HomeKitLink shuts down after power cut
Wed Aug 16, 2023 3:32 am
CliveS offline
Glenn, I am having problems with short power outages and slowly working out a way to restart all plugins that fail to restart properly due to lack of internal and external IP’s.
The HomeKitLink plugin is one that I cannot restart as it crashes when loading and I end up with a red spot instead of green which means that it will not respond to a reload request and has to be manually started.
Is there a way to restart the plugin after a set time instead of just closing it?
2023-08-15 13:48:57.686   Application   Loading plugin "HomeKitLink Siri 0.6.16" using API v3.2
2023-08-15 13:48:57.690   Application   Starting plugin "HomeKitLink Siri 0.6.16" (pid 685)
2023-08-15 13:48:58.698   HomeKitLink Siri Error   Error in plugin execution InitializeMain:
  File "plugin.py", line 61, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/HomeKitDevices.py", line 34, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/HKConstants.py", line 63, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/pyhap/util.py", line 63, in get_local_address
type: local variable 'addr' referenced before assignment
  HomeKitLink Siri
   HomeKitLink Siri                ================================================ Initializing New Plugin Session =================================================
   HomeKitLink Siri                Plugin name:                   HomeKitLink Siri
   HomeKitLink Siri                Plugin version:                0.6.16
   HomeKitLink Siri                Plugin ID:                     com.GlennNZ.indigoplugin.HomeKitLink-Siri
   HomeKitLink Siri                Indigo version:                2022.2.2
   HomeKitLink Siri                Python version:                3.10.2 (v3.10.2:a58ebcc701, Jan 13 2022, 14:50:16) [Clang 13.0.0 (clang-1300.0.29.30)]
   HomeKitLink Siri                Python Directory:              /Library/Frameworks/Python.framework/Versions/3.10
   HomeKitLink Siri
   HomeKitLink Siri                ================================================== End Initializing New Plugin  ==================================================
CliveS
Wed Aug 16, 2023 3:55 am
GlennNZ offline
I can have a look at the error
It is a pretty low level library error as it seems that no network exists.
Often a exception and error as currently the case is best option otherwise will never be caught or seen:
But will have a look,
Try 0.6.17
Catches this particular error, but will be another subsequent error given no network so not completely sure will help....
(Hard for me to test downstream errors, as all my OSX devices are headless, including development Mac Mini. So if I disable network - I’m a bit stuffed! - as I remotes into it)
Glenn
Wed Aug 16, 2023 8:27 am
Re: HomeKitLink shuts down after power cut
I have a trigger setup based on the online sensor plugin that restarts certain plugins when power is restored after a particular device stopped responding. Maybe that could also help?
Wed Aug 16, 2023 9:07 am
CliveS offline
I am using the Indigo error
Error   Unable to connect to IndigoDomo.com.
which I have only seen when I get the power blips and that then runs a 15 minute delayed execute action group that restarts all the plugins that I have seen fail in the logs.
They also run individually as they error at the Indigo restart which clears up most but not all, so the final delayed action runs after the time it takes to get the network back up.
At present the only one I can't restart is HomeKitLink as it shuts down but hopefully Glenn will sort that as HomeKitLink is in my must have plugins.
CliveS
Thu Aug 17, 2023 8:29 pm
GlennNZ offline
Hi Clive
You might have missed it - but try latest version as a post above.
Catches this particularly error, but will be others - but hopefully restartable from...
Glenn
Fri Aug 18, 2023 6:05 am
CliveS offline
Yes I did as I didn't get notification of the edit you made as I had already read the original.
Yes more errors but only the ones stating the error
HomeKitLink Siri Error (util.py: Function: get_local_address line: 58): Error : Message : Error Getting local address IP address. See debug log for more details.
HomeKitLink Siri Error (util.py: Function: get_local_address line: 59): Error : Message : This is a breaking issue which until fixed will cause no connection to be possible.
HomeKitLink Siri Error (util.py: Function: get_local_address line: 61): Error : Message : Try setting Interface for HAP in advanced options, Home Server Options:Interface setting
Which allows me to use 'Error Getting local address IP address. See debug log for more details' as the trigger to restart the plugin every minute until all the IP's are back up and running
Thanks Glenn
CliveS
Fri Aug 18, 2023 6:09 am
GlennNZ offline
I had the fix up within 10 minutes or so! Thought you might have missed it.
Fri Aug 18, 2023 6:41 am
CliveS offline
Yes I did because I read the message as soon as the email arrived and obviously before the edit arrived, I suppose that is a problem with editing messages but all is now up and running.
Just restarted my Mac Mini (headless) without the network cable, waited 5 minutes and then plugged into the network to look at the logs and all 4 plugins did eventually sort themselves out, reloading every minute until the trigger errors stopped, last thing to come back was the reflector just before the final reload after 15 minutes of all 4 plugins (belt and braces)
Thanks for sorting it out, I control Indigo now from Siri and Apple Home so HKL is an essential plugin for me.
Hopefully I am covered now for when Northern Powergrid in the UK has their next outage
CliveS
Fri Aug 18, 2023 8:13 am
So probably in the next 72 hours ; )
