGLE'}}, u'config': {u'starterkitid': u'', u'portalconnection': u'connected', u'whitelist': {u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e': {u'last use date': u'2021-06-06T10:48:03', u'create date': u'2017-08-02T17:59:29', u'name': u"hue_ios_app#Yasmin's iPhone SE"}, u'67e4487f-aa2c-41f7-b2ea-c3bd63600505': {u'last use date': u'2021-09-18T13:58:01', u'create date': u'2021-06-06T10:50:25', u'name': u'Hue Beta#iPhone XR'}, u'6ada8095-fcf7-46fb-acd0-5c88cf1e1888': {u'last use date': u'2017-08-01T20:42:29', u'create date': u'2017-07-08T16:02:57', u'name': u"hue_ios_app#Yasmin's iPhone SE"}, u'7HYhiGzk0Fu8DBfvRn4aKFOapMVGPrZbsQCck5cq': {u'last use date': u'2021-09-18T13:59:29', u'create date': u'2016-11-16T18:34:51', u'name': u'Indigo Hue Lights'}, u'8227f6c7-8a38-43c2-a1fc-55eec72589e8': {u'last use date': u'2017-01-13T17:20:31', u'create date': u'2017-01-13T17:10:51', u'name': u"hue_ios_app#Yasmin's iPhone SE"}, u'd7474a44-5a98-4521-8b00-3e843ee4ed54': {u'last use date': u'2019-01-26T14:08:55', u'create date': u'2019-01-07T19:52:07', u'name': u'LightShow-Mac'}, u'3e4c7d2b-a7b7-45d1-8517-90b06f37cd1f': {u'last use date': u'2020-11-05T10:05:19', u'create date': u'2017-01-13T17:09:38', u'name': u"OnSwitch#Yasmin's iPhone SE"}, u'b7b7c171-2f17-4f14-91c8-0c78cf058c89': {u'last use date': u'2020-11-29T20:15:26', u'create date': u'2019-01-07T20:42:26', u'name': u"HueLights#Yasmin's iPhone SE"}}, u'zigbeechannel': 20, u'timezone': u'Europe/Berlin', u'gateway': u'192.168.100.254', u'modelid': u'BSB002', u'portalstate': {u'communication': u'disconnected', u'outgoing': True, u'signedon': True, u'incoming': False}, u'proxyaddress': u'none', u'datastoreversion': u'111', u'replacesbridgeid': None, u'swupdate2': {u'bridge': {u'state': u'noupdates', u'lastinstall': u'2021-09-15T12:48:08'}, u'lastchange': u'2021-09-15T12:49:00', u'checkforupdate': False, u'state': u'noupdates', u'autoinstall': {u'on': True, u'updatetime': u'T14:00:00'}}, u'dhcp': True, u'localtime': u'2021-09-18T15:59:29', u'proxyport': 0, u'UTC': u'2021-09-18T13:59:29', u'factorynew': False, u'swupdate': {u'devicetypes': {u'bridge': False, u'sensors': [], u'lights': []}, u'url': u'', u'text': u'', u'checkforupdate': False, u'updatestate': 0, u'notify': True}, u'apiversion': u'1.46.0', u'mac': u'00:17:88:40:4e:5f', u'linkbutton': False, u'bridgeid': u'001788FFFE404E5F', u'ipaddress': u'192.168.100.105', u'portalservices': False, u'name': u'Philips hue', u'swversion': u'1947054040', u'netmask': u'255.255.255.0', u'internetservices': {u'swupdate': u'connected', u'time': u'connected', u'remoteaccess': u'disconnected', u'internet': u'connected'}, u'backup': {u'status': u'idle', u'errorcode': 0}}}
Hue Lights Debug Loaded entire Hue bridge configuration - {u'rules': {u'10': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'33:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'status': 0}, u'method': u'PUT', u'address': u'/sensors/5/state'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'false', u'address': u'/groups/5/state/all_on'}, {u'operator': u'dx', u'address': u'/groups/5/state/all_on'}, {u'operator': u'gt', u'value': u'0', u'address': u'/sensors/5/state/status'}]}, u'3': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'21:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'JOrd2tQKbGzRdd-'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'0', u'address': u'/sensors/5/state/status'}, {u'operator': u'dx', u'address': u'/sensors/5/state/lastupdated'}, {u'operator': u'eq', u'value': u'true', u'address': u'/groups/5/state/all_on'}]}, u'2': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'20:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'storelightstate': True}, u'method': u'PUT', u'address': u'/scenes/JOrd2tQKbGzRdd-'}, {u'body': {u'scene': u'lrC6RwPn-8LjnFS'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'dx', u'address