DSC keypad
Tue Jun 21, 2022 12:58 am
agame offline
DSC keypad
a sanity check: is the DSC Keypad device implemented in the current version?
DSC Keypad devices do not appear in the menu of candidate devices in the configuration dialogue so I assume not? [The GitHub notes indicate it is though elsewhere you note security is still coming, so though i'd clarify].
Tue Jun 21, 2022 2:15 am
GlennNZ offline
Re: DSC keypad
Security Systems:
Has recently been added supporting VSS, DSC plugin, and Paradox/SP6000/Magellan plugins - as HomeKit Security systems.
DSC Keypad….
Presume you mean a security system in HomeKit? and if that is the case - should select security system in show all options and see how goes….
Does seem a very old option - and only by default supported it because it was the only security option HomeBridge supported.
Untested though and you may find that VSS - which is action based for resulting security device in HomeKit is usable with a few Actions/Triggers.
Glenn
Tue Jun 21, 2022 2:54 am
agame offline
Re: DSC keypad
DSC is an old plugin though actively maintained, and I find very useful. Especially in rental properties, I find a real-world alarm system with a traditional keypad/touchscreen continues to be relevant. And it works during a system update lol. I map non-DSC sensors on to the DSC via Indigo.
I did load the VSS and after some jigging around I successfully published to HomeKit though (as the acronym implies) it really is only a virtual device to hold alarm system states, leaving a hell of a lot to be managed through scripts or a plethora of triggers and actions, much of which the DSC plugin does under the hood. Worst case i could use it as a virtual proxy for the DSC states though native support would be much nicer..
It occurred to me there could be contention between plugins so i have disabled VSS and unpublished the device, even cloned the DSC keypad. However the keypad devices don't appear in the selection dropdown.
Tue Jun 21, 2022 3:10 am
GlennNZ offline
DSC keypad
agame wrote:
DSC is an old plugin though actively maintained, and I find very useful. However the keypad devices don't appear in the selection dropdown.
Hi
I will have a look at DSC.
That aside - what is the issue? You mention keypad devices don’t appear in the indigo device selection?
Is that the problem?
Pretty sure that device selection pull-down lists every indigo device, plugin or otherwise. So if its an indigo device - it should be there, if it’s not an indigo device… then….
Tue Jun 21, 2022 5:05 pm
agame offline
Re: DSC keypad
Yes that is exactly the issue:I can see every other Indigo device listed in the plugin's device selection dropdown, many of which are never going to be suitable for HomeKit - but no DSC keypad devices.
Even if i create a new one it doesn't appear. Looking closer, none of the DSC plugin's devices are appearing in the dropdown (for instance, individual sensor devices).
Also as a check I confirmed other plugins can see these DSC plugin devices (Cynical Behaviours, the old HomeKit Plugin)
Tue Jun 21, 2022 9:28 pm
GlennNZ offline
Re: DSC keypad
OK.
Slightly odd - but I suspect they are probably all custom devices,
(Actually thought all devices would capture them - but I'll check, I'll try to install DSC plugin and see what I see)
DSC = custom devices
But checked code from afar and all custom devices still should be shown in the All Indigo Devices pulldown.
(Unless already published to a HomeKit Bridge... in which case will be listed at bottom)
Check that first.
Glenn
Tue Jun 21, 2022 11:20 pm
agame offline
Re: DSC keypad
This is really weird.
I just went to publish an (unrelated) new device, an voila, the keypad and motion sensors are now all present on the list.
One possibility is i missed the device in the list earlier: I'm noticing that the device list isn't in the usual alphabetic order (there's a full sequence of devices starting with a Capital letter, then another full sequence of lowercase. Double checked and equivalent lists in other plugins seem to be in conventional alphabetic order ignoring capitalisation... I did realise there was some strange ordering earlier and i thought i stepped through every device but possibly I missed it.
sorry to waste your time!
Tue Jun 21, 2022 11:38 pm
GlennNZ offline
Re: DSC keypad
Good to hear.
The ordering is a bit funky - I think its by device type, alphabetical and then repeats - but hasn’t got too far up the list to improve as once added no need to revisit.
See how you go with the security device - the DSC support is by necessity untested - did try but couldn’t setup without the hardware…
Wed Jun 22, 2022 12:03 am
agame offline
Re: DSC keypad
ah that makes more sense then.
The Unifi plugin has generated hundreds of devices i need to clean out...makes it difficult to deal with unpredictable sequencing!
From a quick play it the plugin appears to be working well, with the exception of mapping armed states: stay-armed and away-armed states seem to be mapped in reverse.
Also, DSC doesn't differentiate night from home/stay and selecting this in HomeKit currently does nothing (would make more sense to map it onto stay?)
Wed Jun 22, 2022 2:52 am
GlennNZ offline
Re: DSC keypad
Happy to revisit DSC - but as can’t test you are going to have to be pretty specific!
Specific debug logging for the DSC Keypad device probably ideal (can select that in plugin Config). And indigo will warning log anytime device changes.. May still need other debug logs as well..
The ‘mapping’ seems find to me, code wise. But really not sure what direction you are referring to… I have copied plugins conversion below. Seems correct.
DSC_TO_HOMEKIT_CURRENT = {
    "armed": HK_ALARM_STAY_ARMED,
    "armed_stay":HK_ALARM_STAY_ARMED,
    "armed_away": HK_ALARM_AWAY_ARMED,
    "exitDelay": HK_ALARM_DISARMED,
    "disarmed": HK_ALARM_DISARMED,
    "tripped": HK_ALARM_TRIGGERED,
DSC_TO_HOMEKIT_TARGET = {
But welcome to check further, turn on debug logging for the DSC device and let me know what it’s reporting/saying and what it should be.
Should be able to fine tune as you need.
Wed Jun 22, 2022 7:21 am
agame offline
Re: DSC keypad
okay...I've run a whole lot of tests.
I think one issue is present:
- HomeKit displays an armed status of 'Home' when Indigo reports the DSC armed status 'Away'. Attached screenshot shows homekit, and and a print of DSC states.
further debugging is made more complex because a DSC configuration issue means the system will always arm to 'Away' regardless of whether 'Away' or 'Home' is requested (regardless of the interface used).
Screen Shot 2022-06-22 at 8.04.01 pm.jpg (241.61 KiB) Viewed 40 times
