berkinet wrote:Indigo 2022.1.1
Plugin 0.3.1
I installed the cryptography module and ran the xattr command after installing and updating the plugin.
The Home app sees the hub and the published devices. However, it is unable to connect to any of the devices
This accessory is not responding.
Any ideas?
Please post a GitHub issue with logging
If there are no log errors - would guess you would post them if existed then it is Likely one the accessory / published devices has broken the bridge through user selection. It should be a device you have setup with via the “ShowALL” {may break bridge} option. HomeKit isn’t very good at letting know what the issue is - will just ‘crap out’ like this. Often it is because state is a string rather than True/False etc. would be interesting to know which device it is though.
Unpublish devices, particularly those that with selectable states, save and start again - do one at a time to track down the offending one.