': u'/sensors/5/state/status'}]}, u'5': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'28:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'y7El64GXzhzIGkJ'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:01:00', u'address': u'/sensors/5/state/lastupdated'}]}, u'4': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'27:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'nVpH9TdzRbEeEUb'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:00:01', u'address': u'/sensors/5/state/lastupdated'}]}, u'7': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'30:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'XAVo7dYKhN6HXsf'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:03:00', u'address': u'/sensors/5/state/lastupdated'}]}, u'6': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'29:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'VXPFSFZx81MGTah'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:02:00', u'address': u'/sensors/5/state/lastupdated'}]}, u'9': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'32:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'status': 1}, u'method': u'PUT', u'address': u'/sensors/5/state'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:05:00', u'address': u'/sensors/5/state/lastupdated'}]}, u'8': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'31:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'aSGOie4t7NLFOKg'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:04:00', u'address': u'/sensors/5/state/lastupdated'}]}}, u'resourcelinks': {u'57987': {u'classid': 2, u'name': u'Autumn living scenes', u'links': [u'/rules/10', u'/rules/9', u'/rules/8', u'/rules/7', u'/rules/6', u'/rules/5', u'/rules/4', u'/rules/3', u'/rules/2', u'/scenes/aSGOie4t7NLFOKg', u'/scenes/XAVo7dYKhN6HXsf', u'/scenes/VXPFSFZx81MGTah', u'/scenes/y7El64GXzhzIGkJ', u'/scenes/nVpH9TdzRbEeEUb', u'/scenes/lrC6RwPn-8LjnFS', u'/scenes/JOrd2tQKbGzRdd-', u'/sensors/5', u'/groups/5', u'/lights/5'], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'Link', u'description': u'-HucBhPLKto0tAXF693k8g:0:DSbafeG6CfheFO2ohGfOfisbk9M'}, u'11496': {u'classid': 1, u'name': u'HueLabs 2.0', u'links': [u'/resourcelinks/57987'], u'recycle': False, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'Link', u'description': u'All installed formulas'}}, u'scenes': {u'-cndADBHxR71zS9': {u'picture': u'', u'group': u'3', u'name': u'Gedimmt', u'appdata': {u'version': 1, u'data': u'R2BaF_r03_d06'}, u'lights': [u'3'], u'image': u'8c74b9ba-6e89-4083-a2a7-b10a1e566fed', u'lastupdated': u'2017-08-19T10:18:21', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'c37A8UgQg5CTb03': {u'picture': u'', u'group': u'4', u'name': u'Entspannen', u'appdata': {u'version': 1, u'data': u'vJEIV_r04_d01'}, u'lights': [u'4', u'6', u'7'], u'image': u'a1f7da49-d181-4328-abea-68c9dc4b5416', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'WZnkjWsKhaR3A0v': {u'picture': u'', u'group': u'4', u'name': u'Lesen', u'appdata': {u'version': 1, u'data': u'taa8l_r04_d02'}, u'lights': [u'4', u'6', u'7'], u'image': u'e101a77f-9984-4f61-aac8-15741983c656', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'0U5B7gai07Ju1UY': {u'picture': u'', u'group': u'4', u'name': u'Energie tanken', u'appdata': {u'version': 1, u'data': u'AB5Ky_r04_d04'}, u'lights': [u'4', u'6', u'7'], u'image': u'7fd2ccc5-5749-4142-b7a5-66405a676f03', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'nVpH9TdzRbEeEUb': {u'picture': u'', u'locked': True, u'name': u'Scene scene1 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'FknzutOGHm4BYsX': {u'picture': u'', u'group': u'1', u'name': u'Nachtlicht', u'appdata': {u'version': 1, u'data': u'usdOu_r01_d07'}, u'lights': [u'1', u'2', u'5'], u'image': u'28bbfeff-1a0c-444e-bb4b-0b74b88e0c95', u'lastupdated': u'2019-06-22T16:10:42', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'hQaXlPphHWVOxDF': {u'picture': u'', u'group': u'4', u'name': u'Hell', u'appdata': {u'version': 