HomeKitLink Siri will not run after migrating to a new Mac
Posted: Fri Mar 08, 2024 10:50 pm
Hello...I migrated Indigo 2023.2 from an Intel Mac to a M2 Mac and everything works except the HomeKitLink Siri plugin will not load. I disabled, removed, and reinstalled, but that did not work.
I get this error when trying to install. Any recommendation on how to resolve? Thank you!
- Code: Select all
Loading external plugins
Loading plugin "HomeKitLink Siri 0.6.61" using API v3.4
Starting plugin "HomeKitLink Siri 0.6.61" (pid 941)
Processing requirements for plugin "HomeKitLink Siri 0.6.61"
Requirements installing, this may take a few seconds...
Error Requirements file for "HomeKitLink Siri 0.6.61" failed to process correctly, contact the developer with the following information:
Error error: subprocess-exited-with-error
× Building wheel for zeroconf (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [344 lines of output]
A setup.py file already exists. Using it.
warning: src/zeroconf/_cache.py:47:23: Unknown type declaration '_DNSRecordCacheType' in annotation, ignoring
warning: src/zeroconf/_cache.py:47:49: Unknown type declaration '_str' in annotation, ignoring
warning: src/zeroconf/_cache.py:47:63: Unknown type declaration '_DNSRecord' in annotation, ignoring
warning: src/zeroconf/_cache.py:67:33: Unknown type declaration '_DNSRecord' in annotation, ignoring
warning: src/zeroconf/_cache.py:100:36: Unknown type declaration '_DNSRecord' in annotation, ignoring
warning: src/zeroconf/_cache.py:117:32: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_cache.py:126:38: Unknown type declaration '_UniqueRecordsType' in annotation, ignoring
warning: src/zeroconf/_cache.py:138:41: Unknown type declaration '_str' in annotation, ignoring
warning: src/zeroconf/_cache.py:138:54: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_cache.py:138:68: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_cache.py:184:47: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_cache.py:184:61: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_cache.py:205:51: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_cache.py:205:65: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_cache.py:237:93: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_dns.py:76:33: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_dns.py:119:31: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_dns.py:191:43: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_dns.py:197:37: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_dns.py:202:30: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_dns.py:206:28: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_dns.py:210:29: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_dns.py:219:39: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_dns.py:255:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_dns.py:300:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_dns.py:346:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_dns.py:380:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_dns.py:429:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_dns.py:480:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_dns.py:552:33: Unknown type declaration '_DNSRecord' in annotation, ignoring
warning: src/zeroconf/_dns.py:224:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_handlers/answers.py:82:50: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/answers.py:90:13: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/answers.py:90:96: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_handlers/answers.py:102:56: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/multicast_outgoing_queue.py:67:29: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_handlers/multicast_outgoing_queue.py:67:46: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/multicast_outgoing_queue.py:89:50: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:118:48: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:129:51: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:134:51: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:206:44: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:220:55: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:238:20: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:240:15: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:267:23: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:403:14: Unknown type declaration '_str' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:404:14: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_handlers/query_handler.py:405:19: Unknown type declaration '_WrappedTransport' in annotation, ignoring
warning: src/zeroconf/_handlers/record_manager.py:51:33: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_history.py:41:63: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_history.py:45:53: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_history.py:67:32: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_listener.py:87:20: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/zeroconf/_listener.py:109:18: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_listener.py:110:13: Unknown type declaration '_float' in annotation, ignoring
warning: src/zeroconf/_listener.py:111:14: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/zeroconf/_listener.py:189:14: Unknown type declaration '_str' in annotation, ignoring
warning: src/zeroconf/_listener.py:190:14: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_listener.py:191:19: Unknown type declaration '_WrappedTransport' in annotation, ignoring
warning: src/zeroconf/_listener.py:214:48: Unknown type declaration '_str' in annotation, ignoring
warning: src/zeroconf/_listener.py:222:14: Unknown type declaration '_str' in annotation, ignoring
warning: src/zeroconf/_listener.py:223:14: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_listener.py:224:19: Unknown type declaration '_WrappedTransport' in annotation, ignoring
warning: src/zeroconf/_protocol/incoming.py:262:35: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_protocol/incoming.py:305:22: Unknown type declaration '_str' in annotation, ignoring
