TRADFRI bulb E26 WW clear 250lm
Sun Apr 11, 2021 7:38 am
achterberg offline
Could you add support for the following?
Got response {u'5': {u'swversion': u'2.1.022', u'name': u'Tradfri bulb 2', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2021-04-11T00:17:38'}, u'uniqueid': u'14:b4:57:ff:fe:4a:52:72-01', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Dimmable light', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'TRADFRI bulb E26 WW clear 250lm'}
Sun Apr 11, 2021 1:08 pm
nsheldon offline
Re: TRADFRI bulb E26 WW clear 250lm
Hi.
Certainly. I’ll add support in the next update. Thanks for the report.
Mon Apr 19, 2021 12:29 am
nsheldon offline
Version 1.7.49 Posted
  • Added support for a new TRADFRI dimmable bulb.
  • Added support for an eWeLight full color/color temperature bulb.
  • Added support for the Hue Wall Switch module.
  • Added support for a new Hue ambiance downlight.
  • Added option to disable ON and OFF ramp rates (transition times) in lighting device configuration dialogs to help improve compatibility with non-Hue lights.
  • Fixed a bug that would cause the wrong color to be sent to a Hue Group when using the RGB picker in the Indigo UI.
