Impossible to add/configure second bridge
Fri Jul 22, 2022 1:07 am
MarcoGT offline
Hi Karl,
I am trying to add a second bridge.
It is detected, but when in config I click confirm I get this warning (not error)
Hue Lights Warning
  File "plugin.py", line 2686, in selHubNumberGWPair
    valuesDict['hostId'] = self.hostIds[self.hubNumberSelected]
KeyError: '1'
and I cannot load any device from that bridge.
Marco
Fri Jul 22, 2022 6:48 am
Re: Impossible to add/configure second bridge
please try v 2022.12.37 just posted.
Sat Jul 23, 2022 1:59 pm
MarcoGT offline
It works, thanks.
I have now following problem
Hue Lights                      debug areas:[]
   Hue Lights                      bridge lights groups scenes users resources rules schedules sensors hostIds / user names ------------------- ip Numbers ---- BridgeIds-------
   Hue Lights Warning              #0    ; ipNumber:192.168.2.11 --- not properly setup
   Hue Lights                      #1          4      2      2     0         0     0         0       1 P-ILAfP2BUsVFHEPHOTxZicr3EdxvN30HVZVN6R1 192.168.2.141   ECB5FAFFFEA8E5A1
   Hue Lights                      ... initialized
Hue Lights                      Sent Hue Lights  "Bagno EG-1" off.
   Hue Lights                      updateDeviceState: Updating device "Bagno EG-1" state: "brightnessLevel". Old value = 15. New value = 0
   Hue Lights Error                Error retrieving Hue device status: method, GET, not available for resource, / for device :Bagno EG-1
   Hue Lights                      Sent Hue Lights  "Bagno EG-2" off.
   Hue Lights                      updateDeviceState: Updating device "Bagno EG-2" state: "brightnessLevel". Old value = 15. New value = 0
   Hue Lights Error                Error retrieving Hue device status: method, GET, not available for resource, / for device :Bagno EG-2
The "configure" dialog says that everything is configured and fully operational (see attached image), but as you can see from the logs, it seems not properly set up, and in fact in the Indigo logs I do not see the motion sensors event and also turn on/off via Indigo is not working
Screenshot 2022-07-23 alle 21.58.16.png (397.41 KiB) Viewed 1463 times
Sat Jul 23, 2022 11:14 pm
could you re-pair bridge#0 and then save config and restart the plugin
Sun Jul 24, 2022 3:56 am
MarcoGT offline
Yes, I did it and it works partially, as for a motion sensor I do not get data
Sun Jul 24, 2022 10:12 am
please try the version i just posted 2022.12.38 @ 2022-07-24
it adds a check for not completely defined bridges.
and has a print pluginpreferences. if you continue to have that issue, please do menu print hue config ../ print plugin prefs
and post the contents of hoatIds and addresses (with s at the end , not address and hostid)
Mon Jul 25, 2022 2:10 pm
MarcoGT
please try v 2022.12.39.
that should finally put that issue to rest.