1, u'data': u'eSBHw_r04_d05'}, u'lights': [u'4', u'6', u'7'], u'image': u'732ff1d9-76a7-4630-aad0-c8acc499bb0b', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'aSGOie4t7NLFOKg': {u'picture': u'', u'locked': True, u'name': u'Scene scene5 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'y7El64GXzhzIGkJ': {u'picture': u'', u'locked': True, u'name': u'Scene scene2 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'JOrd2tQKbGzRdd-': {u'picture': u'', u'group': u'5', u'name': u'Scene storageScene ', u'appdata': {}, u'lights': [u'5'], u'lastupdated': u'2020-11-30T19:52:00', u'recycle': True, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': True, u'type': u'GroupScene'}, u'dXMWPRKM1o19CJb': {u'picture': u'', u'group': u'4', u'name': u'Nordlichter', u'appdata': {u'version': 1, u'data': u'yTx1G_r04_d17'}, u'lights': [u'4', u'6', u'7'], u'image': u'1e42b2e8-d02e-40d2-9c8d-b1fd8216c686', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'yQ17vjEsOf3udxO': {u'picture': u'', u'group': u'4', u'name': u'Nachtlicht', u'appdata': {u'version': 1, u'data': u'ehrih_r04_d07'}, u'lights': [u'4', u'6', u'7'], u'image': u'28bbfeff-1a0c-444e-bb4b-0b74b88e0c95', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'XAVo7dYKhN6HXsf': {u'picture': u'', u'locked': True, u'name': u'Scene scene4 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'Pu5spbERsxuPreh': {u'picture': u'', u'group': u'4', u'name': u'Konzentrieren', u'appdata': {u'version': 1, u'data': u'6ztbk_r04_d03'}, u'lights': [u'4', u'6', u'7'], u'image': u'b90c8900-a6b7-422c-a5d3-e170187dbf8c', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'VXPFSFZx81MGTah': {u'picture': u'', u'locked': True, u'name': u'Scene scene3 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'yFwsHk1yJxSFl89': {u'picture': u'', u'group': u'3', u'name': u'Hell', u'appdata': {u'version': 1, u'data': u'lNgcI_r03_d05'}, u'lights': [u'3'], u'image': u'732ff1d9-76a7-4630-aad0-c8acc499bb0b', u'lastupdated': u'2017-08-19T10:18:21', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'kdzO5Ko18osmZD3': {u'picture': u'', u'group': u'4', u'name': u'Gedimmt', u'appdata': {u'version': 1, u'data': u'fNBn4_r04_d06'}, u'lights': [u'4', u'6', u'7'], u'image': u'8c74b9ba-6e89-4083-a2a7-b10a1e566fed', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'lrfEjORNiWi57sk': {u'picture': u'', u'group': u'4', u'name': u'Tropend\xe4mmerung', u'appdata': {u'version': 1, u'data': u'oZLWi_r04_d16'}, u'lights': [u'4', u'6', u'7'], u'image': u'a6a03e6a-fe6e-45bc-b686-878137f3ba91', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'9Emql0TziBf5wSL': {u'picture': u'', u'group': u'4', u'name': u'Sonnenuntergang Savanne', u'appdata': {u'version': 1, u'data': u'L4qxq_r04_d15'}, u'lights': [u'4', u'6', u'7'], u'image': u'4f2ed241-5aea-4c9d-8028-55d2b111e06f', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'S0mKdDgaKyvV-Me': {u'picture': u'', u'group': u'3', u'name': u'Nachtlicht', u'appdata': {u'version': 1, u'data': u'1Iamu_r03_d07'}, u'lights': [u'3'], u'image': u'28bbfeff-1a0c-444e-bb4b-0b74b88e0c95', u'lastupdated': u'2017-08-19T10:18:21', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'h9bdCAjaKr5tpVq': {u'picture': u'', u'group': u'1', u'name': u'Hell', u'appdata': {u'version': 1, u'data': u'1VI5t_r01_d05'}, u'lights': [u'1', u'2', u'5'], u'image': u'732ff1d9-76a7-4630-aad0-c8acc499bb0b', u'lastupdated': u'2019-06-22T16:10:42', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'7QgI7NTQy8fZcu3': {u'picture': u'', u'group': u'4', u'name': u'Fr\xfchlingsbl\xfcten', u'appdata': {u'version': 1, u'data': u'Q5MeU_r04_d18'}, u'lights': [u'4', u'6', u'7'], u'image': u'adfa9c3e-e9aa-4b65-b9d3-c5b2c0576715', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'UusHfDe9hOQiIAW': {u'picture': u'', u'group': u'1', u'name': u'Gedimmt', u'appdata': {u'version': 