Yup
I should have been clearer.
I have good quality strips but the range of zigbee controllers I have tried are not as solid as the hue contollers
joesan wrote:Thanks Nathan. You're a gent.
May I ask you, what's the best option to choose here to control a WW/CW strip?
I can switch on and alter the colour temperature of my white only strips using the Gledopto RGB-CCT controller but it's a bit hit and miss. If I bought the GLEDOPTO CW/WW controller what model of light would I choose and would your Hue plugin only show controls for white (as opposed to RGB)?
Assuming the Hue bridge sends the correct ZigBee commands with the WW/CW and RGB-CCT controllers (and the controller understands them), you should be able to set the color temperature on any controller that supports the color temperature method specifying color.
29/04/2019, 5:25:58 PM
Hue Lights Turning on debug logging
Hue Lights Debug Starting updateSensorsList.
Hue Lights Debug Starting parseAllHueSensorsData.
Hue Lights Debug Starting updateLightsList.
Hue Lights Debug Sending command to bridge: http://192.168.1.47/api/rLyZsLoM5RWlJu01Zv5gWOSQ92Fhk4Ry-Q4ya9yy/lights
Hue Lights Debug Got response {u'11': {u'swversion': u'2.0', u'name': u'On/Off plug 1', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-02-23T15:10:32'}, u'uniqueid': u'00:15:8d:00:03:56:ab:ae-01', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'On/Off plug', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'alert': u'select'}, u'manufacturername': u'innr', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'On/Off plug-in unit', u'modelid': u'SP 120'}, u'13': {u'swversion': u'2.0', u'name': u'Tresen1', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-04-29T14:20:02'}, u'uniqueid': u'00:15:8d:00:03:61:87:46-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 200}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 447}, u'manufacturername': u'innr', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'RS 228 T'}, u'12': {u'swversion': u'1.46.13_r26312', u'name': u'Fins bathroom striplight', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-03-09T13:27:20'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:04:49:0c:04-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 8615, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4439, 0.4065], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 344, u'sat': 119}, u'manufacturername': u'Philips', u'swconfigid': u'A25796CB', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'14': {u'swversion': u'2.0', u'name': u'Tresen2', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-04-29T14:24:38'}, u'uniqueid': u'00:15:8d:00:03:61:9e:f4-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 200}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 447}, u'manufacturername': u'innr', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'RS 228 T'}, u'1': {u'swversion': u'1.46.13_r26312', u'name': u'Entrance Diele Lightstrip', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:26'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:03:e1:49:1d-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'lselect', u'xy': [0.6915, 0.3083], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 153, u'sat': 254}, u'manufacturername': u'Philips', u'swconfigid': u'A25796CB', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'3': {u'swversion': u'1.46.13_r26312', u'name': u'Sideboard', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:05'}, u'productid': u'Philips-LTW010-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:9e:97:d1-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 806, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'lselect', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'7A2E82CC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'customsettings': {u'bri': 215, u'ct': 447}, u'mode': u'custom'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW010'}, u'2': {u'swversion': u'1.46.13_r26312', u'name': u'Upstairs Bookshelf', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:00'}, u'productid': u'Philips-LTW010-1-A19CTv2', u'uniqueid': u'00:17:88:01:04:e3:8a:d0-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 806, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'lselect', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'7A2E82CC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'customsettings': {u'bri': 144, u'ct': 447}, u'mode': u'custom'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW010'}, u'5': {u'swversion': u'1.46.13_r26312', u'name': u'Black Lady Head', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:48:55'}, u'productid': u'Philips-LWB010-1-A19DLv4', u'uniqueid': u'00:17:88:01:04:22:91:75-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 183, u'alert': u'lselect'}, u'manufacturername': u'Philips', u'swconfigid': u'322BB2EC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'4': {u'swversion': u'1.46.13_r26312', u'name': u'Studio Door', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:10'}, u'productid': u'Philips-LWB010-1-A19DLv4', u'uniqueid': u'00:17:88:01:03:4d:53:cc-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 183, u'alert': u'lselect'}, u'manufacturername': u'Philips', u'swconfigid': u'322BB2EC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'7': {u'swversion': u'1.46.13_r26312', u'name': u'Lounge Sideboard L', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:15'}, u'productid': u'Philips-LTW010-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:79:6a:4d-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 806, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'lselect', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'7A2E82CC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'customsettings': {u'bri': 