Return to the terminal window and copy and paste the below:
This removes the apple quarantine bit for downloaded files and is needed for full function. Very annoyingly unlike the pip3 command it is needed everytime you upgrade! Arghh.. Apple...
- Code: Select all
sudo xattr -rd com.apple.quarantine /Library/Application\ Support/Perceptive\ Automation/Indigo\ 2023.1/Plugins
NB: With every update of the plugin this commands needs to be run unfortunately. The plugin will now highlight this correct command when needed after an update.