1, u'data': u'tMqXz_r01_d06'}, u'lights': [u'1', u'2', u'5'], u'image': u'8c74b9ba-6e89-4083-a2a7-b10a1e566fed', u'lastupdated': u'2019-06-22T16:10:42', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'lrC6RwPn-8LjnFS': {u'picture': u'', u'locked': True, u'name': u'Scene scene0 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}}, u'lights': {u'1': {u'swversion': u'5.130.1.30000', u'name': u'Couchlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-03T13:20:36'}, u'uniqueid': u'00:17:88:01:10:2f:f2:0b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'3': {u'swversion': u'1.88.1', u'name': u'Flurlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2021-08-12T12:25:50'}, u'productid': u'Philips-LWB010-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:86:2a:7c-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'2628EA25', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'2': {u'swversion': u'5.130.1.30000', u'name': u'Papierlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-03T13:20:33'}, u'uniqueid': u'00:17:88:01:02:30:83:9b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'5': {u'swversion': u'V1.04.12', u'name': u'Tischlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-06-08T14:58:57'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:64:a2-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'4': {u'swversion': u'2.0', u'name': u'Bettlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-01-25T16:47:48'}, u'uniqueid': u'00:15:8d:00:02:0a:f5:3c-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.7, 0.3], [0.11, 0.82], [0.12, 0.08]], u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'lselect', u'xy': [0.4578, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 204}, u'manufacturername': u'innr', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'RB 185 C'}, u'7': {u'swversion': u'V1.04.12', u'name': u'Bettlampe links', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2020-11-29T20:21:55'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:5a:0b-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'6': {u'swversion': u'V1.04.12', u'name': u'Bettlampe rechts', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-06-08T17:55:26'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:64:b3-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'8': {u'swversion': u'', u'name': u'X', u'swupdate': {u'state': u'notupdatable', u'lastinstall': None}, u'uniqueid': u'60:a4:23:ff:fe:c1:fe:96-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': True, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.0, 0.0], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 322, u'sat': 35}, u'manufacturername': u'_TZ3000_kohbva1f', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'TS0505B'}}, u'groups': {u'1': {u'name': u'Wohnzimmer', u'lights': [u'5', u'1', u'2'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'bri': 1, u'ct': 370, u'sat': 0}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Flur', u'lights': [u'3'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'2': {u'name': u'K\xfcche', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}, u'5': {u'name': u'Custom group for $lights', u'lights': [u'5'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'bri': 254, u'ct': 370, u'sat': 0}}, u'4': {u'name': u'Schlafzimmer', u'lights': [u'7', u'6', u'4'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'lselect', u'xy': [0.4578, 0.4101], u'bri': 1, u'ct': 370, u'sat': 204}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'6': {u'name': u'G\xe4stebad', u'lights': [u'8'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.0, 0.0], u'bri': 254, u'ct': 322, u'sat': 35}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bathroom'}}, u'schedules': {}, u'sensors': {u'1': {u'name': u'Daylight', u'config': {u'on': True, u'configured': False, u'sunriseoffset': 