- Posted on
Wed Sep 27, 2023 10:23 am
offline
2022.16.53 @ 2023-09-27
Added option to REPLACE a (eg broken) hue light in indigo - ie keep the indigo ID (and trigger etc) and link it to the new Hue device
In indigo device edit Lights you now have 3 options:
1. normal edit, no change
2. replace the hue device an indigo device is linked to
- add new hue device to hue bridge, then edit the old indigo device and select "replace device, select new Hue device"
3. copy other indigo device (eg already created indigo device for new replaced hue device, but you would like to keep triggers etc in place that use THIS indigo device id)
- edit old Indigo device and select option: "replace device, copy other Indigo device to this device"
after save delete the indigo device that was copied from.