254, u'ct': 447}, u'mode': u'custom'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW010'}, u'6': {u'swversion': u'1.46.13_r26312', u'name': u'Lounge Sideboard R', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:20'}, u'productid': u'Philips-LTW010-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:11:80:ee-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 806, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'lselect', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'7A2E82CC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'customsettings': {u'bri': 254, u'ct': 447}, u'mode': u'custom'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW010'}, u'9': {u'swversion': u'1.0.6', u'name': u'Lounge Strip Lighting', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-02-14T18:21:52'}, u'uniqueid': u'00:12:4b:00:1b:92:0e:f8-0b', u'capabilities': {u'control': {u'ct': {u'max': 65535, u'min': 0}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 7424, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.526, 0.4591], u'reachable': False, u'mode': u'homeautomation', u'bri': 57, u'ct': 482, u'sat': 20}, u'manufacturername': u'GLEDOPTO', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'GL-C-008'}, u'8': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen Unit Lightstrip', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-14T15:31:13'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:04:49:94:37-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 7676, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5016, 0.4151], u'reachable': True, u'mode': u'homeautomation', u'bri': 144, u'ct': 443, u'sat': 199}, u'manufacturername': u'Philips', u'swconfigid': u'A25796CB', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}}
Hue Lights Debug Loaded lights list - {u'11': {u'swversion': u'2.0', u'name': u'On/Off plug 1', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-02-23T15:10:32'}, u'uniqueid': u'00:15:8d:00:03:56:ab:ae-01', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'On/Off plug', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'alert': u'select'}, u'manufacturername': u'innr', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'On/Off plug-in unit', u'modelid': u'SP 120'}, u'13': {u'swversion': u'2.0', u'name': u'Tresen1', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-04-29T14:20:02'}, u'uniqueid': u'00:15:8d:00:03:61:87:46-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 200}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 447}, u'manufacturername': u'innr', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'RS 228 T'}, u'12': {u'swversion': u'1.46.13_r26312', u'name': u'Fins bathroom striplight', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-03-09T13:27:20'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:04:49:0c:04-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 8615, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4439, 0.4065], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 344, u'sat': 119}, u'manufacturername': u'Philips', u'swconfigid': u'A25796CB', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'14': {u'swversion': u'2.0', u'name': u'Tresen2', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-04-29T14:24:38'}, u'uniqueid': u'00:15:8d:00:03:61:9e:f4-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 200}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 447}, u'manufacturername': u'innr', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'RS 228 T'}, u'1': {u'swversion': u'1.46.13_r26312', u'name': u'Entrance Diele Lightstrip', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:26'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:03:e1:49:1d-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'lselect', u'xy': [0.6915, 0.3083], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 153, u'sat': 254}, u'manufacturername': u'Philips', u'swconfigid': u'A25796CB', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'3': {u'swversion': u'1.46.13_r26312', u'name': u'Sideboard', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:05'}, u'productid': u'Philips-LTW010-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:9e:97:d1-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 806, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'lselect', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'7A2E82CC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'customsettings': {u'bri': 215, u'ct': 447}, u'mode': u'custom'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW010'}, u'2': {u'swversion': u'1.46.13_r26312', u'name': u'Upstairs Bookshelf', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:00'}, u'productid': u'Philips-LTW010-1-A19CTv2', u'uniqueid': u'00:17:88:01:04:e3:8a:d0-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 806, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'lselect', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'7A2E82CC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'customsettings': {u'bri': 144, u'ct': 447}, u'mode': u'custom'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW010'}, u'5': {u'swversion': u'1.46.13_r26312', u'name': u'Black Lady Head', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:48:55'}, u'productid': u'Philips-LWB010-1-A19DLv4', u'uniqueid': u'00:17:88:01:04:22:91:75-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 183, u'alert': u'lselect'}, u'manufacturername': u'Philips', u'swconfigid': u'322BB2EC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'4': {u'swversion': u'1.46.13_r26312', u'name': u'Studio