30, u'sunsetoffset': -30}, u'swversion': u'1.0', u'state': {u'daylight': None, u'lastupdated': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'type': u'Daylight', u'modelid': u'PHDL00'}, u'2': {u'name': u'HL-S00-5000', u'uniqueid': u'4c:61:70:41:70:70:73-HL-00-00', u'config': {u'on': True, u'reachable': True}, u'swversion': u'1.0', u'state': {u'status': 0, u'lastupdated': u'none'}, u'manufacturername': u'LapApps, LLC', u'recycle': False, u'type': u'CLIPGenericStatus', u'modelid': u'HL_STATE'}, u'5': {u'name': u'Tischlampe, Falling leaves, 30', u'uniqueid': u'2:10:bc5b-aef1-4b40-be99', u'config': {u'on': True, u'reachable': True}, u'swversion': u'2.0', u'state': {u'status': 0, u'lastupdated': u'2020-11-30T19:52:08'}, u'manufacturername': u'Philips', u'recycle': True, u'type': u'CLIPGenericStatus', u'modelid': u'HUELABSVTOGGLE'}}, u'config': {u'starterkitid': u'', u'portalconnection': u'connected', u'whitelist': {u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e': {u'last use date': u'2021-06-06T10:48:03', u'create date': u'2017-08-02T17:59:29', u'name': u"hue_ios_app#Yasmin's iPhone SE"}, u'67e4487f-aa2c-41f7-b2ea-c3bd63600505': {u'last use date': u'2021-09-18T13:58:01', u'create date': u'2021-06-06T10:50:25', u'name': u'Hue Beta#iPhone XR'}, u'6ada8095-fcf7-46fb-acd0-5c88cf1e1888': {u'last use date': u'2017-08-01T20:42:29', u'create date': u'2017-07-08T16:02:57', u'name': u"hue_ios_app#Yasmin's iPhone SE"}, u'7HYhiGzk0Fu8DBfvRn4aKFOapMVGPrZbsQCck5cq': {u'last use date': u'2021-09-18T13:59:29', u'create date': u'2016-11-16T18:34:51', u'name': u'Indigo Hue Lights'}, u'8227f6c7-8a38-43c2-a1fc-55eec72589e8': {u'last use date': u'2017-01-13T17:20:31', u'create date': u'2017-01-13T17:10:51', u'name': u"hue_ios_app#Yasmin's iPhone SE"}, u'd7474a44-5a98-4521-8b00-3e843ee4ed54': {u'last use date': u'2019-01-26T14:08:55', u'create date': u'2019-01-07T19:52:07', u'name': u'LightShow-Mac'}, u'3e4c7d2b-a7b7-45d1-8517-90b06f37cd1f': {u'last use date': u'2020-11-05T10:05:19', u'create date': u'2017-01-13T17:09:38', u'name': u"OnSwitch#Yasmin's iPhone SE"}, u'b7b7c171-2f17-4f14-91c8-0c78cf058c89': {u'last use date': u'2020-11-29T20:15:26', u'create date': u'2019-01-07T20:42:26', u'name': u"HueLights#Yasmin's iPhone SE"}}, u'zigbeechannel': 20, u'timezone': u'Europe/Berlin', u'gateway': u'192.168.100.254', u'modelid': u'BSB002', u'portalstate': {u'communication': u'disconnected', u'outgoing': True, u'signedon': True, u'incoming': False}, u'proxyaddress': u'none', u'datastoreversion': u'111', u'replacesbridgeid': None, u'swupdate2': {u'bridge': {u'state': u'noupdates', u'lastinstall': u'2021-09-15T12:48:08'}, u'lastchange': u'2021-09-15T12:49:00', u'checkforupdate': False, u'state': u'noupdates', u'autoinstall': {u'on': True, u'updatetime': u'T14:00:00'}}, u'dhcp': True, u'localtime': u'2021-09-18T15:59:29', u'proxyport': 0, u'UTC': u'2021-09-18T13:59:29', u'factorynew': False, u'swupdate': {u'devicetypes': {u'bridge': False, u'sensors': [], u'lights': []}, u'url': u'', u'text': u'', u'checkforupdate': False, u'updatestate': 0, u'notify': True}, u'apiversion': u'1.46.0', u'mac': u'00:17:88:40:4e:5f', u'linkbutton': False, u'bridgeid': u'001788FFFE404E5F', u'ipaddress': u'192.168.100.105', u'portalservices': False, u'name': u'Philips hue', u'swversion': u'1947054040', u'netmask': u'255.255.255.0', u'internetservices': {u'swupdate': u'connected', u'time': u'connected', u'remoteaccess': u'disconnected', u'internet': u'connected'}, u'backup': {u'status': u'idle', u'errorcode': 0}}}
Hue Lights Loaded 8 lights.
Hue Lights Loaded 6 groups.
Hue Lights Loaded 24 scenes.
Hue Lights Loaded 3 sensors.
Hue Lights Debug Starting device: Alle Hue Lampen
Hue Lights Debug Starting rebuildDevice.
Hue Lights Debug Checking if the Alle Hue Lampen device needs to be rebuilt.