warning: src/zeroconf/_protocol/incoming.py:305:35: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_protocol/incoming.py:305:49: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_protocol/incoming.py:305:60: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_protocol/incoming.py:305:74: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_protocol/incoming.py:362:32: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_protocol/incoming.py:394:44: Unknown type declaration '_int' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:152:67: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:200:33: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:205:32: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:209:44: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:213:36: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:213:49: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:217:33: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:232:34: Unknown type declaration 'bytes_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:239:28: Unknown type declaration 'str_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:257:31: Unknown type declaration 'str_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:300:41: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:306:40: Unknown type declaration 'DNSQuestion_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:323:33: Unknown type declaration 'DNSRecord_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:323:50: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:327:36: Unknown type declaration 'DNSRecord_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:327:53: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:349:63: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:349:81: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:368:61: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:376:56: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:384:79: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:393:32: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:393:53: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:393:77: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_protocol/outgoing.py:393:102: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_services/__init__.py:69:64: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_services/__init__.py:73:66: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_services/browser.py:189:39: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:212:16: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:212:35: Unknown type declaration 'bool_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:212:71: Unknown type declaration '_QuestionWithKnownAnswers' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:250:16: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:378:55: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:378:84: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:417:53: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:417:84: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:513:47: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:628:22: Unknown type declaration 'ServiceStateChange' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:629:15: Unknown type declaration 'str_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:630:14: Unknown type declaration 'str_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:645:56: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/browser.py:147:28: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_services/browser.py:153:28: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_services/browser.py:165:28: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_services/browser.py:171:28: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_services/info.py:304:44: Unknown type declaration 'IPVersion' in annotation, ignoring
warning: src/zeroconf/_services/info.py:323:23: Unknown type declaration 'IPVersion' in annotation, ignoring
warning: src/zeroconf/_services/info.py:336:29: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:442:35: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:442:49: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:455:66: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:464:66: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:473:56: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:485:81: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:573:17: Unknown type declaration 'IPVersion' in annotation, ignoring
warning: src/zeroconf/_services/info.py:704:77: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:731:52: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:861:13: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:862:14: Unknown type declaration 'str_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:863:15: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:864:16: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:885:35: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_services/info.py:885:58: Unknown type declaration 'DNSQuestionType' in annotation, ignoring
warning: src/zeroconf/_services/info.py:107:42: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
warning: src/zeroconf/_services/registry.py:82:65: Unknown type declaration '_str' in annotation, ignoring
warning: src/zeroconf/_updates.py:52:56: Unknown type declaration 'float_' in annotation, ignoring
warning: src/zeroconf/_utils/ipaddress.py:112:43: Unknown type declaration 'bytes_' in annotation, ignoring
warning: src/zeroconf/_utils/ipaddress.py:112:58: Unknown type declaration 'int_' in annotation, ignoring
warning: src/zeroconf/_utils/time.py:40:30: Unknown type declaration '_float' in annotation, ignoring
Compiling src/zeroconf/_dns.py because it changed.
Compiling src/zeroconf/_cache.py because it changed.
Compiling src/zeroconf/_history.py because it changed.
Compiling src/zeroconf/_record_update.py because it changed.
Compiling src/zeroconf/_listener.py because it changed.
Compiling src/zeroconf/_protocol/incoming.py because it changed.
Compiling src/zeroconf/_protocol/outgoing.py because it changed.
Compiling src/zeroconf/_handlers/answers.py because it changed.
Compiling src/zeroconf/_handlers/record_manager.py because it changed.
Compiling src/zeroconf/_handlers/multicast_outgoing_queue.py because it changed.
Compiling src/zeroconf/_handlers/query_handler.py because it changed.
Compiling src/zeroconf/_services/__init__.py because it changed.
Compiling src/zeroconf/_services/browser.py because it changed.
Compiling src/zeroconf/_services/info.py because it changed.
Compiling src/zeroconf/_services/registry.py because it changed.
Compiling src/zeroconf/_updates.py because it changed.
Compiling src/zeroconf/_utils/ipaddress.py because it changed.