Door', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:10'}, u'productid': u'Philips-LWB010-1-A19DLv4', u'uniqueid': u'00:17:88:01:03:4d:53:cc-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 183, u'alert': u'lselect'}, u'manufacturername': u'Philips', u'swconfigid': u'322BB2EC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'7': {u'swversion': u'1.46.13_r26312', u'name': u'Lounge Sideboard L', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:15'}, u'productid': u'Philips-LTW010-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:79:6a:4d-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 806, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'lselect', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'7A2E82CC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'customsettings': {u'bri': 254, u'ct': 447}, u'mode': u'custom'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW010'}, u'6': {u'swversion': u'1.46.13_r26312', u'name': u'Lounge Sideboard R', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:20'}, u'productid': u'Philips-LTW010-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:11:80:ee-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 806, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'lselect', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'7A2E82CC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'customsettings': {u'bri': 254, u'ct': 447}, u'mode': u'custom'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW010'}, u'9': {u'swversion': u'1.0.6', u'name': u'Lounge Strip Lighting', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-02-14T18:21:52'}, u'uniqueid': u'00:12:4b:00:1b:92:0e:f8-0b', u'capabilities': {u'control': {u'ct': {u'max': 65535, u'min': 0}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 7424, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.526, 0.4591], u'reachable': False, u'mode': u'homeautomation', u'bri': 57, u'ct': 482, u'sat': 20}, u'manufacturername': u'GLEDOPTO', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'GL-C-008'}, u'8': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen Unit Lightstrip', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-14T15:31:13'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:04:49:94:37-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 7676, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5016, 0.4151], u'reachable': True, u'mode': u'homeautomation', u'bri': 144, u'ct': 443, u'sat': 199}, u'manufacturername': u'Philips', u'swconfigid': u'A25796CB', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}}
Hue Lights Debug Starting parseAllHueLightsData.
Hue Lights Debug parseAllHueLightsData: There are 13 lights on the Hue bridge and 11 Indigo devices controlling Hue devices.
Hue Lights Debug Starting updateGroupsList.
Hue Lights Debug Sending command to bridge: http://192.168.1.47/api/rLyZsLoM5RWlJu01Zv5gWOSQ92Fhk4Ry-Q4ya9yy/groups
Hue Lights Debug Got response {u'10': {u'name': u'Upstairs Hallway', u'lights': [u'2', u'12'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8615, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4439, 0.4065], u'bri': 1, u'ct': 344, u'sat': 119}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'1': {u'name': u'Couch Group', u'lights': [u'11'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Studio', u'lights': [u'6', u'7'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'lselect', u'colormode': u'ct', u'bri': 1, u'ct': 454}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'2': {u'name': u'Lounge Group', u'lights': [u'9'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 7424, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.526, 0.4591], u'bri': 57, u'ct': 482, u'sat': 20}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'7': {u'name': u'Entrance', u'lights': [u'3', u'1'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'lselect', u'xy': [0.6915, 0.3083], u'bri': 1, u'ct': 153, u'sat': 254}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'9': {u'name': u'Kitchen', u'lights': [u'8', u'13', u'14'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 7676, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.5016, 0.4151], u'bri': 254, u'ct': 447, u'sat': 199}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}}
Hue Lights Debug Loaded groups list - {u'10': {u'name': u'Upstairs Hallway', u'lights': [u'2', u'12'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8615, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4439, 0.4065], u'bri': 1, u'ct': 344, u'sat': 119}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'1': {u'name': u'Couch Group', u'lights': [u'11'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Studio', u'lights': [u'6', u'7'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'lselect', u'colormode': u'ct', u'bri': 1, u'ct': 454}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'2': {u'name': u'Lounge Group', u'lights': [u'9'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 7424, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.526, 0.4591], u'bri': 57, u'ct': 482, u'sat': 20}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'7': {u'name': u'Entrance', u'lights': [u'3', u'1'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'lselect', u'xy': [0.6915, 0.3083], u'bri': 1, u'ct': 153, u'sat': 254}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'9': {u'name': u'Kitchen', u'lights': [u'8', u'13', u'14'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 7676, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.5016, 0.4151], u'bri': 254, u'ct': 447, u'sat': 199}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}}
Hue Lights Debug Starting parseAllHueGroupsData.
Hue Lights Debug Starting parseOneHueGroupData.