Hue Lights Debug Device details before rebuild check:
address : 192.168.100.105 (GID 0)
batteryLevel : None
blueLevel : 0.0
brightness : 0
buttonConfiguredCount : 0
buttonGroupCount : 0
configured : True
defaultBrightness : 100
description :
deviceTypeId : hueGroup
displayStateValRaw : 0
displayStateValUi : 0
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 0
com.nathansheldon.indigoplugin.HueLights : (dict)
SupportsColor : true (bool)
SupportsRGB : true (bool)
SupportsRGBandWhiteSimultaneously : false (bool)
SupportsWhite : true (bool)
SupportsWhiteTemperature : true (bool)
WhiteTemperatureMax : 6500 (string)
WhiteTemperatureMin : 2000 (string)
address : 192.168.100.105 (GID 0) (string)
defaultBrightness : (string)
groupClass : (string)
groupId : 0 (string)
groupLights : (list)
groupLightsDisabler : false (bool)
nameOnHub : (string)
rate : (string)
savedBrightness : (string)
type : (string)
greenLevel : 0.0
lastChanged : 2000-01-01 00:00:00
lastSuccessfulComm : 2000-01-01 00:00:00
ledStates : []
model : Hue Group
name : Alle Hue Lampen
onBrightensToDefaultToggle : False
onBrightensToLast : False
onState : False
ownerProps : com.nathansheldon.indigoplugin.HueLights : (dict)
rate : (string)
type : (string)
pluginId : com.nathansheldon.indigoplugin.HueLights
pluginProps : com.nathansheldon.indigoplugin.HueLights : (dict)
rate : (string)
type : (string)
protocol : Plugin
redLevel : 0.0
remoteDisplay : True
states : States : (dict)
alertMode : (string)
allOn : false (bool)
anyOn : false (bool)
blueLevel : 0 (integer)
colorMode : (string)
colorTemp : 0 (integer)
colorX : 0 (integer)
colorY : 0 (integer)
effect : (string)
greenLevel : 0 (integer)
groupMemberIDs : (string)
hue : 0 (integer)
redLevel : 0 (integer)
saturation : 0 (integer)
whiteLevel : 0 (integer)
whiteTemperature : 0 (integer)
subModel :
subType :
supportsAllOff : False
supportsColor : True
supportsRGB : True
supportsStatusRequest : True
supportsWhite : True
supportsWhiteTemperature : True
version : None
whiteLevel : 0.0
whiteLevel2 : None
Hue Lights Debug Verifying the Alle Hue Lampen group device.
Hue Lights Debug Telling server to reload state list and display state.
Hue Lights Debug Starting getDeviceStateList for the "Alle Hue Lampen" device.
Hue Lights Debug rebuildDevice complete.
Hue Lights Debug Hue Group device definition:
batteryLevel : None
blueLevel : 0.0
brightness : 0
configured : True
description :
enabled : True
errorState :
folderId : 0
com.indigodomo.indigoserver : (dict)
rate : (string)
type : (string)
greenLevel : 0.0
ledStates : []
model : Hue Group
onState : False
rate : (string)
type : (string)
rate : (string)
type : (string)
protocol : Plugin
redLevel : 0.0
effect : (string)
hue : 0 (integer)
subModel :
subType :
supportsRGB : True
version : None
whiteLevel : 0.0
whiteLevel2 : None
Hue Lights Debug Starting device: Bettlampe
Hue Lights Debug Checking if the Bettlampe device needs to be rebuilt.
address : 192.168.100.105 (ID 4)
batteryLevel : None
blueLevel : 0.0
brightness : 0
configured : True
description :
deviceTypeId : hueBulb
enabled : True
errorState :
folderId : 1036166448
publish-device : true (bool)
sub-type : Color Dimmer (string)
address : 192.168.100.105 (ID 4) (string)
bulbId : 4 (string)
defaultBrightness : 100 (string)
manufacturerName : innr (string)
modelId : RB 185 C (string)
nameOnBridge : Bettlampe (string)
nameOnHub : Bettlampe (string)
nameOnbridge : Bettlampe (string)
rate : 5 (string)
savedBrightness : 1 (integer)
swVersion : 2.0 (string)
type : Extended color light (string)
uniqueId : 00:15:8d:00:02:0a:f5:3c-01 (string)
greenLevel : 0.0
lastChanged : 2021-09-16 20:02:21
lastSuccessfulComm : 2021-09-16 20:02:21
ledStates : []
model : Hue Color/Ambiance (Original, Downlight, Spotlight, etc.)
onState : False
bulbId : 4 (string)
rate : 5 (string)
bulbId : 4 (string)
rate : 5 (string)
protocol : Plugin
redLevel : 0.0
blueLevel : 0.00000000 (real)
colorMode : ct (string)
colorMode.ui : ct (string)
colorTemp : 2703 (integer)
colorTemp.ui : 2703 (string)
colorX : 0.4578 (real)
colorX.ui : 0.4578 (string)
colorY : 0.4101 (real)
colorY.ui : 0.4101 (string)
greenLevel : 0.00000000 (real)
hue : 0 (integer)
hue.ui : 0 (string)
redLevel : 0.00000000 (real)
saturation : 80 (integer)
saturation.ui : 80 (string)
whiteLevel : 20.00000000 (real)
whiteLevel.ui : 20 (string)
whiteTemperature : 2703.00000000 (real)
whiteTemperature.ui : 2703 (string)
subModel :
subType :
supportsRGB : True
version : None
whiteLevel : 20.0
whiteLevel2 : None
Hue Lights Debug Verifying the Bettlampe lighting device properties.
Hue Lights Debug Starting getDeviceStateList for the "Bettlampe" device.