Compiling src/zeroconf/_utils/time.py because it changed.
[ 1/18] Cythonizing src/zeroconf/_cache.py
[ 2/18] Cythonizing src/zeroconf/_dns.py
[ 3/18] Cythonizing src/zeroconf/_handlers/answers.py
[ 4/18] Cythonizing src/zeroconf/_handlers/multicast_outgoing_queue.py
[ 5/18] Cythonizing src/zeroconf/_handlers/query_handler.py
[ 6/18] Cythonizing src/zeroconf/_handlers/record_manager.py
[ 7/18] Cythonizing src/zeroconf/_history.py
[ 8/18] Cythonizing src/zeroconf/_listener.py
[ 9/18] Cythonizing src/zeroconf/_protocol/incoming.py
[10/18] Cythonizing src/zeroconf/_protocol/outgoing.py
[11/18] Cythonizing src/zeroconf/_record_update.py
[12/18] Cythonizing src/zeroconf/_services/__init__.py
[13/18] Cythonizing src/zeroconf/_services/browser.py
[14/18] Cythonizing src/zeroconf/_services/info.py
[15/18] Cythonizing src/zeroconf/_services/registry.py
[16/18] Cythonizing src/zeroconf/_updates.py
[17/18] Cythonizing src/zeroconf/_utils/ipaddress.py
[18/18] Cythonizing src/zeroconf/_utils/time.py
running build
running build_py
creating /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build
creating /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311
creating /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_record_update.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_cache.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/asyncio.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_updates.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/__init__.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_engine.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_transport.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_core.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_logger.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_listener.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_exceptions.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_history.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/const.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_dns.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
creating /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
copying src/zeroconf/_handlers/multicast_outgoing_queue.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
copying src/zeroconf/_handlers/record_manager.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
copying src/zeroconf/_handlers/__init__.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
copying src/zeroconf/_handlers/query_handler.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
copying src/zeroconf/_handlers/answers.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
creating /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
copying src/zeroconf/_protocol/outgoing.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
copying src/zeroconf/_protocol/__init__.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
copying src/zeroconf/_protocol/incoming.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
creating /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
copying src/zeroconf/_services/registry.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
copying src/zeroconf/_services/__init__.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
copying src/zeroconf/_services/types.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
copying src/zeroconf/_services/browser.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
copying src/zeroconf/_services/info.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
creating /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
copying src/zeroconf/_utils/time.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
copying src/zeroconf/_utils/ipaddress.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
copying src/zeroconf/_utils/asyncio.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
copying src/zeroconf/_utils/net.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
copying src/zeroconf/_utils/__init__.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
copying src/zeroconf/_utils/name.py -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
copying src/zeroconf/py.typed -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_dns.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_updates.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_record_update.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_cache.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_history.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_listener.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
copying src/zeroconf/_handlers/answers.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
copying src/zeroconf/_handlers/record_manager.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
copying src/zeroconf/_handlers/multicast_outgoing_queue.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
copying src/zeroconf/_handlers/query_handler.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
copying src/zeroconf/_protocol/outgoing.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
copying src/zeroconf/_protocol/incoming.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
copying src/zeroconf/_services/browser.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
copying src/zeroconf/_services/__init__.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
copying src/zeroconf/_services/registry.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
copying src/zeroconf/_services/info.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
copying src/zeroconf/_utils/ipaddress.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
copying src/zeroconf/_utils/time.pxd -> /private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
running build_ext
File "/private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/setup.py", line 43, in <module>
setup(**setup_kwargs)
File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/__init__.py", line 103, in setup
return distutils.core.setup(**attrs)
File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 185, in setup
return run_commands(dist)
File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 201, in run_commands
dist.run_commands()
File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 969, in run_commands
self.run_command(cmd)
File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/dist.py", line 963, in run_command
super().run_command(command)
File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 988, in run_command
cmd_obj.run()
File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/_distutils/command/build.py", line 131, in run
self.run_command(cmd_name)
File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/_distutils/cmd.py", line 318, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/_distutils/command/build_ext.py", line 315, in run
customize_compiler(self.compiler)
File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/setuptools/_distutils/sysconfig.py", line 291, in customize_compiler
_osx_support.customize_compiler(_config_vars)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/_osx_support.py", line 488, in customize_compiler
_find_appropriate_compiler(_config_vars)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/_osx_support.py", line 244, in _find_appropriate_compiler
raise SystemError(
SystemError: Cannot locate working compiler
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
main()
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 251, in build_wheel
return _build_backend().build_wheel(wheel_directory, config_settings,
File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/poetry/core/masonry/api.py", line 58, in build_wheel
return WheelBuilder.make_in(
File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 88, in make_in
wb.build(target_dir=directory)
File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 121, in build
self._build(zip_file)
File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 182, in _build
self._run_build_command(setup)
File "/private/tmp/pip-build-env-hjh3gtj2/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 248, in _run_build_command
subprocess.check_call([
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/subprocess.py", line 413, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['/Library/Frameworks/Python.framework/Versions/3.11/bin/python3.11', '/private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/setup.py', 'build', '-b', '/private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build', '--build-purelib', '/private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib', '--build-platlib', '/private/tmp/pip-install-90gr448z/zeroconf_3c0b26beb4f44d7c95e4a899ec5aa78e/build/lib.macosx-10.9-universal2-cpython-311']' returned non-zero exit status 1.
