Py3 Conversion Issue using from __future__
Sun Dec 04, 2022 4:16 pm
automaton offline
I'm converting some external scripts to py3 which are executed by indigo. I used some of the automatic converters to upgrade my code.
I get this error when executing (from a schedule):
Dec 4, 2022 at 2:07:50 PM
   Script Error                    schedule "NOAA Alert Check CAP 2.20 Py3" script error in file noaa-cap-poller-py3-2.20.py:
   Script Error                    from __future__ imports must occur at the beginning of the file
   Script Error                    around line 1
However, the from __future__ statement is in the first line of the code:
from __future__ import absolute_import
from __future__ import print_function
import sys
import os
Is this not supported for py3 under Indigo, or am I making a rookie mistake?
Sun Dec 04, 2022 4:58 pm
Re: Py3 Conversion Issue using from __future__
I'm not sure, but I'll take a guess. Are you running this script as an embedded script? If so, try running it as a linked script instead.
Mon Dec 05, 2022 10:53 am
I don't think you need those two future imports - I think they were shims in Python 2 to make the behavior mirror Python 3. I could be wrong, but try it without them.
Thu Dec 08, 2022 10:22 am
automaton offline
Removing them seems to be the trick. Thanks.