Hue Lights Debug Hue device definition:
batteryLevel : None
blueLevel : 0.0
brightness : 0
configured : True
description :
enabled : True
errorState :
bulbId : 4 (string)
rate : 5 (string)
greenLevel : 0.0
ledStates : []
onState : False
bulbId : 4 (string)
rate : 5 (string)
bulbId : 4 (string)
rate : 5 (string)
protocol : Plugin
redLevel : 0.0
alertMode : lselect (string)
alertMode.ui : lselect (string)
blueLevel.ui : 0 (string)
brightnessLevel : 0 (integer)
brightnessLevel.ui : 0 (string)
colorBlue : 0 (integer)
colorBlue.ui : 0 (string)
colorGreen : 0 (integer)
colorGreen.ui : 0 (string)
colorRed : 0 (integer)
colorRed.ui : 0 (string)
effect : none (string)
effect.ui : none (string)
greenLevel.ui : 0 (string)
hue : 0 (integer)
hue.ui : 0 (string)
online : true (bool)
online.ui : True (string)
redLevel.ui : 0 (string)
subModel :
subType :
supportsRGB : True
version : None
whiteLevel : 20.0
whiteLevel2 : None
Hue Lights Debug Starting device: Bettlampe links
Hue Lights Debug Checking if the Bettlampe links device needs to be rebuilt.
address : 192.168.100.105 (ID 7)
batteryLevel : None
blueLevel : 0.0
brightness : 0
configured : True
description :
enabled : True
errorState :
address : 192.168.100.105 (ID 7) (string)
bulbId : 7 (string)
defaultBrightness : 75 (string)
manufacturerName : OSRAM (string)
modelId : PAR 16 50 RGBW - LIGHTIFY (string)
nameOnBridge : Bettlampe links (string)
nameOnHub : Bettlampe links (string)
rate : 5 (string)
swVersion : V1.04.12 (string)
uniqueId : 7c:b0:3e:aa:00:ab:5a:0b-03 (string)
greenLevel : 0.0
lastChanged : 2021-09-16 13:24:48
lastSuccessfulComm : 2021-09-16 13:24:48
ledStates : []
onState : False
bulbId : 7 (string)
rate : 5 (string)
bulbId : 7 (string)
rate : 5 (string)
protocol : Plugin
redLevel : 0.0
alertMode : select (string)
alertMode.ui : select (string)
colorX : 0.3805 (real)
colorX.ui : 0.3805 (string)
colorY : 0.3769 (real)
colorY.ui : 0.3769 (string)
hue : 0 (integer)
hue.ui : 0 (string)
saturation.ui : 0 (string)
whiteLevel : 100.00000000 (real)
whiteLevel.ui : 100 (string)
subModel :
subType :
supportsRGB : True
version : None
whiteLevel : 100.0
whiteLevel2 : None
Hue Lights Debug Verifying the Bettlampe links lighting device properties.
Hue Lights Debug Starting getDeviceStateList for the "Bettlampe links" device.
batteryLevel : None
blueLevel : 0.0
brightness : 0
configured : True
description :
enabled : True
errorState :
bulbId : 7 (string)
rate : 5 (string)
greenLevel : 0.0
ledStates : []
onState : False
bulbId : 7 (string)
rate : 5 (string)
bulbId : 7 (string)
rate : 5 (string)
protocol : Plugin
redLevel : 0.0
hue : 0 (integer)
hue.ui : 0 (string)
subModel :
subType :
supportsRGB : True
version : None
whiteLevel : 100.0
whiteLevel2 : None
Hue Lights Debug Starting device: Bettlampe rechts
Hue Lights Debug Checking if the Bettlampe rechts device needs to be rebuilt.
address : 192.168.100.105 (ID 6)
batteryLevel : None
blueLevel : 0.0
brightness : 0
configured : True
description :
enabled : True
errorState :
address : 192.168.100.105 (ID 6) (string)
bulbId : 6 (string)
nameOnBridge : Bettlampe rechts (string)
nameOnHub : Bettlampe rechts (string)
rate : 5 (string)
uniqueId : 7c:b0:3e:aa:00:ab:64:b3-03 (string)
greenLevel : 0.0
lastChanged : 2021-09-17 22:23:46
lastSuccessfulComm : 2021-09-17 22:23:46
ledStates : []
onState : False
bulbId : 6 (string)
rate : 5 (string)
bulbId : 6 (string)
rate : 5 (string)
protocol : Plugin
redLevel : 0.0
hue : 0 (integer)
hue.ui : 0 (string)
subModel :
subType :
supportsRGB : True
version : None
whiteLevel : 100.0
whiteLevel2 : None
Hue Lights Debug Verifying the Bettlampe rechts lighting device properties.