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for zeroconf
× Building wheel for chacha20poly1305-reuseable (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [87 lines of output]
warning: src/chacha20poly1305_reuseable/__init__.py:50:57: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:105:14: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:139:14: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:164:72: Unknown type declaration '_int' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:178:17: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:178:67: Unknown type declaration '_int' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:178:84: Unknown type declaration '_int' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:219:47: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:225:37: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:237:10: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:238:21: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:244:37: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:244:62: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:261:10: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:262:21: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:275:37: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:275:62: Unknown type declaration '_bytes' in annotation, ignoring
Compiling src/chacha20poly1305_reuseable/__init__.py because it changed.
[1/1] Cythonizing src/chacha20poly1305_reuseable/__init__.py
running build
running build_py
creating /private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/build
creating /private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/build/lib.macosx-10.9-universal2-cpython-311
creating /private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
copying src/chacha20poly1305_reuseable/__init__.py -> /private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
copying src/chacha20poly1305_reuseable/py.typed -> /private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
copying src/chacha20poly1305_reuseable/__init__.pxd -> /private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
running build_ext
File "/private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/setup.py", line 35, in <module>
File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/__init__.py", line 103, in setup
File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 185, in setup
File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 201, in run_commands
dist.run_commands()
File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 969, in run_commands
File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/dist.py", line 963, in run_command
File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 988, in run_command
cmd_obj.run()
File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/_distutils/command/build.py", line 131, in run
File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/_distutils/cmd.py", line 318, in run_command
cmd_obj.run()
File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/_distutils/command/build_ext.py", line 315, in run
File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/setuptools/_distutils/sysconfig.py", line 291, in customize_compiler
raise SystemError(
main()
File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/poetry/core/masonry/api.py", line 58, in build_wheel
File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 88, in make_in
File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 121, in build
File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 182, in _build
File "/private/tmp/pip-build-env-765_e1w1/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 248, in _run_build_command
subprocess.CalledProcessError: Command '['/Library/Frameworks/Python.framework/Versions/3.11/bin/python3.11', '/private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/setup.py', 'build', '-b', '/private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/build', '--build-purelib', '/private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/build/lib', '--build-platlib', '/private/tmp/pip-install-90gr448z/chacha20poly1305-reuseable_164fdee5cee94c67bef7480006c6f555/build/lib.macosx-10.9-universal2-cpython-311']' returned non-zero exit status 1.
[end of output]
ERROR: Failed building wheel for chacha20poly1305-reuseable
ERROR: Could not build wheels for zeroconf, chacha20poly1305-reuseable, which is required to install pyproject.toml-based projects
HomeKitLink Siri Error Error in plugin execution InitializeMain:
File "plugin.py", line 21, in <module>
type: No module named 'ifaddr'
Stopping plugin "HomeKitLink Siri 0.6.61" (pid 941)
Waiting for external plugins to initialize
Stopped plugin "HomeKitLink Siri 0.6.61"
