Can't find cryptography module even though I installed it
Sat Jun 11, 2022 9:19 am
webdeck offline
I've installed the cryptography module, but the plugin can't seem to find it. I have 3 different pip3 executables (/opt/homebrew/b in, /usr/local/bin, /usr/bin), so I installed it using all three of those versions of pip3 and it still fails with this error:
   HomeKitLink Siri Error          Error in plugin execution InitializeMain:
  File "plugin.py", line 36, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/pyhap/accessory_driver.py", line 50, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/pyhap/encoder.py", line 9, in <module>
type: No module named 'cryptography'
[Indigo] # /opt/homebrew/bin/pip3 list | grep cryptography
cryptography                                      36.0.2
[Indigo] # /usr/local/bin/pip3 list | grep cryptography
cryptography 37.0.2
[Indigo] # /usr/bin/pip3 list | grep cryptography
cryptography 37.0.2
Sat Jun 11, 2022 9:33 am
Re: Can't find cryptography module even though I installed i
Cryptography should be installed in /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages
More detail:
pip3 show cryptography
Version: 36.0.2
Summary: cryptography is a package which provides cryptographic recipes and primitives to Python developers.
Home-page: https://github.com/pyca/cryptography
Author: The Python Cryptographic Authority and individual contributors
Author-email: cryptography-dev@python.org
License: BSD or Apache License, Version 2.0
Location: /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages
Requires: cffi
Required-by:
Sat Jun 11, 2022 9:56 am
webdeck offline
Ah, okay, so I got this working by running:
sudo /Library/Frameworks/Python.framework/Versions/3.10/bin/pip3 install cryptography
Apparently my /usr/bin/pip3 is the one installed by the developer command line tools which is separate.