Hue Lights Debug Starting getDeviceStateList for the "Bettlampe rechts" device.
batteryLevel : None
blueLevel : 0.0
brightness : 0
configured : True
description :
enabled : True
errorState :
bulbId : 6 (string)
rate : 5 (string)
greenLevel : 0.0
ledStates : []
onState : False
bulbId : 6 (string)
rate : 5 (string)
Re: Hue Lights discussion
Posted:
Sun Sep 19, 2021 3:40 am
by nsheldon
Hi Yassi.
Sure! Thanks for all the details. I'll add support in the next plugin version.
Posted:
Sun Sep 19, 2021 3:45 am
by yassi
nsheldon wrote:Hi Yassi.
Great! Thanks a lot, Nathan!
Gesendet von iPhone mit Tapatalk
Posted:
Fri Sep 24, 2021 3:30 pm
by jroach
I noticed that my Hue lights were not working through Indigo.
The IP address of the Hue hub is 192.168.1.3 while Indigo it says that it is 192.168.1.2. Restarted Indigo (same), unplugged the hub (same),.
I then looked at the plugin and it was correct (192.168.1.3) but the address in the list of devices is still 192.168.1.2.
I removed the Preferences file for the hue plugin (disabling the plugin first), enabled, then configured. I enter the IP, press the button and hit "Pair".
It says "pairing" but that never goes to anything else.
Is it stuck?
Posted:
Fri Sep 24, 2021 4:57 pm
by jroach
Correction, Hue lights work from Indigo but the IP address is still different and triggers/schedules seem to be flakey.
Posted:
Sat Sep 25, 2021 2:52 pm
by nsheldon
jroach wrote:Correction, Hue lights work from Indigo but the IP address is still different and triggers/schedules seem to be flakey.
Hi. For the device addresses in Indigo, if the IP address of the Hue hub changes after the device in Indigo was created, the Indigo device will not reflect the new IP address of the Hue hub unless you edit the device in Indigo. The device address, at least with the Hue Lights plugin, is not actually critical to the device working in Indigo. It's just a reference value primarily for sorting and searching purposes. As you've noticed, the device continues to work even if the device address shown is incorrect.
As for flaky triggers and schedules, that's not really enough information to determine what the source of the problem is. You'll probably need to do some more trial and error testing to narrow down under what conditions the triggers and schedules fail and under which conditions they succeed in order to determine the source of the problem. For example, do triggers based on a specific device fail? Or a specific group of devices? Do they fail during specific times of day, when some other device is on (or off)? Is it the trigger that fails to be activated or the action taken by the trigger that fails to complete? (I'm assuming the latter).
Posted:
Sat Sep 25, 2021 3:05 pm
by nsheldon
Version 1.7.58 Posted- Added support for the Lightway/Megos E27 806 lumen bulb.
Posted:
Sun Sep 26, 2021 9:56 am
by yassi
Thanks, Nathan!
Looking good!
Yassi
Posted:
Tue Oct 12, 2021 5:03 pm
by andarv
I really appreciate your pluggin.
When I was adding a few new lights I wasn't able to find them as new devices, the plugin identifies correct number of lights but they don't show up as HUE devices under device settings.
I tried to reload, re pair etc but it doesn't make any difference.
It's two lamps that doesn't show up.
Hue ambient ceiling (have a working one with model nr LTC003)
Model 3261330P6
Hue Color pendant
Model 4090331P9_01 (and 02)
Posted:
Thu Oct 14, 2021 12:23 am
by nsheldon
Thanks for the report. I can add support for those in the next update. However, could you please provide a screenshot from the Hue app showing those models just so I can be sure I get the exact model ID and light type down? Thanks.
andarv wrote:Hi,
Model 3261330P6
Hue Color pendant
Posted:
Fri Oct 15, 2021 12:33 am
by andarv
Here are the two lamps.
The pendant consits of two separate lamps one for Up/down
Posted:
Fri Oct 15, 2021 1:02 am
by nsheldon
Great! Thanks! I'll add support in the next release.
Posted:
Sat Oct 16, 2021 2:27 pm
by andarv
Great, thanks for the support!
Skickat från min IN2023 via Tapatalk
Posted:
Sat Oct 16, 2021 3:40 pm
by vtmikel
Hi there-
Thanks for the great plugin.
I was hoping to make a request. I run scenes for my Hue lights which animate them slowly. The plugin floods the indigo log with updates. I was wondering if there was a way to quiet some of the updates to the log?
Thanks again.
Mike
